Raid Progress Block w/ACP
cromatics
Portal Enthusiast
Re: Raid Progress Block w/ACP
Post by cromatics »
kann ich dir sagen, die de übersetzung von der ersten seite ist noch vom wow patch 3.2 (Raid Progress Block ver. v2.0.0) oder so, da ist icc noch nicht drin, habe mir die de übersetzung für 2.2.0 selbst gebastelt, solltest du da noch fehler drin finden (schreibweise der namen) sag mir bescheit
MarriageAA
Post by MarriageAA »
Okay, so now that's sorted, anyone any idea why I still can;t see ICC bosses. Even after a reinstall the same thing, all other raid notices work, except icc 10 and 25.
cromatics
Portal Enthusiast
Post by cromatics »
because my English is not so good because you can time a picture with your problem please?
MarriageAA
Okay, here are some pictures (linked as I don't have thumbs and don't want to destroy the board!):
here is my homepage at http://www.punished-guild.eu - http://img.photobucket.com/albums/v98/1 ... c/home.jpg
I addes the togc part just to show that the other functions work.
now, here is the block home section:
http://img.photobucket.com/albums/v98/1 ... ptions.jpg
here is the togc (working) block:
http://img.photobucket.com/albums/v98/1 ... c/togc.jpg
And here is the icc non-working block:
http://img.photobucket.com/albums/v98/1 ... fc/icc.jpg
the whole setup is pretty simple to be honest, so I am suprised I can't get this bit right.
I have done a full re-install, but that did not resolve the issue either.
cromatics
Portal Enthusiast
Post by cromatics »
you also run the installer?
you've already emptied your cache from the forum?
MarriageAA
cromatics wrote:you also run the installer?
Yep on both.
MarriageAA
Okay. Now it's sorted. I completely deleted the html progress block from my web server and recopied it up (thought a reinstall would do that?) and then redid my cache - popped up perfectly.
Thanks a million!
Teksonic
Portal Enthusiast
phpBB.com User: Teksonic
Post by Teksonic »
vollheilig wrote:hello
i have make the update from a older version on my portal an now i have a little bug
in my acp i have this
and on the website a have this
and yes i make the changes from the readme^^
any idea was the problem is?
on http://eknb.dogweb24.de you can see it
thx
make sure to upload the new language files that problem your seeing is because the language file is out of date for the version your running.
Guild - Iron Circle
Server - Llane
Teksonic
Portal Enthusiast
Post by Teksonic »
hey guys, sorry i haven't been around much to get to these issues, glad i see others are able to help. The army has been kicking my ass for the last couple months, plus i've been writing a huge new Raid and Event Planner tool in my spare time.
Guild - Iron Circle
Server - Llane
Biozone
Post by Biozone »
Do you plan to have ical native support?
Teksonic
Portal Enthusiast
Post by Teksonic »
Biozone wrote:Do you plan to have ical native support?
ical? as in apples icalendar? i had never thought about adding support for that, if this is something people really want i could look into it, but i have 0 knowledge of ical.
Guild - Iron Circle
Server - Llane
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
for anyone having a problem with images not working if you use the theme selector heres a fix for it
inside portal/block/raid_progress.php
FIND:
'RP_IMAGE'
and replace that whole line with:
		'RP_IMAGE'			=> "{$phpbb_root_path}styles/" . $user->theme['theme_path'] . "/theme/images/raid_progress/",
this will remove the append_sid tag on the image link and will make the images work without problem with theme selector enabled :)
Teksonic
Portal Enthusiast
Post by Teksonic »
good call Tal. i don't personally use different themes so i never thought to include that. I will make sure to modify the Cataclysm version to allow theme selection without fucking things up.
Guild - Iron Circle
Server - Llane
Biozone
Post by Biozone »
http://en.wikipedia.org/wiki/ICalendar
Yeah, Group calendar 5 allows for exporting ical files to web calendars but all the web calendars that have ical support I find are total stand-alone packages...every PHPBB calendar I have found does not have ical support...oddly enough.
I have asked a few authors of PHPBB calendars but they do not seem interested and yep, 0 knowledge on it so am tempted to try one of the stand-alone ones like http://phpicalendar.net/ and just integrate it into PHPBB3.
Tried to get my guild to switch to a web based event management but they seem to be set on the in-game addon for ease of use and the fact that not everybody registered on the website and seeing now group calendar 5 can snyc itself with the WOW calendar, even more harder to get them to switch lol
But some do want the web based event management and would rather be able to sync all the event data than type it all out again on the website.
Biozone
Post by Biozone »
Sorry I tend to go by the file extension name which oddly enough is apple calendar's software name xD
