Create Topic from Portal
DutchToxophilite
phpBB.com User: DutchToxophilite
Post by DutchToxophilite »
Your Portal Version: 1.0.3
Boardlink: http://www.handboogforum.nl
Thought about it.
Hi.
My question is something, one of my board members asked me.
He has trouble finding the correct button to start a new topic.
Would it be possible to "Create a new topic from the Portal?" without having to go through the board index?
I figure it should be possible to do that, but I also figure, that this has to be a separate MOD.
When the link for "A new Topic" has been selected, the user should get a single screen, where he can select the (categorie)forum the message should go.
Let me know if this is not possible, or maybe it is.
grtz,
Twan
The joy's of Archery can be found anywhere. Far places only offer exotic ways to suffer.
DutchToxophilite
Re: Create Topic from Portal
Nobody?
Please let me know something...... Even if it would not be possible without a separate MOD....
grtz,
Twan
It would be possible with an extra block i guess (well, I'm pretty sure).
The function make_jumpbox in the includes/functions_content.php core file might be interesting for you - regarding the SQL query and the dropdown menu for the forum list.
Basically you "just" have to rename and rebuild this function, to let the link point directly to the posting.php, using the desired forum ID I guess.
This is how the viewforum.php is building up the link to start a new topic, might be interesting as well:
    'U_POST_NEW_TOPIC'    => ($auth->acl_get('f_post', $forum_id) || $user->data['user_id'] == ANONYMOUS) ? append_sid("{$phpbb_root_path}posting.$phpEx", 'mode=post&f=' . $forum_id) : '',
The function make_jumpbox is called this way:
make_jumpbox(append_sid("{$phpbb_root_path}viewforum.$phpEx"));
Just found out - pretty easy with the make_jumpbox function:
Open portal.php
find:
replace with:
make_jumpbox(append_sid("{$phpbb_root_path}posting.$phpEx", 'mode=post&f=' . $forum_id));
If a forum is now selected in the jumpbox, it leads directly to the posting.php with the correct forum ID. :)
Now 80% of the way is gone. ;)
DutchToxophilite
Hi Kevin.
That works.
But if it is possible it would be nice if there would be a separate "button" or link. And the user would be able to only select the forums where creating new topics is allowed.
If that is not possible, I think I will use this solution.
grtz,
Twan
Then i would suggest to copy, rename and modify this function.
I'm sorry, i do not have the time to do more investigation, very busy at the moment.
*moved to "modification requests"*
