[Release] mChat Block for Board3 Portal 2.0.0
Addon: mChat Block
Addon Version: 1.1.0
Addon Author: Marc Alexander
Addon Description:
Adds an mChat window to your portal page.
Addon Requirements: Board3 Portal 2.0.0 and newer and mChat 1.3.5 by RMcGirr83
Download:
b3p_mchat_block_110.zip
(12.69 KiB) Downloaded 4723 times
Instructions:
Upload the module package via the ACP or just upload the content of the ZIP-File into the root of your forum.
Lade das Modul Paket über den Admin-Bereich hoch oder lade den Inhalt der ZIP-Datei in das Hauptverzeichnis deines Forums.
Updates:
19th May 2011: Added missing <br /> in prosilver
Hans
phpBB.de User: Hans
phpBB.com User: Hans
Re: [Release] mChat Block for Board3 Portal 2.0.0b1
Post by Hans »
./styles/prosilver/template/mchat_body.html does not exist
No, you are missing mChat:
Marc wrote: Addon Requirements: Board3 Portal 2.0.0b1 and newer and mChat 1.3.5 by RMcGirr83
DIYBear
phpBB.com User: MightySapphire
Post by DIYBear »
I cannot get the mChat module to upload. I get the error message:
Information
The module you are trying to upload seems to be corrupted.
I am running Board3 2.0.0b1 on phpBB 3.0.9 and have downloaded a brand new copy of the mChat 1.3.5.zip from the phpBB page.
Any idea why the portal thinks it is corrupted? Can it not auto-install mChat?
EDIT:
Post postponed because the wrong place.
Greeting archivar
MetalMarine
phpBB.de User: MetalMarine
phpBB.com User: MetalMarine
Post by MetalMarine »
DIYBear wrote:I cannot get the mChat module to upload. I get the error message:
Information
I installed it with no problems. using the .zip file from these forums. viewtopic.php?f=54&t=4577
my website http://www.triplexclan.com
EDIT:
Greeting archivar
Armgaming
Post by Armgaming »
I have tried to install from zip list in this post and I get this:
template->_tpl_load_file(): File ./styles/X-Treme/template/portal/modules/mchat_center.html does not exist or is empty
Armgaming wrote:I have tried to install from zip list in this post and I get this:
Copy the appropriate files in the style.
Your style X-Treme is subsilver basis.
Take this subsilver the files from the download package.
Hexaglo
Post by Hexaglo »
Hallo ist es auch möglich die Box im Portal nach rechts zu verschieben?
Über dem Portal sieht das ziemlich fehl am Platz aus!
Du kannst die Box auch in die Mittee schieben oder auch nach unten. Auf der rechten Seite ist meiner Meinung nach zu wenig Platz für den Block.
Avis
Post by Avis »
Tell how to make a chat not in the central column, and in right?
Avis
Post by Avis »
I have found the decision
Search in forum/portal/modules/portal_mchat.php
		global $config, $template, $phpbb_root_path, $phpEx, $auth, $user, $cache, $db;
		if(!defined('MCHAT_INCLUDE'))
			define('MCHAT_INCLUDE', true);
		if(!function_exists('mchat_cache') && !empty($config['mchat_enable']) && $auth->acl_get('u_mchat_view'))
			$mchat_include_index = true;
			include($phpbb_root_path . 'mchat.' . $phpEx);
		return 'mchat_center.html';
Replace:
		return 'mchat_side.html';
/forum/styles/subsilver2/template/portal/modules/mchat_center.html
rename: mchat_side.html
Armgaming
Post by Armgaming »
Information
EDIT:
Greeting archivar
I have tried both and I keep getting the same message, mchat works just fine on my index page. I just get that message when I try to install to a portal module. Everything used to work just fine this way until I had to redo my forums do to an admin deleting the root.
Here is a link: http://armgaming.net
Armgaming
Post by Armgaming »
I am really not trying to flame but is there but is there anyone here that helps resolve these issues, I understand this is a free based mod and have no problem donating. I am just curious why everything worked prior and now on a new install it tells me every module is corrupted?
MyLady
Sponsor
phpBB.de User: Scanialady
phpBB.com User: Scanialady
Post by MyLady »
have a look to the chmod of module files on your server - may be, they are read protected. Set them to 644 if it is so.
Ich gehe mal davon aus, dass Gäste nicht die nötigen Rechte haben den mChat zu sehen.
