warcraft recruitment block (port from phpbb3portal)
vollheilig
Re: warcraft recruitment block (port from phpbb3portal)
Hello
Fine mods, works perfekt in my portal, but i have one little problem.
The Statustext collur from Priest ist black on black background^^
i will change the Collor from the Priest to white but i have no idea.
http://www.blackhand-raiderz.de/portal.php
Biozone
Hmmmm...the update to board3 version 104 seems to have broken this lol, the block has disappeared and phpbb3 is giving me a general error
No mode specified when trying to access the admin config for it, gonna mess around with it to see if I can fix it.
/facepalm....my own mistake, nevermind lol
sorry
sorry
DigitalVinyl
Wrong thread sry
Sfullak
Works well for me check instructions here (more clear than txt file): http://www.phpbb3portal.com/viewtopic.php?f=45&t=1663
=> I found (template)
http://www.magenealogie.net
I have the same trouble: where I could change the color of priest from black to white ?vollheilig wrote:Hello
Thresherinc
- phpBB.com User: Thresherinc
Hi Talonos,
I'm trying to put this mod into my site, however in the install_board3.txt it says . . .
I'm proceeding on that basis anyway, hope I don't cock it up.
EDIT: Added lang_portal_acp.php differences too.
I think
Should read
I think it should be looking forInstall instructions wrote: ** Find:
'portal_minicalendar_day_link_color' => array('lang' => 'PORTAL_MINICALENDAR_DAY_LINK_COLOR' , 'validate' => 'string', 'type' => 'text:10:10', 'explain' => true),
break;
'portal_sunday_first' => array('lang' => 'PORTAL_SUNDAY_FIRST' , 'validate' => 'bool', 'type' => 'radio:yes_no', 'explain' => true),
break;
I think
'PORTAL_MINICALENDAR_DAY_LINK_COLOR_EXPLAIN'=> 'HEX or named colors are allowed such as #FFFFFF for white, or color names like violet.',
'PORTAL_SUNDAY_FIRST_EXPLAIN' => 'If disabled the calendar will show Mo. --> Su., else Su. --> Sa.',
Thresherinc
I have it all working on my board now, those corrections were, well . . .
Correct.
http://www.mostly-harmless.org
Correct.
Nylream
Hello everybody,
Edit : next time, I will not read the install.txt with only one eye
Here is an Aion recrutement Block. It works for me, but it is the first time I do this kind of thing so don't shoot at me if it's not perfect
http://www.omen-aion.com/phpBB3/downloa ... _block.zip
Jester
Can you reup the File please? The Download Link is downNylream wrote:Hello everybody,
Edit : next time, I will not read the install.txt with only one eye![]()
Here is an Aion recrutement Block. It works for me, but it is the first time I do this kind of thing so don't shoot at me if it's not perfect![]()
Thanks
Jester
Have anyone the aion_recruitment_block.zip (aion recruitment block) to Download? I search this
Thanks
Thanks
talonos
Topic author - Portal Specialist
- phpBB.com User: talonos
the Aion block is available HERE
Jester
Thanks for Downloadlinktalonos wrote:the Aion block is available HERE
Unrak
Hi Guys -
So i uploaded all the files and made the necessary edits (i included the modded edits from Thresherinc) and followed the instructions for the ACP.
Now i click on the .mods tab of the ACP and get a blank screen.
http://www.grraids.net/forum/adm/index. ... 8f459&i=31
So i did a database restore and still have no .mod screen. The tab is there biut clicking on it gives a blank screen.
So i started again. followed all the instructions (agfain) and got the same result. A blank screen.
Any idea what i have done wrong?
talonos
a white screen generally means you have a WHITSPACE in your edits somewhere
Unrak
Righto. I thought i had check thouroughly but you never know.
Doing a completely fresh install of PbPBB 3.0.6 tonight and will reinstall Portal and Mods after that. see if i get a result. I have a sneaking suspician that it may have had something to do with the fact that i had phpbb3 portal originally and converted to Board3. I may have missed some files or not removed some phpbb3 portal edits.
I'll keep you informed of my progress.
Many thanks
Many thanks
Unrak
A reinstall solved the problem, as i thought it would.
Thanks for both your time and your assistance with this great mod
