Supernova Block Config need
Khamosh-Saya
phpBB.de User: Khamosh-Saya
phpBB.com User: Khamosh-Saya
Post by Khamosh-Saya »
Supernova Block config need
Thanks in advance
Re: Supernova Block Config need
Hello,
install as prosilver, except the overall_header.html.
Only works without Forum Index.
Since the graphics in supernova / theme / images / blue / ... and in .... / Green / and ... / red /
not allow it!
Forum Index ACP in the portal off.
For all other edits please take a look at: board3_Portal_105/install.xml .
>See here<
Khamosh-Saya
Right And Left Block is not perfect
mean like Its borders are not Rounder u can see live
www.friendzsociety.com
Sorry for the error. :oops:
The error was corrected. ;)
Please check again the instructions for the style.
Khamosh-Saya
Thanks Archiver its working
i have Problem
Username and password Area is out of the block :S
in IE8
Google Chorme working fine
The ACP-Mod Portal Enable PHP menu.
Khamosh-Saya
sorry i didnot understand :S
archivar wrote:The ACP-Mod Portal Enable PHP menu.
Look here:acp_demo/en/
Khamosh-Saya wrote:Thanks Archiver its working
i have Problem
in IE8
I hope to finally know what you want. :)
Left and right column width settings
Width of the left column:
Change the width of the left column in pixels; recommended value is 180
Width of the right column:
Change the width of the right column in pixels; recommended value is 180
change:
Width of the left column: 210
Width of the right column: 190
Return to “Config requests”
