Calendar block for phpBB Calendar 0.0.8
frold
Portal Enthusiast
Re: Calendar block for phpBB Calendar 0.0.7
Post by frold »
fred_du_41 wrote:Thank you for your answer :D
frold wrote: Did you install the phpBB Calendar mod from: http://www.phpbb.com/community/viewtopi ... 0&t=666195
Yes naturally, I always install mods from phpBB.com only
I do not understand why that does not work for me :?
it seems like you are using a frensh lang package - did you add the lang changes to you frensh lang
/fr/common.php
frold
Portal Enthusiast
Post by frold »
fred_du_41 wrote: But after the install i have a little problem, at the top of my portal there is this error :?
[phpBB Debug] PHP Notice: in file /includes/functions_calendar.php on line 1922: Undefined index: WEEK
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3656: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2989)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3658: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2989)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3659: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2989)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3660: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2989)
I am very sorry! It seems like there was some missing lang variable for the calender.... Please update language/fr/common.php or language/en/common.php with the new code strip...
I did update the first post!
//Missing lang variables
$lang['MONTH'] = 'Month';
$lang['WEEK'] = 'Week';
$lang['DAY'] = 'Day';
fred_du_41
Translator
Post by fred_du_41 »
frold wrote: it seems like you are using a frensh lang package - did you add the lang changes to you frensh lang
/fr/common.php
Yes I added this at the end ;)
My /fr/common.php
 // Event Calendar
       'CALENDAR'      => 'Agenda',
       // minical short day names
       'mini_datetime'   => array(
            'Su'      => 'Lu',
            'Mo'      => 'Ma',
            'Tu'      => 'Me',
            'We'      => 'Je',
            'Th'      => 'Ve',
            'Fr'      => 'Sa',
            'Sa'      => 'Di',
La Passion du Reflex Numérique : ?Photos-entre-Amis ?Annuaire ? Mon Flickr ?
frold
Portal Enthusiast
Post by frold »
fred_du_41 wrote:
My /fr/common.php
 // Event Calendar
            'Su'      => 'Lu',
            'Mo'      => 'Ma',
            'Tu'      => 'Me',
            'We'      => 'Je',
            'Th'      => 'Ve',
            'Fr'      => 'Sa',
            'Sa'      => 'Di',
Before that part please add:
fred_du_41
Translator
Re: Calendar block for phpBB Calendar 0.0.7 (fixed version)
That's good now :D
Thank's a lot ;)
frold
Portal Enthusiast
Post by frold »
fred_du_41 wrote:That's good now :D
Thank's a lot ;)
Im glad it work for you also :D
CocoVFR
Post by CocoVFR »
frold wrote:
CocoVFR wrote:An other question.
How can i make enable/disable the calendar (not mini_cal) in the ACP ?
You are not able to do so - this is a dirty hack :D
I think i've done this, but if someone can say if i am totally right. (i'm a noob in phpbb and modding, but i know well php. This snippets work well for me, so...)
So, that's i have done:
First, i've apply the snippets from frold (in first post).
In adm/acp/info/acp_portal.php
After:
'minicalendar'	=> array('title' => 'ACP_PORTAL_MINICALENDAR_INFO', 'auth' => 'acl_a_board', 'cat' => array('ACP_BOARD_CONFIGURATION')),
add:
'calendarevent'	=> array('title' => 'ACP_PORTAL_CALENDAR_EVENT_INFO', 'auth' => 'acl_a_board', 'cat' => array('ACP_BOARD_CONFIGURATION')),
In Langage/fr/Mods/lang_portal_acp.php
After
'PORTAL_VIEW_PERS_ALBUMS'				=> 'Voir les images des albums personnels ?',
Add
'ACP_PORTAL_CALENDAR_EVENT_INFO'		=> 'Calendrier des evenements',
'ACP_PORTAL_CALENDAR_EVENT_SETTINGS'	=> 'Parametres du calendrier des evenements',
'PORTAL_CALENDAR_EVENT'					=> 'Afficher ce bloc sur le portail',
'MINI_CAL_CALENDAR'						=> 'Calendrier evenement',
In include/acp/acp_portal.php
After
case 'minicalendar':
		$display_vars = array(
				'title'	=> 'ACP_PORTAL_MINICALENDAR_SETTINGS',
				'vars'	=> array(
					'legend1'							=> 'ACP_PORTAL_MINICALENDAR_SETTINGS',
					'portal_minicalendar'				=> array('lang' => 'PORTAL_MINICALENDAR'					 ,	'validate' => 'bool',	 'type' => 'radio:yes_no',	'explain' => true),
					'portal_minicalendar_today_color'	=> array('lang' => 'PORTAL_MINICALENDAR_TODAY_COLOR'	 ,	'validate' => 'string', 'type' => 'text:10:10',	 'explain' => true),
					'portal_minicalendar_day_link_color'	=> array('lang' => 'PORTAL_MINICALENDAR_DAY_LINK_COLOR' ,	'validate' => 'string', 'type' => 'text:10:10',	 'explain' => true),
		break;
Add
case 'calendarevent':
			'title'	=> 'ACP_PORTAL_CALENDAR_EVENT_SETTINGS',
			'vars'	=> array(
				'legend1'							=> 'ACP_PORTAL_CALENDAR_EVENT_SETTINGS',
				'portal_calendar_event'				=> array('lang' => 'PORTAL_CALENDAR_EVENT'					 ,	'validate' => 'bool',	 'type' => 'radio:yes_no',	'explain' => true),
		break;
In root/Portal.php
After
if ($portal_config['portal_change_style'])
	include($phpbb_root_path . 'portal/block/change_style.'.$phpEx);
ADD
if ($portal_config['portal_calendar_event'])
	include($phpbb_root_path . 'portal/block/calendar.'.$phpEx);
In root/portal/block/calendar.php
AFTER
'U_CALENDAR'   => append_sid("{$phpbb_root_path}calendar.$phpEx"),
ADD
'S_DISPLAY_CALENDAR_EVENT' => true,
In root/styles/prosilver/template/portal/portal_body.html
ADD
	<!-- IF S_DISPLAY_CALENDAR_EVENT -->
		<!-- INCLUDE portal/block/calendar.html -->
In where you want your block appear. (right block, left bloc or center block
In your database, execute this sql query:
INSERT INTO xxxxx_portal_config VALUES("portal_calendar_event","1");
where xxxxx is the extension of your phpbb database table.
Go to ACP, and add a new module in portal bloc settings, and add "ACP_PORTAL_CALENDAR_EVENT_INFO" module.
That's all.
Now, in your ACP, you can display or not the "calendar event".
Any comment ? It's works for me, but perhaps, i've make some error, and/or i've forget someting ?
frold
Portal Enthusiast
Post by frold »
it seems right ;-)
thomas.d
phpBB.de User: thomas.d
phpBB.com User: thomas.d
Post by thomas.d »
Another dirty hack:
Since my topic event icons are of different sizes and they looked a bit weired I changed in
styles/prosilver/template/portal/block/calendar.html
<!-- IF mini_calendar_days.events.IMAGE --><img src="{mini_calendar_days.events.IMAGE}" title="{mini_calendar_days.events.ETYPE_DISPLAY_NAME}" height="20" width="20" /><!-- ENDIF -->
to
<!-- IF mini_calendar_days.events.IMAGE --><img src="{mini_calendar_days.events.IMAGE}" title="{mini_calendar_days.events.ETYPE_DISPLAY_NAME}" height="" width="" /><!-- ENDIF -->
(empty "height" and "width", may be this is not XHTML 1.0 Strict anymore ...)
Since birthdays are displayed in a portal block this snippet here does not show them. But it creates a <hr> if a birthday occures. So I changed in
<!-- BEGIN mini_calendar_days -->
      <!-- BEGIN events -->
      <!-- IF mini_calendar_days.events.S_FIRST_ROW -->
      <!-- IF mini_calendar_days.BIRTHDAYS --><hr><!-- ENDIF -->
      <!-- ELSE --><hr><!-- ENDIF -->
to
So it does not mind birthdays anymore and this way the events are grouped by the day of occurence with a line break after each group, e.g.
[10] Meeting
[10] Another Meeting
[11] One more Meeting
[12] What the hell another Meeting
[12] I can't stand it ...
[12] Last Meeting
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
derkubi
Portal Enthusiast
Post by derkubi »
Is there a block for subsilver ?
frold
Portal Enthusiast
Post by frold »
derkubi wrote:Is there a block for subsilver ?
I havent made one....
But I guess you can use the code and easy edit it to fit subsilver...
derkubi
Portal Enthusiast
Post by derkubi »
when i copy all the prosilver files to x-static ( subsilver ) and edit the x-static files i see the calendar , but without a frame :
frold
Portal Enthusiast
Post by frold »
Sry, due to lack of time I dont have time to support other templates then prosilver
tomcon
Post by tomcon »
@frold: woul you be so kind to post the following code of your Poratl:
1. actual themes: the last poster is on the right side ...that looks good
2. the registertabs on your actual themes are linked to differnt forum?
thx a lot+
tomcon
tomcon
frold
Portal Enthusiast
Post by frold »
tomcon wrote: 1. actual themes: the last poster is on the right side ...that looks good
Thats because I use a old version of Board3 portal - I use the second latest version. I never did a upgrade....
The tab based block with "Alle", "Studmed", "Candmed".....?
If so its a hardcode hacked version of the news compacted block- If I get time tonight I can share it but its very ugly code, so ppl need to hardcode the forums from where the latest post are taken....
