As you can guess it is a gaming site. See what you think.
http://ltpgaming.com/
ltpgaming
Re: ltpgaming
Your site looks great!
Where did you get the Ventrilo script?
If possible can I get a copy?
Re: ltpgaming
Hmm... your Blocks have different Headers
Re: ltpgaming
Vent is from gameservers. I really wish I had my own script and did not need to rely on a third party.
@Mike feeling some sarcasm..may just be me. Either way I don't claim to be an expert....was just showing what I did.
Re: ltpgaming
Sarcasm? Im using this Style too, and i prefer the Headers from the Board for the Blocks instead of the original Headers after installation. (heres what i mean)
In your Portal, the Forumlist Blocks have rounded Corners and the other ones dont. Thats what i mean.
But i just want to give a hint... it was not my intension to make any sarcasm...
Re: ltpgaming
Ok sry Mike guess I was just reading into your post too much, posting when drinking
. I see what you mean now though, I never even noticed that before but I see from your site that the rounded corners look much better. Thanks for the tip. I'm still on 1.2 of the portal so not sure if that has anything to do with it. I'll look into it some. BTW I like your user rank images also...nice.
@yocalif I meant to say http://www.gametracker.com for the vent status.
Re: ltpgaming
If you update to the latest version of B3P you can simply use one file to change all the headers of the Blocks.
Maybe you noticed this section already: http://board3.de/viewforum.php?f=42
Theres a file for Black Pearl too, at the very bottom...
But note: this will not work with 1.0.2 since we change the Style system in 1.0.3
Re: ltpgaming
Looks like I'll have to update then. I didn't want to take the chance of messing up my board but editing every block by hand will be a pain also. I can change the headers to the rounded ones but can't figure out how to fix the border around the block.
Edit: Just remembered I have a test board with 1.03 on it so I'll give it a try on that. Thx Mike.
EDIT2: Updated my main site to phpbb 3.0.5 and the portal to 1.0.3. Added the rounded block headers. Just need to add back my custom blocks.
EDIT3: Crap..I'm stuck. Before I would just add a block in styles/black_pearl/template/portal/block and then choose where it was displayed in portal_body.html. I understand there is a custom thing in the admin panel but that only lets you add one side and one center. I can still add blocks like before but they have the old square headers.I'm sure I must be missing something...help plz
Last edit: Got the blocks...I was using my old ones as a template instead of the new custom blocks.
