I am new to phpbb but am slowly learning
I am using the Board 3 portal and AeroRed
I would like to add a custom box to the portal which I have done no problem.
The problem comes with the info I want in the box...I would like to show a list of Members and their golf handicap (from the custom profile field)
This is the code I have for the .HTML:-
{$C_BLOCK_H_L}Handicaps{$C_BLOCK_H_R}
<tr class="row1">
<td>Player</td>
<td>HDCP</td>
<!-- BEGIN handicaplist -->
<tr class="row1">
<td><strong>{handicaplist.USER_NAME} : {handicaplist.HANDICAP}</strong></td>
<!-- END handicaplist -->
{$C_BLOCK_F_L}{$C_BLOCK_F_R}Code: Select all
//Portal Block to return username and handicap
//make sure the code is being called inside of the application itself and is not a hack attempt
if (!defined('IN_PHPBB'))
exit;
//make sure it is being run from the portal mod
if (!defined('IN_PORTAL'))
exit;
//select the username from the users table paired with the handicap from the profile fields table by user_id
$sql = 'SELECT u.username, p.handicap
FROM ' . USERS_TABLE . ' u
LEFT JOIN . PROFILE_FIELD_DATA_TABLE . p
ON u.user_id = p.user_id
ORDER BY u.username ASC';
//execute the query and assign the results to the $result array
//loop through each item in the result set assigning each row to the row array and then read the row array and set the values in the handicaplist array for the block display from the contents of the row
foreach($result as $row)
$template->assign_block_vars('handicaplist', array(
'USER_NAME' => $row['username'],
'HANDICAP' => $row['handicap'],
?> After trying to work out what is going wrong(for a whole week) I am now going round in circles
Thanks For Any Help
Cheers RobC
