Raid Progress Block w/ACP
Vinck
Re: Raid Progress Block w/ACP
Post by Vinck »
You're a star Teksonic, and I'm sure the boys above will appreciate the session fix. My site was being backed up last night so was pretty dead, however back up and fine so when you get a chance that'd be fab.
Thanks again.
Teksonic
Portal Enthusiast
phpBB.com User: Teksonic
Post by Teksonic »
ok, so it's showing the block, but not the info inside it. are the individual raids on or off in the ACP?
Guild - Iron Circle
Server - Llane
Vinck
Post by Vinck »
Here's a few screenshots of what should be enough information to show how it doesn't seem to work;
http://www.matthuxley.com/img/mainoptions.jpg
http://www.matthuxley.com/img/raidoptions.jpg
Teksonic
Portal Enthusiast
Post by Teksonic »
ok perfect that should help me out. i'm on a train right now and the internet is sketchy as hell. so i'll look more closely in a bit. can you try turning everything on, and seeing if anything shows at all. there's a chance i have a switch incorrect and for some reason the heroics aren't showing properly.
Guild - Iron Circle
Server - Llane
Vinck
Post by Vinck »
Turned on every setting on the main section, enabled a few raids with all / some bosses to give some variety. All changes will be screencapped below so you can see exactly what I'm seeing.
http://www.matthuxley.com/img/mainoptions2.jpg
http://www.matthuxley.com/img/raidoptions2.jpg
http://www.matthuxley.com/img/raidoptions3.jpg
And yet, still no love on the portal showing anything: http://www.quietlyconfident.net/forum/
Thanks again, request any information or anything and I'll post as soon as I see it.
Swinder
Post by Swinder »
I noticed today my zone icons sometimes failed to load (except after cache being purged) so I assumed it was related to the session id fix.
I applied the fix and purged my cache, this caused all icons to not show at all. I have since reverted back to the line below which is ok as long as I purge the cache every so often.
'RP_IMAGE' => append_sid("{$phpbb_root_path}styles/" . $user->theme['theme_path'] . "/theme/images/raid_progress/"),
Teksonic
Portal Enthusiast
Post by Teksonic »
nm...
Guild - Iron Circle
Server - Llane
Unrak
Post by Unrak »
Hi Tek and welcome back for the holidays.
So - just like Swinder - my icons are failing to load and the boss progress block is also now missing it's ticks and crosses on prosilver, and not there at all on wowmoonclaw. I have turned on the style switcher so you can have a look.
http://www.grraids.net/reborn/phpbb3/portal.php?style=1
here are a few screenshots showing differnt browsers:
Hope that helps
Teksonic
Portal Enthusiast
Post by Teksonic »
ok let me double check this again and see if there is some thing else wrong.
Guild - Iron Circle
Server - Llane
Teksonic
Portal Enthusiast
Post by Teksonic »
SESSION BUG FIX - anyone having issues with the images not showing should apply this fix immediately. I will including it in the next patch also.
Open
portal/block/raid_progress.php
Find:
Replace With:
'RP_IMAGE' => "{$phpbb_root_path}styles/" . $user->theme['theme_path'] . '/theme/images/raid_progress/',
Sorry guys, used the wrong quotes in one part when I wrote the fix the first time, mah bad. i changed the previous post also so both are correct. Just make sure your RP_IMAGE line is exactly the same as the second line of code above.
Guild - Iron Circle
Server - Llane
Teksonic
Portal Enthusiast
Post by Teksonic »
Any other issues, currently ongoing that I haven't looked into yet?
Guild - Iron Circle
Server - Llane
Swinder
Post by Swinder »
Applied the updated fix and all images are displaying correctly, thanks!
Unrak
Post by Unrak »
ok - now i am weirded out.
I have a fresh clean install of phpBB3 and i have installed the Board3 Portal. Now i install this block and i get:
[phpBB Debug] PHP Notice: in file /install/install_install.php on line 27: Undefined property: module::$installed_rpb_version
[phpBB Debug] PHP Notice: in file /install/index.php on line 315: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3493)
[phpBB Debug] PHP Notice: in file /install/index.php on line 316: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3493)
[phpBB Debug] PHP Notice: in file /install/index.php on line 317: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3493)
[phpBB Debug] PHP Notice: in file /install/index.php on line 318: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3493)
Now i know that "headers already sent by " indicates a space before the <php at the start of a file somewhere but it is not in index.php nor in includes.php so i navigate to those 4 lines and see that they are header information:
// header('Content-type: text/html; charset=UTF-8');
		// header('Cache-Control: private, no-cache="set-cookie"');
		// header('Expires: 0');
		// header('Pragma: no-cache');
I comment them out as you see and i am left with:
I have installed this block many times trying to fix the missing images issue that Tek soved with the code change so i am at a loss as to why i am suddenly getting this error. Any clues?
Edit: have unistalled the entire block until i get this fixed as it was throwing errors on my forums.
Teksonic
Portal Enthusiast
Post by Teksonic »
Unrak wrote:ok - now i am weirded out.
I will look into this shortly. Also. "headers already sent", doesn't necessarily mean a space at the start of the file. More often then not it means something completely different.
the issue your seeing is in the installer only. so what version of the mod are you using? and when do you get this error? as soon as you try to install, at a certain page.. etc
Guild - Iron Circle
Server - Llane
Teksonic
Portal Enthusiast
Post by Teksonic »
ok made some changes to the installer. i'll upload a copy here for you to try out. extract this and replace your whole install folder with it. let me know how it goes. For others, if your not having an issue don't worry about this change.
New Install Files
Thanks
Guild - Iron Circle
Server - Llane
