Your phpBB Type: other phpBB Distribution
Boardlink: http://remixpromotions.net
Installed Portal (board3)
Nothing, want something to know..
Hello,,
I have installed board3 at my board.
But when i see the donation (paypal) setting. I cant change the settings.
Is it possible to set alreadt some amounts, instead you can donate what you want?
Thanks in advance,,,
Donation system ?
djbosanac
- phpBB.com User: djbosanac
djbosanac
Re: Donation system ?
nobody of the designers can fix it for me???
abendrise
This MOD should install with AutoMOD without any issues. You will need to run the installer afterwards, but AutoMOD will link you to that. You only need manual steps if some edits couldn't be found, i.e. if a MOD already edited that part of the code. If you edited your template/theme/imageset in the ACP, then refreshing your theme/template/imageset will remove those changes. That's why you should always edit the files and not the cached versions in the ACP.
