Pull dkp list from eqdkp plus to Board3 page.
Swinder
Post by Swinder »
Basically I have seen some topics flirting with the idea of pulling certain things from eqdkp install to a custom portal page and was wondering if anyone has managed to pull just the dkp list and display it on portal with its own page (../portal/dkp.html for example).
This way I would be able to use Board3 portal with my nice clean style and not have to mess around with the eqdkp portal which just ruins my site.
I have been toying with this for the last week or so and I really have no clue how to do this but this is due to my complete lack of knowledge.
As such I am wondering if anyone could write this up, I believe it would be a popular modification.
ahmiquilena
phpBB.com User: amiquilena
Re: Pull dkp list from eqdkp plus to Board3 page.
Post by ahmiquilena »
I've been trying to do pretty much the same, I want to eliminate the constant use of the eqdkp site, and just use the portal to look up important info such as current standing and /or next raids in custom blocks. Asked everywhere for help, but noone seems to really be bothering with it, which is a shame really.
http://www.bbdkp.com/ is a project which pretty much merges phpbb3+eqdkp in a portal-style website. But I already have the main website and the eqdkp set up with months of info. So that doesn't do anything for me.
If you find something somewhere, let me know :)
Dr Nick^
Post by Dr Nick^ »
it is possible to pull the info out of the db, just like every normal page you will make.
i made an eqdkp latest drop list in a block for my website,
who is running on an other portal. but almost the same.
it depends on what you want from the site, what does it needs to generate,
what does it need to display etc.
but generally everything should be able to get from there.
not saying i will make it, since its a lot of work, to make it also with the right modes/styles/etc/etc/
The reason also why i didnt make something like that is basicly due to overflood of functions in eqdkp,
and i dont mind using that system. But if you where looking @ just displaying some loot and dkp values
that you could consider making it ;) else find a style for eqdkp :P
ps: interlopers.interfrommars.nl there you can see what i made )pretty simple tho(
