[Rel] (WoW) Application form + ACP sup. (v3.1.x)
Fourth
Re: [Rel] (WoW) Application form + ACP sup. (v2.2)
Post by Fourth »
I upgraded to v1.0.4 and now one of your instructions on the installation is incorrect.
Open portal/includes/lang_adm_additional_blocks.php
This file no longer exists.
neo4u
phpBB.com User: neo4u
Post by neo4u »
Dr Nick^ wrote:i can.
must find out how guest can post and how that works first.
never use it, so never checked it ;)
we just let them register, make app. and if they got declined we just delete accound and lock toppic.
makes it also control-able. little more work. but better then all possible spam etc .
but when i got time will try to look into it (well be seperate release or something)
Hi mate I looked at the application.php file then found a removed the following
// Users must be logged in to make posts, delete this part if that is not needed.
if ($user->data['user_id'] == ANONYMOUS)
	login_box('', $user->lang['LOGIN']);
It now allows users to use application form without being registered. And because of how we have permissions set for the forum it links to unregistered users cannot post in it but applications go in no problem so no spam issues....
Dr Nick^
Post by Dr Nick^ »
@ Fourth
i need to look into changes of the board. didnt had the time to do it yet, but as far as i read from changelog i didnt see changes there.
will try to it this week.
@ neo4u
I wasnt actually sure if this was the key to solving the nog login.
because (i thought) that setting only made it possible to view the app form without being logged in.
I used some technic on the post witch requires user lang etc (some default stuff for posting with users etc)
so i wasnt sure about how it would work (reed work correctly without warning/errors) in this side.
if this works, keep on using it. note, its not mentioned that way ;)
Dr Nick^
Post by Dr Nick^ »
little update.
I recently installed board3 v1.0.4 myself.
i found some errors according to the language,
i'm working on a release. expect one today.
Dr Nick^
Re: [Rel] (WoW) Application form + ACP sup. (v2.2 + v3.0)
Post by Dr Nick^ »
I dont need to post this much, but hey like to keep you guys updated.
Version 3.0 released, working on board3 portal v1.0.4.
Version 2.2 will still be able to download for users with porta v1.0.3.
DigitalVinyl
Post by DigitalVinyl »
is it possible to add a poll to the application post? so the guildmembers could vote "yes" or "no"? not everyone is writing something in guildforum, especially on applications :D
WeZoN
phpBB.com User: WeZoN
Post by WeZoN »
Is it possible to make it add the user that takes a certain application to a group automatically?
Dr Nick^
Post by Dr Nick^ »
hi folks, sorry for late reply was on a small holiday.
@DigitalVinyl
I will look for an option for this, i dont know how yet, but i gonna think of it!
i assume you want a auto poll with 'your vote for this person' ?
@WeZoN
maybe i could make it, but it isn't totally in line with the meanings of this mod.
then you go deeper and deeper in the phpbb core.
I will check the posibilities, but i dont see it as a prio edit (yet)
if others think this should help them too, then plz let it know, then i can make it a prio ;)
Nick
Dr Nick^
Re: [Rel] (WoW) Application form + ACP sup. (v3.1.x)
Post by Dr Nick^ »
poll options included.
with some acp support in it.
hope this is what you want.
DigitalVinyl
Dr Nick^ wrote:poll options included.
Perfect!
In ACP i have something like
ACP_APPLICATIONFORM_POLL
PORTAL_APPLICATIONFORM_POLL:
PORTAL_APPLICATIONFORM_POLLQ:
PORTAL_APPLICATIONFORM_POLLTIME:
PORTAL_APPLICATIONFORM_POLLCHANGE:
I have reinstalled the Mod and the modul in ACP, do i missed anything or is this correct?
edit: Ok, found it ^^ Missed to copy the language file in my "DE" directory :-P
Swinder
Post by Swinder »
Hey again, just built a new portal and obviously installed this addon again however this time I have a small issue which you can see here; http://www.virtue-eu.co.uk/application.php
I adjusted the center width to 600 instead of 750 to prevent my left blocks being crushed, I assume somewhere there is something else that needs to be adjusted to account for my center block adjustment.
Other problem is that both the input boxes and the text itself is white which makes it difficult to view.
The style is a prosilver based one and is located here; http://www.phpbbhacks.com/download/8533
Magikz
Post by Magikz »
Hello, nice mod^ i was wondering if the was anyway to include wowhead tool tip tags to the 1st question.
Eg
Character Name: Randomname
then went you hit submit it will add tages to the name like [recruit]Randomname[/Recruit] on the forums
Dr Nick^
Post by Dr Nick^ »
@ swinder, i looked but i cant seem to find it. dunno whats wrong.
it maybe occours in some of the div settings, tho en dont put values on where they are.
only the size etc. it can be a bad table referrance some where. but there is nothing
that is line-ing out in the middle for the rest. so i hit the blanks there.
@magikz
ofc that is possible, but ... how often do ppl read the question and put their name correct there,
w/o any ohter crap like: BE paladin somenicename
then it wont work :P
and i dont know what the [reqruit] tag does on wow-head, is new to me
Magikz
Post by Magikz »
it just ads a little info from the armory to the post
would it be possible if you could post what needs editing to be able to do so
Spadewar
Post by Spadewar »
first off GREAT ADDON
but to make it custom fit for my website i had to make some change's in the applicationform.html that i think will be a great change to your released ver.
so what the change's did you may ask, it took all the answer box's and placed them under each question. this took me little bit to figure out and code right but at the end ..... its was so easy im smacking my self for it..
first to make the regular answer box " small one ' appear under the questions for all do a replace and enter in the following code as the code u want to replace.
<td height="30"
then the new code is as follows
      <td  valigh="left" height="30"
ok that takes care of the small box, now for the large textarea box's
same thing open replace and search for this code
<td align="left">
replace with
     <td valigh="left">
and this will allow you to have your txt box's under your questions.
