PhpBB Knowledge Base Mod on board3 Portal
t90
Post by t90 »
PhpBB Knowledge Base Mod block on board3 Portal
Hi there,
I have written a simple block, that accuires article titles from PhpBB Knowledge Base Mod.
Board3 Portal v. 1.0.5
PhpBB Knowledge Base Mod v. 1.0.2RC3
Demo: http://busomania.pl/ (find block titled "Baza wiedzy") on left side column.
Files to be copied:
./root/portal/block/articles.php
./root/styles/prosilver/template/portal/block/articles.html
Files to be edited:
./root/portal.php
./root/styles/prosilver/template/portal/portal_left.html
EDITS:
Open: ./root/portal.php
Find:
if($portal_config['portal_left_column'])
    $template->assign_var('S_LEFT_COLUMN', true);
Add on a new blank line after preceding lines to find:
    include($phpbb_root_path . 'portal/block/articles.' . $phpEx);
Open: ./root/styles/prosilver/template/portal/portal_left.html
Find:
<!-- IF S_DISPLAY_MAINMENU -->
    <!-- INCLUDE portal/block/main_menu.html -->
<!-- ENDIF -->
<!-- IF CAT_LIST -->
    <!-- INCLUDE portal/block/articles.html -->
<!-- ENDIF -->
DIY instructions:
Copy files from attachment, logon to ACP, purge cache. It's done.
Ok, since I can not add any attachments, here is a code for articles.php and articles.html.
Create file "articles.php" on location ./root/portal/block/ of your phpBB3 instalation:
* @package - Board3portal
* @version $Id: articles.php 001 2010-07-23 10:50:43Z t90 $
* @copyright (c) t90 (busomania.pl)
* @based on: phpBB3 Portal by Sevdin Filiz, www.phpbb3portal.com
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
if (!defined('IN_PHPBB') || !defined('IN_PORTAL'))
   exit;
    $sql = "SELECT * FROM `phpbb_articles` ORDER BY `phpbb_articles`.`article_id` ASC";
    $result = mysql_query($sql);
    $i = 0;
        while($row = mysql_fetch_assoc($result))
            $i++;
            $template->assign_block_vars('articles', array(
            'U_TITLE'    => append_sid("{$phpbb_root_path}kb.$phpEx", 'a=' .$row['article_id']),
            'TITLE' => $row['article_title'],
    $cat_list = ($i > 0) ? true : false; //check if there is anything to show
// Assign index specific vars
$template->assign_vars(array(
    'CAT_LIST'                => $cat_list,
Create file "articles.html" on location ./root/styles/prosilver/template/portal/block/ of your phpBB3 instalation:
{$LR_BLOCK_H_L}<img src="{T_THEME_PATH}/images/icon_kb.gif" width="27" height="22" alt="{L_KB_EXPLAIN}">{L_KB}{$LR_BLOCK_H_R}
    <div class="portal-navigation">
        <div class="menutitle">{ILE}</div>
            <ul>
                <!-- BEGIN articles -->
                <li><a href="{articles.U_TITLE}" title="{articles.TITLE}" title="{articles.TITLE}" alt="{articles.TITLE}">{articles.TITLE}</a></li>
                <!-- END articles -->
Now it's done :-)
Je?d??: T3 '86 1.6D (CS) -> 1.7D (KY) -> 1.9TD (AAZ) + 3H
Trzeba my?le? praktycznie, dopóki nie przyjdzie czas, ?e mo?na ju? zacz?? my?le? niepraktycznie.
busomania.pl
amka
Re: PhpBB Knowledge Base Mod on board3 Portal
Post by amka »
hello!
Tell me how to do that in the block displays the category of "PhpBB Knowledge Base Mod"
P.S. Sorry for my bad English!
t90
Post by t90 »
amka wrote:hello!
It's all there. You need to edit portal.php and left_side_column.html. I have described all steps on first post. After you complete file modifications, you will have to clear cache.
Block is not perfect, but it works. Updated code for articles.php would be:
   exit;
    $sql = "SELECT * FROM `phpbb_articles` WHERE `article_status` = 1 ORDER BY `phpbb_articles`.`article_id` ASC";
    $i = 0;
            $i++;
This way only approved articles will be shown.
busomania.pl
vonhazey
phpBB.com User: vonhazey
Post by vonhazey »
nice how do i limit how many it shows as i have a mega long list and only want 5
Image Image
t90
Post by t90 »
vonhazey wrote:nice how do i limit how many it shows as i have a mega long list and only want 5
This one will give 5 random articles ...
   exit;
    $sql = "SELECT * FROM `phpbb_articles` ORDER BY RAND() LIMIT 5";
    $i = 0;
            $i++;
If you wish to have more (or less) results just find:
and change "LIMIT 5" to "LIMIT X" where "X" is your desired number of articles to be shown within a block.
busomania.pl
obiewan
phpBB.com User: obiewan
Post by obiewan »
Correct me if i'm wrong; you can only display the articles when you display the forumlist in the portal?
I just tried the block.. and nothing is shown, because i do not want the forumlist to be seen in the portal.
t90
Post by t90 »
Well, it has nothing to forum lists. Anyway, I have checked, and knowledge base mod block is shown both, forum lists enabled or disabled.
busomania.pl
obiewan
Post by obiewan »
Ok, thanks :D
