warcraft recruitment block (port from phpbb3portal)
talonos
Portal Specialist
phpBB.com User: talonos
Re: warcraft recruitment block (port from phpbb3portal)
Post by talonos »
Thunderspud wrote:my bad, and i have been off for 3 days. my site is: http://www.demiseofexodar.com. I follwed the steps, no errors and i have access to it in the ACP, but it doesnt seem to display.
:oops:
did u edit
styles/prosilver/template/portal/portal_body.html
and put the info needed in there ?
	<!-- IF S_DISPLAY_PORTAL_RECRUITMENT -->
			<!-- INCLUDE portal/block/recruitment.html -->
if its already there then u need to upgrade to the NEW fixed version which is now in the first post, OVERWRITE all the files and check the file edits as a few things have been tweaked by Ice for bette compatability
Thunderspud
phpBB.de User: Thunderspud
phpBB.com User: Thunderspud
Post by Thunderspud »
yup I had that there *Under the right side). Ill download the upgrade and give it a spin
Thunderspud
All set! Thanks everyone! Once i updated to the new version it all came together! I look forword to teh other mods such as (Boss Progress, Recent lot, Etc...) hint hint :)
talonos
Portal Specialist
Post by talonos »
hmmmm let me think
Recent loot block is DONE and its here viewtopic.php?f=9&t=2465
vicster
Post by vicster »
I dont know if theres still any support on this, but i really hope there is.
Ive installed this block after changeing over from portal3, where it didn work either. cause of mulitple errors i decided to try board3 instead.
after completeing the installation all, the whole ".mods" segment in ACP only returns the following
[phpBB Debug] PHP Notice: in file /adm/index.php on line 156: Cannot modify header information - headers already sent by (output started at /language/en/mods/lang_portal_acp.php:1)
[phpBB Debug] PHP Notice: in file /adm/index.php on line 158: Cannot modify header information - headers already sent by (output started at /language/en/mods/lang_portal_acp.php:1)
[phpBB Debug] PHP Notice: in file /adm/index.php on line 159: Cannot modify header information - headers already sent by (output started at /language/en/mods/lang_portal_acp.php:1)
[phpBB Debug] PHP Notice: in file /adm/index.php on line 160: Cannot modify header information - headers already sent by (output started at /language/en/mods/lang_portal_acp.php:1)
Adm/index.php
155	// application/xhtml+xml not used because of IE
156	header('Content-type: text/html; charset=UTF-8');
157
158	header('Cache-Control: private, no-cache="set-cookie"');
159	header('Expires: 0');
160	header('Pragma: no-cache');
161
162	return;
163 }
^^ pretty much says it self what line 1 is
my eyes are bleeding from making just one of these mods work on either of the portals. i hope you can lend a newbie a hand.
Thanks in Advance
Vicster
www.amaturepwnography.com
Ice
Post by Ice »
You've saved the language file you've edited as the wrong type. You need to save it as UTF8 without BOM, your editor has saved it just as UTF8. A text editor that can differentiate is Notepad++
vicster
Post by vicster »
My God im a compelete newb.
Thank you so much, that fixed it instantly!
im you eternally greateful the late hrs must be crawling up on me =)
embryo
Post by embryo »
Hmm. It's not showing up in ACP?
(i've done cache multiple times)
Edit: Nvm, wasn't adding the module correctly. Fixed.
maniacal
Post by maniacal »
Wanted to stop back by now that I made our updated board live and say thanks again for the help. Combining the Recruitment block with the Application plugin for BBDKP has gotten us some good attention and results. I'm thoroughly enjoying the Board3 community thus far!
-Maniacal
http://www.perfecteulogy.net
Ciprian
Post by Ciprian »
Heya
I am just wondering i could take your Scirpt and Transfer it to Final Fantasy XI Jobs Recruitment, would save me alot of time.
Of Course i leave your Name etc. in there.
Greetings Ciprian
talonos
Portal Specialist
Post by talonos »
Ciprian wrote:Heya
Greetings Ciprian
go for it don't leave credits for me thou as i only ported it over from phpbb3portal, if credits are given they need to be sent to sheepy of phpbb3portal.com
Pharel
phpBB.de User: Pharel
Post by Pharel »
is there any chance to get it for other games??? maybe like aion http://na.aiononline.com/en/?? :)
Ciprian
Post by Ciprian »
Heya Talonos, i am almost done with FFXI Block.
I've had to make some changes to Recuitment.html since my Board is for English/German players, now its almost totally Multilingual.
Do u want a copy of it? Please consider i never learned any coding, just a bit of understanding.
talonos
Portal Specialist
Post by talonos »
yea why not Ciprian, sorry i didn't reply to your earlier post but i've just had a short break from thinks atm
Scaver
Post by Scaver »
I can't see the Recruitment under the ACP. I have done all step by step how it is described in the .txt
After that I have checked all twice and everything seems to be ok and I also get no error messages.
I have absolutly no ideas.
http://legion.scaver-online.de/
