Gallery block not showing after update
bc2005
Your Portal Version: 1.0.6
Boardlink: http://www.bonsaicafe.be
Updated to Board3 Portal from 1.0.5 tot 1.0.6
Purged cache, Checked the Gallery Block configuration.
After updating my Board3 Portal from 1.0.5 to 1.0.6, my Gallery Block (1.4.1) on the Portal isn't there anymore. I did refresh everything and purged my cahe, so I am a bit confused now. What should I do to get my Gallery Block working again?
Re: Gallery block not showing after update
Hi,bc2005 wrote: Boardlink: http://www.bonsaicafe.be
Please check again:
portal / block / additional_blocks.php,
styles / prosilver / template / portal / block / additional_blocks_center.html,
styles / prosilver / template / portal / block / additional_blocks_right.html
Refresh your Styles:
bc2005
OK Thanks, found the problem...
novanilla
I've had an identical problem. I've been running 3.08 and Gallery 1.05 for a long time. Finally got around to updating Board3 Portal to 1.06, and my gallery blocks have disappeared. I've verified the existence of these files:
And checked that the blocks are enabled in the portal's acp. The themes, images, templates have had their caches cleared many times, and purged the cache many times as well, as I've been troubleshooting other issues.
Any ideas?
Any ideas?
A link to your board would be helpful.
novanilla
sorry... www.nova-nilla.com/Members/phpBB3/
It's a private board, so I don't know how much you can get from this. Let me know if you need me to pm you a test login.
Thanks in advance.
Thanks in advance.
Check the installation instructions for the "gallery-block ".
novanilla
Ah. Much thanks. I forgot there were such things in an update. I'll get back tomorrow and let you know if that worked.
novanilla
No joy... I've gone through the instructions for the old gallery block for the portal, and can't find anything that's missing in my files. I have the portal configured to show a row of random images in the center, and a block of recent images on the right. I've made the appropriate changes to the directions (switching instances of "left" with "right"), and the blocks simply do not show up in my portal.
EDIT:
I found THIS line in my additional_blocks.php file:
I'm not sure why this was changed to this, but it was supposed to be:
So I changed it, and that fixed it. Except I can't seem to use the small gallery block on the right hand side, it expands to mimic the center gallery block.
EDIT:
if (!defined('IN_PHPBB') || !defined('IN_PORTAL'))Code: Select all
if (!defined('IN_PORTAL'))
exit;
}Tip: Add these lines on a new blank line after the preceding line(s) to find.
if(!function_exists('recent_gallery_images'))
include($phpbb_root_path . 'portal/block/gallery.'.$phpEx);
} V.G. archivar
novanilla
This works for me now, Archivar. Thank you for your help.
bc2005
HI, this week I wanted to update my phpbb gallery from 1.06 to 1.1.4. But it seems it isn't compatible with the Gallery Block 1.4.1 addon. Halfway the update i got some problems. ( http://www.flying-bits.org/viewtopic.php?f=105&t=3270 ) Nick advised me to uninstall the Gallery Block 1.4.1 addon. Can someone tell me the best way to do this?
Thx,
Hans
Thx,
Hans
userxy
Same Problem here
Try`d to update Gallery from 1.0.6 >1.1.1 and i got error messages conflicting with "recent_gallery_images" on Index.php and Portal.php
The Problem seems to be the Gallery-Portal-Mod that is incompatible with new Gallery versions. They say to uninstall Portal-Gallery-Mod.
Any Howto out there to uninstall clean from Portal?
bc2005
Well, I tried it this way: I removed all the changes I had to make in the install procedure of Gallery Block 1.4.1, reloaded the files, and purged my cache. Now everything works like it should, alas without the Gallery Blocks add-on. I presume I have to install a newer version now, and probably also update my board to Board3 2.0.1...
[REL] Gallery Block 1.4.1
[REL] Gallery Block 1.4.2Addon-Requirements: board3 Portal v1.0.4 and Gallery by nickvergessen v1.0.0
[Release] Addon for phpBB Gallery 1.1.2+ for B3P v. 2.0.b1Addon-Requirements: board3 Portal v1.0.6 and phpBB Gallery by nickvergessen v1.0.5 or 1.0.5.1
Addon Requirements: Board3 Portal 2.0.0b1 and newer and phpBB Gallery 1.1.2+ by nickvergessen
