Hello
I am trying to install this with Avalon (which I believe is subsilver2 based) but I cant find any of the entries or anything similar in the overall_header.html:
<div id="logodesc">
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --> <span style="color: red;">{L_BOARD_DISABLED}</span><!-- ENDIF -->
<div id="datebar">
<div id="wrapcentre">
Heres what I have:
<head>
<!-- INCLUDE ca_config.html -->
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" />
{META}
<title>{SITENAME} - <!-- IF S_IN_MCP -->{L_MCP} - <!-- ELSEIF S_IN_UCP -->{L_UCP} - <!-- ENDIF -->{PAGE_TITLE}</title>
<!-- IF S_ENABLE_FEEDS -->
<link rel="alternate" type="application/atom+xml" title="{L_FEED} - {SITENAME}" href="{U_FEED}" />
<!-- IF S_ENABLE_FEEDS_TOPICS --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_ALL_TOPICS}" href="{U_FEED}?mode=topics" /><!-- ENDIF -->
<!--[if IE]>
<link rel="stylesheet" type="text/css" href="{T_THEME_PATH}/ie7.css" />
<![endif]-->
// <![CDATA[
var ca_main_width = '{$CA_WIDTH}';
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
window.onload = function()
eval(onload_functions[i]);
window.onunload = function()
eval(onunload_functions[i]);
if(navigator.userAgent && navigator.userAgent.indexOf('Mac OS X') > 0)
document.write('<link rel="stylesheet" href="{T_THEME_PATH}/mac.css" type="text/css" />');
</script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/ca_scripts.js"></script>
</head>
<div id="body">
<a name="top"></a>
<table border="0" cellspacing="0" cellpadding="0" width="{$CA_WIDTH}" id="maintable" align="center">
<td class="row-left" valign="top"><img src="{T_THEME_PATH}/images/row_left_top.gif" width="4" height="100" alt="" /></td>
<td id="header" align="center" valign="top">
<div id="logorow">
<div id="logo-left"><div id="logo-right">
</div></div>
<div class="navrow">
<!-- IF not S_IS_BOT -->
<!-- IF S_USER_LOGGED_IN --><a href="{U_PROFILE}">{L_PROFILE}</a> • <!-- ENDIF -->
<!-- IF S_DISPLAY_PM --><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a> • <!-- ENDIF -->
<!-- ELSEIF S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) --><a href="{U_REGISTER}">{L_REGISTER}</a> • <!-- ENDIF -->
<!-- IF U_RESTORE_PERMISSIONS --><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a> • <!-- ENDIF -->
<a href="{U_FAQ}">{L_FAQ}</a>
<!-- IF S_DISPLAY_SEARCH --> • <a href="{U_SEARCH}">{L_SEARCH}</a><!-- ENDIF -->
<!-- IF S_DISPLAY_MEMBERLIST --> • <a href="{U_MEMBERLIST}">{L_MEMBERLIST}</a><!-- ENDIF -->
<!-- IF not S_IS_BOT --> • <a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a><!-- ENDIF -->
<td class="row-right" valign="top"><img src="{T_THEME_PATH}/images/row_right_top.gif" width="4" height="100" alt="" /></td>
<td class="row-left"><img src="{T_THEME_PATH}/images/spacer.gif" width="4" height="1" alt="" /></td>
<td id="contentrow">
<!-- IF not S_IS_BOT && not $CA_SKIP_PM_NOTIFY && S_USER_LOGGED_IN && S_DISPLAY_PM -->
<!-- IF S_USER_NEW_PRIVMSG -->
<div class="pm-notify-new"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<!-- ELSEIF S_USER_UNREAD_PRIVMSG -->
<div class="pm-notify-unread"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
<!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}<br /><!-- ENDIF -->
<!-- IF S_DISPLAY_SEARCH --><a href="{U_SEARCH_UNANSWERED}">{L_SEARCH_UNANSWERED}</a> | <a href="{U_SEARCH_ACTIVE_TOPICS}">{L_SEARCH_ACTIVE_TOPICS}</a><!-- ENDIF -->
<!-- IF S_DISPLAY_SEARCH and S_USER_LOGGED_IN --><a href="{U_SEARCH_UNREAD}">{L_SEARCH_UNREAD}</a> | <a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a> | <a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a><!-- ENDIF -->
