Problem Beim Regestrieren
Evolution
Post by Evolution »
Link zu Deinem Forum: http://www.evolutio.bplaced.de/Forum/uc ... e=register
ich kan mich auf meinem Portal nicht Regestrieren BZW auf Dem Forum kann man sich ent Regestrieren,
ich habe hier mal die FehlerMeldung:
Fatal error: Call to undefined method user::confirm_gc() in /users/evolutio/www/Forum/includes/ucp/ucp_register.php on line 473
und da ist Iwo der Fehler,
ich Suche mal eben die Stelle Heraus:
				$user->confirm_gc(CONFIRM_REG);
und der Ganze Code:
* @package ucp
* @version $Id: ucp_register.php 9511 2009-05-08 11:48:51Z Kellanved $
* @ignore
if (!defined('IN_PHPBB'))
	exit;
* ucp_register
* Board registration
* @package ucp
class ucp_register
	var $u_action;
	function main($id, $mode)
		global $config, $db, $user, $auth, $template, $phpbb_root_path, $phpEx;
		if ($config['require_activation'] == USER_ACTIVATION_DISABLE)
			trigger_error('UCP_REGISTER_DISABLE');
		include($phpbb_root_path . 'includes/functions_profile_fields.' . $phpEx);
		$confirm_id			= request_var('confirm_id', '');
		$confirm_refresh	= (isset($_POST['confirm_refresh']) && $config['confirm_refresh']) ? ((!empty($_POST['confirm_refresh'])) ? 1 : 0) : false;
		$coppa				= (isset($_REQUEST['coppa'])) ? ((!empty($_REQUEST['coppa'])) ? 1 : 0) : false;
		$agreed				= (!empty($_POST['agreed'])) ? 1 : 0;
		$submit				= (isset($_POST['submit'])) ? true : false;
		$change_lang		= request_var('change_lang', '');
		$user_lang			= request_var('lang', $user->lang_name);
		if ($agreed)
			add_form_key('ucp_register');
			add_form_key('ucp_register_terms');
		if ($change_lang || $user_lang != $config['default_lang'])
			$use_lang = ($change_lang) ? basename($change_lang) : basename($user_lang);
			if (file_exists($user->lang_path . $use_lang . '/'))
				if ($change_lang)
					$submit = false;
					// Setting back agreed to let the user view the agreement in his/her language
					$agreed = (empty($_GET['change_lang'])) ? 0 : $agreed;
				$user->lang_name = $lang = $use_lang;
				$user->lang = array();
				$user->add_lang(array('common', 'ucp'));
				$change_lang = '';
				$user_lang = $user->lang_name;
		$cp = new custom_profile();
		$error = $cp_data = $cp_error = array();
		if (!$agreed || ($coppa === false && $config['coppa_enable']) || ($coppa && !$config['coppa_enable']))
			$add_lang = ($change_lang) ? '&change_lang=' . urlencode($change_lang) : '';
			$add_coppa = ($coppa !== false) ? '&coppa=' . $coppa : '';
			$s_hidden_fields = ($confirm_id) ? array('confirm_id' => $confirm_id) : array();
			// If we change the language, we want to pass on some more possible parameter.
			if ($change_lang)
				// We do not include the password
				$s_hidden_fields = array_merge($s_hidden_fields, array(
					'username'			=> utf8_normalize_nfc(request_var('username', '', true)),
					'email'				=> strtolower(request_var('email', '')),
					'email_confirm'		=> strtolower(request_var('email_confirm', '')),
					'confirm_code'		=> request_var('confirm_code', ''),
					'confirm_id'		=> request_var('confirm_id', ''),
					'lang'				=> $user->lang_name,
					'tz'				=> request_var('tz', (float) $config['board_timezone']),
			if ($coppa === false && $config['coppa_enable'])
				$now = getdate();
				$coppa_birthday = $user->format_date(mktime($now['hours'] + $user->data['user_dst'], $now['minutes'], $now['seconds'], $now['mon'], $now['mday'] - 1, $now['year'] - 13), $user->lang['DATE_FORMAT']);
				unset($now);
				$template->assign_vars(array(
					'L_COPPA_NO'		=> sprintf($user->lang['UCP_COPPA_BEFORE'], $coppa_birthday),
					'L_COPPA_YES'		=> sprintf($user->lang['UCP_COPPA_ON_AFTER'], $coppa_birthday),
					'U_COPPA_NO'		=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=register&coppa=0' . $add_lang),
					'U_COPPA_YES'		=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=register&coppa=1' . $add_lang),
					'S_SHOW_COPPA'		=> true,
					'S_HIDDEN_FIELDS'	=> build_hidden_fields($s_hidden_fields),
					'S_UCP_ACTION'		=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=register' . $add_lang),
					'L_TERMS_OF_USE'	=> sprintf($user->lang['TERMS_OF_USE_CONTENT'], $config['sitename'], generate_board_url()),
					'S_SHOW_COPPA'		=> false,
					'S_REGISTRATION'	=> true,
					'S_UCP_ACTION'		=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=register' . $add_lang . $add_coppa),
			$this->tpl_name = 'ucp_agreement';
			return;
		// Try to manually determine the timezone and adjust the dst if the server date/time complies with the default setting +/- 1
		$timezone = date('Z') / 3600;
		$is_dst = date('I');
		if ($config['board_timezone'] == $timezone || $config['board_timezone'] == ($timezone - 1))
			$timezone = ($is_dst) ? $timezone - 1 : $timezone;
			if (!isset($user->lang['tz_zones'][(string) $timezone]))
				$timezone = $config['board_timezone'];
			$is_dst = $config['board_dst'];
		$data = array(
			'new_password'		=> request_var('new_password', '', true),
			'password_confirm'	=> request_var('password_confirm', '', true),
			'lang'				=> basename(request_var('lang', $user->lang_name)),
			'tz'				=> request_var('tz', (float) $timezone),
		// Check and initialize some variables if needed
		if ($submit)
			$error = validate_data($data, array(
				'username'			=> array(
					array('string', false, $config['min_name_chars'], $config['max_name_chars']),
					array('username', '')),
				'new_password'		=> array(
					array('string', false, $config['min_pass_chars'], $config['max_pass_chars']),
					array('password')),
				'password_confirm'	=> array('string', false, $config['min_pass_chars'], $config['max_pass_chars']),
				'email'				=> array(
					array('string', false, 6, 60),
					array('email')),
				'email_confirm'		=> array('string', false, 6, 60),
				'confirm_code'		=> array('string', !$config['enable_confirm'], CAPTCHA_MIN_CHARS, CAPTCHA_MAX_CHARS),
				'tz'				=> array('num', false, -14, 14),
				'lang'				=> array('match', false, '#^[a-z_\-]{2,}$#i'),
			if (!check_form_key('ucp_register'))
				$error[] = $user->lang['FORM_INVALID'];
			// Replace "error" strings with their real, localised form
			$error = preg_replace('#^([A-Z_]+)$#e', "(!empty(\$user->lang['\\1'])) ? \$user->lang['\\1'] : '\\1'", $error);
			// DNSBL check
			if ($config['check_dnsbl'])
				if (($dnsbl = $user->check_dnsbl('register')) !== false)
					$error[] = sprintf($user->lang['IP_BLACKLISTED'], $user->ip, $dnsbl[1]);
			// validate custom profile fields
			$cp->submit_cp_field('register', $user->get_iso_lang_id(), $cp_data, $error);
			// Visual Confirmation handling
			$wrong_confirm = false;
			if ($config['enable_confirm'])
				if (!$confirm_id)
					$error[] = $user->lang['CONFIRM_CODE_WRONG'];
					$wrong_confirm = true;
					$sql = 'SELECT code
						FROM ' . CONFIRM_TABLE . "
						WHERE confirm_id = '" . $db->sql_escape($confirm_id) . "'
							AND session_id = '" . $db->sql_escape($user->session_id) . "'
							AND confirm_type = " . CONFIRM_REG;
					$db->sql_freeresult($result);
					if ($row)
						if (strcasecmp($row['code'], $data['confirm_code']) === 0)
							$sql = 'DELETE FROM ' . CONFIRM_TABLE . "
			if (!sizeof($error))
				if ($data['new_password'] != $data['password_confirm'])
					$error[] = $user->lang['NEW_PASSWORD_ERROR'];
				if ($data['email'] != $data['email_confirm'])
					$error[] = $user->lang['NEW_EMAIL_ERROR'];
				$server_url = generate_board_url();
				// Which group by default?
				$group_name = ($coppa) ? 'REGISTERED_COPPA' : 'REGISTERED';
				$sql = 'SELECT group_id
					FROM ' . GROUPS_TABLE . "
					WHERE group_name = '" . $db->sql_escape($group_name) . "'
						AND group_type = " . GROUP_SPECIAL;
				if (!$row)
					trigger_error('NO_GROUP');
				$group_id = $row['group_id'];
				if (($coppa ||
					$config['require_activation'] == USER_ACTIVATION_SELF ||
					$config['require_activation'] == USER_ACTIVATION_ADMIN) && $config['email_enable'])
					$user_actkey = gen_rand_string(10);
					$key_len = 54 - (strlen($server_url));
					$key_len = ($key_len < 6) ? 6 : $key_len;
					$user_actkey = substr($user_actkey, 0, $key_len);
					$user_type = USER_INACTIVE;
					$user_inactive_reason = INACTIVE_REGISTER;
					$user_inactive_time = time();
					$user_type = USER_NORMAL;
					$user_actkey = '';
					$user_inactive_reason = 0;
					$user_inactive_time = 0;
				$user_row = array(
					'username'				=> $data['username'],
					'user_password'			=> phpbb_hash($data['new_password']),
					'user_email'			=> $data['email'],
					'group_id'				=> (int) $group_id,
					'user_timezone'			=> (float) $data['tz'],
					'user_dst'				=> $is_dst,
					'user_lang'				=> $data['lang'],
					'user_type'				=> $user_type,
					'user_actkey'			=> $user_actkey,
					'user_ip'				=> $user->ip,
					'user_regdate'			=> time(),
					'user_inactive_reason'	=> $user_inactive_reason,
					'user_inactive_time'	=> $user_inactive_time,
				// Register user...
				$user_id = user_add($user_row, $cp_data);
				// This should not happen, because the required variables are listed above...
				if ($user_id === false)
					trigger_error('NO_USER', E_USER_ERROR);
				if ($coppa && $config['email_enable'])
					$message = $user->lang['ACCOUNT_COPPA'];
					$email_template = 'coppa_welcome_inactive';
				else if ($config['require_activation'] == USER_ACTIVATION_SELF && $config['email_enable'])
					$message = $user->lang['ACCOUNT_INACTIVE'];
					$email_template = 'user_welcome_inactive';
				else if ($config['require_activation'] == USER_ACTIVATION_ADMIN && $config['email_enable'])
					$message = $user->lang['ACCOUNT_INACTIVE_ADMIN'];
					$email_template = 'admin_welcome_inactive';
					$message = $user->lang['ACCOUNT_ADDED'];
					$email_template = 'user_welcome';
				if ($config['email_enable'])
					include_once($phpbb_root_path . 'includes/functions_messenger.' . $phpEx);
					$messenger = new messenger(false);
					$messenger->template($email_template, $data['lang']);
					$messenger->to($data['email'], $data['username']);
					$messenger->headers('X-AntiAbuse: Board servername - ' . $config['server_name']);
					$messenger->headers('X-AntiAbuse: User_id - ' . $user->data['user_id']);
					$messenger->headers('X-AntiAbuse: Username - ' . $user->data['username']);
					$messenger->headers('X-AntiAbuse: User IP - ' . $user->ip);
					$messenger->assign_vars(array(
						'WELCOME_MSG'	=> htmlspecialchars_decode(sprintf($user->lang['WELCOME_SUBJECT'], $config['sitename'])),
						'USERNAME'		=> htmlspecialchars_decode($data['username']),
						'PASSWORD'		=> htmlspecialchars_decode($data['new_password']),
						'U_ACTIVATE'	=> "$server_url/ucp.$phpEx?mode=activate&u=$user_id&k=$user_actkey")
					if ($coppa)
							'FAX_INFO'		=> $config['coppa_fax'],
							'MAIL_INFO'		=> $config['coppa_mail'],
							'EMAIL_ADDRESS'	=> $data['email'])
					$messenger->send(NOTIFY_EMAIL);
					if ($config['require_activation'] == USER_ACTIVATION_ADMIN)
						// Grab an array of user_id's with a_user permissions ... these users can activate a user
						$admin_ary = $auth->acl_get_list(false, 'a_user', false);
						$admin_ary = (!empty($admin_ary[0]['a_user'])) ? $admin_ary[0]['a_user'] : array();
						// Also include founders
						$where_sql = ' WHERE user_type = ' . USER_FOUNDER;
						if (sizeof($admin_ary))
							$where_sql .= ' OR ' . $db->sql_in_set('user_id', $admin_ary);
						$sql = 'SELECT user_id, username, user_email, user_lang, user_jabber, user_notify_type
							FROM ' . USERS_TABLE . ' ' .
							$where_sql;
							$messenger->template('admin_activate', $row['user_lang']);
							$messenger->to($row['user_email'], $row['username']);
							$messenger->im($row['user_jabber'], $row['username']);
								'U_USER_DETAILS'	=> "$server_url/memberlist.$phpEx?mode=viewprofile&u=$user_id",
							$messenger->send($row['user_notify_type']);
				$message = $message . '<br /><br />' . sprintf($user->lang['RETURN_INDEX'], '<a href="' . append_sid("{$phpbb_root_path}index.$phpEx") . '">', '</a>');
				trigger_error($message);
		$s_hidden_fields = array(
			'agreed'		=> 'true',
			'change_lang'	=> 0,
		if ($config['coppa_enable'])
			$s_hidden_fields['coppa'] = $coppa;
		$s_hidden_fields = build_hidden_fields($s_hidden_fields);
		$confirm_image = '';
		// Visual Confirmation - Show images
			if ($change_lang || $confirm_refresh)
				$str = '&change_lang=' . $change_lang;
				$sql = 'SELECT code
				if (!$row = $db->sql_fetchrow($result))
					$confirm_id = '';
				$str = '';
			if (!$change_lang || !$confirm_id || !$confirm_refresh)
				$sql = 'SELECT COUNT(session_id) AS attempts
					WHERE session_id = '" . $db->sql_escape($user->session_id) . "'
				$attempts = (int) $db->sql_fetchfield('attempts');
				if ($config['max_reg_attempts'] && $attempts > $config['max_reg_attempts'])
					trigger_error('TOO_MANY_REGISTERS');
				$code = gen_rand_string(mt_rand(CAPTCHA_MIN_CHARS, CAPTCHA_MAX_CHARS));
				$confirm_id = md5(unique_id($user->ip));
				$seed = hexdec(substr(unique_id(), 4, 10));
				// compute $seed % 0x7fffffff
				$seed -= 0x7fffffff * floor($seed / 0x7fffffff);
				$sql = 'INSERT INTO ' . CONFIRM_TABLE . ' ' . $db->sql_build_array('INSERT', array(
					'confirm_id'	=> (string) $confirm_id,
					'session_id'	=> (string) $user->session_id,
					'confirm_type'	=> (int) CONFIRM_REG,
					'code'			=> (string) $code,
					'seed'			=> (int) $seed)
			else if ($confirm_refresh)
				$sql = 'UPDATE ' . CONFIRM_TABLE . ' SET ' . $db->sql_build_array('UPDATE', array(
					'seed'			=> (int) $seed)) . "
					WHERE
					confirm_id = '" . $db->sql_escape($confirm_id) . "' AND
					session_id = '" . $db->sql_escape($session_id) . "' AND
					confirm_type = " . (int) CONFIRM_REG;
			$confirm_image = '<img src="' . append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=confirm&id=' . $confirm_id . '&type=' . CONFIRM_REG . $str) . '" alt="" title="" />';
			$s_hidden_fields .= '<input type="hidden" name="confirm_id" value="' . $confirm_id . '" />';
		$l_reg_cond = '';
		switch ($config['require_activation'])
			case USER_ACTIVATION_SELF:
				$l_reg_cond = $user->lang['UCP_EMAIL_ACTIVATE'];
			break;
			case USER_ACTIVATION_ADMIN:
				$l_reg_cond = $user->lang['UCP_ADMIN_ACTIVATE'];
			break;
			'ERROR'				=> (sizeof($error)) ? implode('<br />', $error) : '',
			'USERNAME'			=> $data['username'],
			'PASSWORD'			=> $data['new_password'],
			'PASSWORD_CONFIRM'	=> $data['password_confirm'],
			'EMAIL'				=> $data['email'],
			'EMAIL_CONFIRM'		=> $data['email_confirm'],
			'CONFIRM_IMG'		=> $confirm_image,
			'L_CONFIRM_EXPLAIN'			=> sprintf($user->lang['CONFIRM_EXPLAIN'], '<a href="mailto:' . htmlspecialchars($config['board_contact']) . '">', '</a>'),
			'L_REG_COND'				=> $l_reg_cond,
			'L_USERNAME_EXPLAIN'		=> sprintf($user->lang[$config['allow_name_chars'] . '_EXPLAIN'], $config['min_name_chars'], $config['max_name_chars']),
			'L_PASSWORD_EXPLAIN'		=> sprintf($user->lang[$config['pass_complex'] . '_EXPLAIN'], $config['min_pass_chars'], $config['max_pass_chars']),
			'S_LANG_OPTIONS'	=> language_select($data['lang']),
			'S_TZ_OPTIONS'		=> tz_select($data['tz']),
			'S_CONFIRM_CODE'	=> ($config['enable_confirm']) ? true : false,
			'S_CONFIRM_REFRESH'	=> ($config['enable_confirm'] && $config['confirm_refresh']) ? true : false,
			'S_COPPA'			=> $coppa,
			'S_HIDDEN_FIELDS'	=> $s_hidden_fields,
			'S_UCP_ACTION'		=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=register'),
		$user->profile_fields = array();
		// Generate profile fields -> Template Block Variable profile_fields
		$cp->generate_profile_fields('register', $user->get_iso_lang_id());
		$this->tpl_name = 'ucp_register';
		$this->page_title = 'UCP_REGISTRATION';
MFG Evolution[/i]
Re: Problem Beim Regestrieren
Diese Datei scheint in Ordnung zu sein. Der Fehler liegt wo anders. Ich weiß aber leider auch nicht wo der Fehler liegt. Wenn der Fehler in Sachen Registrieren erst nach dem Install des Portals aufgetreten ist, dann überprüfe die Dateien gründlich auf falschen oder fehlende Änderungen. Siehe die entsprechenden Install-Anleitungen.
Evolution
Post by Evolution »
das Mit Der Regestrierung,
ist nach der instalation des Portals Aufgetreten,
und jetzt weiß ich nicht, wo ich den fehler suchen soll ;(
MFG
Überprüfe mal diese Dateien und passe diese laut der install.xml an:
  1. root/.htaccess,
  2. root/viewonline.php,
  3. root/includes/constants.php,
  4. root/includes/functions.php,
  5. root/includes/session.php,
Wobei ich vermute das der Fehler eventuell in diesen Dateien liegen könnte:
  • root/includes/constants.php,
  • root/includes/functions.php,
[/color]
Evolution
Post by Evolution »
okay, ich Probiere das mal mit Neatbeans-IDE 6.8 das ist auch Extra Für PHP
und dann melde ich mich nochmal
MFG
