Calendar block for phpBB Calendar 0.0.8
Re: Calendar block for phpBB Calendar 0.0.8
derkubi wrote:2. Can i change the date from [1.4] to [4.1.2009] or [4.Jan.2009]?
Other way round this should be the solution: viewtopic.php?p=7870#p7870
wang5555
Translator
phpBB.com User: wang5555
Post by wang5555 »
derkubi wrote:Hello
Two questions :
1. Under style BF-VISTA the block is transparent .
1. Please paste style BF-VISTA download link.
2. Try it:
#-----[ OPEN ]-----
includes/functions_calendar.php
#-----[ FIND ]-----
            $event_output['NUMBER'] = $dayOfEvent["mon"].".".$dayOfEvent["mday"]."";
#-----[ REPLACE WITH ]-----
            $event_output['NUMBER'] = $dayOfEvent["mday"].".".$dayOfEvent["mon"].".".$dayOfEvent["year"]."";
#-----[ SAVE & CLOSE ]-----
It is more blessed to give than to reveive, welcome to letter, thanks & good-bye!
Good luck ^_^
Welcome to visit my forum!!
https://wang5555.dnsfor.me/phpBB3/
p.s. Shut down computer before 11 clock night!!!
derkubi
Portal Enthusiast
Post by derkubi »
ty , works fine .....
You can find BF-Vista here : http://www.phpbb.com/community/viewtopi ... b5da2c1a74 , but i am using the 3.0.0 version
Here are 2 links :
original board3portal minical-block without transparency
http://dienstagstruppe.pytalhost.com/we ... lendar.txt
and the calendar0.0.8 portal block with transparency
think you need only these two files to help ....
wang5555
Translator
Post by wang5555 »
derkubi wrote:ty , works fine .....
Here are 2 links :
Try it--Add class="row2":
#-----[ OPEN ]-----
styles/YOUR_THEME/template/portal/block/calendar.html
#-----[ FIND ]-----
<table class="tablebg" cellspacing="1" cellpadding="0" width="100%">
            <td align="left" colspan="2"><!-- IF CALENDAR_PREV_MINI -->{CALENDAR_PREV_MINI}</a><!-- ENDIF --></td>
            <td colspan="3" align="center"><span class="genmed">{CALENDAR_HEADER_MINI}</span></td>
            <td align="right" colspan="2"><!-- IF CALENDAR_NEXT_MINI -->{CALENDAR_NEXT_MINI}</a><!-- ENDIF --></td>
#-----[ RPLACE WITH ]-----
         <tr class="row2">
#-----[ FIND ]-----
  <!-- BEGIN mini_calendar_days -->
  <!-- IF mini_calendar_days.START_WEEK -->
  <tr class="row2">
P.S.
Purge the cache.
Good luck ^_^
derkubi
Portal Enthusiast
Post by derkubi »
Ty wang , perfect ...
sloeri
Post by sloeri »
Hey Guys,
For some reason events are not shown in the calendar...
(i have the Calendar mod 0.0.8 yes... :) i have done the required options for the block... added it to the portal and it is showing correct...)
when i click on it, the calendar indeed opens... (correct month etc...)
only thing not showing is the events i added to the calendar..
where could i have gone wrong ?
edit : The link where it should say "Calendar" also shows as { MINI_CAL_CALENDAR } ...???
EDIT 2 : GOT IT WORKING ;) i made a mistake... duh :)
Regards
Joeri
Onetimer
Post by Onetimer »
If I disable the default Board3 mini calendar (which anyone who installs this mod would obviously do) the name in the block header changes from Calendar to { MINI_CAL_CALENDAR }. But if I enable the mini calendar both have the Calender name displayed. Is this a bug or have I made a mistake somewhere?
*EDIT* Solved it by the fix posted below */EDIT*
Onetimer
Post by Onetimer »
Calendar 0.0.8 block and Mini Calander block seem to both use the same L_MINI_CAL_CALENDAR, right? The Calendar 0.0.8 block should have used the L_CALENDAR tag instead, I think?
I solved the above problem by exchanging the two instances of L_MINI_CAL_CALENDAR to L_CALENDAR in calendar.html.
Joschi
Post by Joschi »
hallo,
kann jemand die zum Einbinden des Blocks benötigten Daten mal zusammen fassen?
Es sind mittlerweile so viele Fragen/Probleme hier drin dass ich nicht mehr durchblicke.......
Danke
Joschi
Post by Joschi »
hmmm...... schade eigentlich........ :?
Grüße
steppe
Post by steppe »
Hallo!
Bei mir werden Termine im Block nicht angezeigt, wenn sie nicht im aktuellen Monat stattfinden. Sprich, jetzt ist Januar und ein Termin im Juni wird nicht angezeigt. Wenn ich mich bis Juni vorarbeite, wird dann auch der Termin angezeigt. Wie kann man das ändern?
Gruß Steppe
mk1200
phpBB.com User: mk1200
Post by mk1200 »
Nice work on this one guys.
JeRicHoOL
Post by JeRicHoOL »
I installed this block and all days look the same. Is there a ways to have the current day in another color or something like this, so people can see which day it is? (proSilver)
Thanks in advance.
amroth
Post by amroth »
Ich finde die Datei
absolut nicht die gibts bei mir einfach nicht -.- und nu ?
www.religions-of-azeroth.de
< Wir Suchen GM's | Scripter / Bugfixxer | Foren Moderatoren | Foren Designer >
Hast du dir auch den phpBB Calendar 0.0.8 runtergeladen? Den brauchst du nähmlich.
Denke aber mal eher nicht, ok gibs zu regulär geht es eh schlecht da phpBB.com Down ist, wenn man kein Trick 17 anwendet. :lol:
Download wäre jedenfalls http://www.phpbb.com/index.php?f=70&t=666195 gewesen.
Da aber derzeit Down ist hab ich mit Trick 17 mal die Cache-Version genommen.
Und sehe da, der Download-Link des Kalender gefunden: http://phpbbcalendar.com/downloads/phpbb_Calendar.zip :lol:
Gruß Chris
