Your Portal Version: 1.0.3
Boardlink: http://www.handboogforum.nl
I have no idea.
Something went wrong with portal.
Tried to reinstall.
had to manually remove some files
When I try to enter my ACP, I get the following error message:
mods/lang_portal_acp_logs.php couldn't be opened.
Please help.
grtz,
Twan
can not access ACP
- phpBB.com User: DutchToxophilite
can not access ACP
The joy's of Archery can be found anywhere. Far places only offer exotic ways to suffer.
Re: can not access ACP
Hi.
I have found out that I can access the ACP through the Dutch Language.
But a few things don't work in the ACP in the Dutch Language, so I do need it in English.
grtz,
Twan
grtz,
Twan
I copied the file that was needed from the Dutch language to the Englisch language.
Now I can access the ACP again.
No further help needed.
grtz,
Twan
grtz,
Twan
Never hit the "edit" Button on top of your postings! NO! DO IT NOT!! Your Computer will explode into thousands of peaces... Thank God, you never hit this dangerous thing...
I am a little offended by your commentary.
Let me ask you this.
From a supporters view, what would you rather have?
1) One message that says: PROBLEM PROBLEM PROBLEM, oh never mind it's solved.
2) A list of messages that tell you the complete history of steps taken to try to solve the issue.
I can not imagine that you would go for the first one, for every one giving, searching or receiving support it is much better not to edit any messages.
They might not get the full and clear picture.
If you might differ on this with me, please let me know.
grtz,
Twan
grtz,
Twan
Its also a history list with the different steps up to the solution, if you make edits in your posting... And i dont want to offend you, but im sure you know about the doublepost rule in the most serious Boards
