DarkFantasy
DarkFantasy
Style: DarkFantasy
Style Version: 1.0.10
phpBB Version: 3.0.6
Board3Portal Version: 1.0.4 / 1.0.5
Style Download: http://www.gamexe.net/forum/viewtopic.php?f=1&t=1229
Portal Demo: http://area51.mikevil.de/portal.php?style=44
As first you need to download and install this Style. If it works, you can install the Portal for this Style as per description:
to: styles/DarkFantasy/template/portal/*.*
to: styles/DarkFantasy/theme/images/portal/*.*
open: styles/DarkFantasy/template/breadcrumbs.html
find:
			<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> &#187; <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>
in-line find:
in-line add after:
open: styles/DarkFantasy/template/overall_header.html
find:
<div id="content1">
<div id="content2">
<div id="content3">
add after:
find:
	<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --><br /><span style="color: red;">{L_BOARD_DISABLED}</span><!-- ENDIF --></p>
add before:
find:
add after:
find:
	<div id="wrapheader"></div>
add before:
open: styles/DarkFantasy/template/portal/_block_config.html
_block_config.html for DarkFantasy
nach: styles/DarkFantasy/template/portal/*.*
nach: styles/DarkFantasy/theme/images/portal/*.*
öffne: styles/DarkFantasy/template/breadcrumbs.html
finde:
finde in dieser Zeile:
in dieser Zeile danach einfügen:
öffne: styles/DarkFantasy/template/overall_header.html
finde:
<div id="content1">
<div id="content2">
<div id="content3">
danach einfügen:
finde:
davor einfügen:
finde:
danach einfügen:
finde:
davor einfügen:
öffne: styles/DarkFantasy/template/portal/_block_config.html
ersetze mit: (folge dem Link um zum Code zu gelangen)
_block_config.html für DarkFantasy
