2.0.0 Portal bloc
arshess
2.0.0 Portal bloc
Post by arshess »
Hi everybody,
I have a problem with my portal.
I copied the archive files on my Server and I did the following step. It looked ok but by opening the internet page I saw that: http://dissidia.guild-heberg.fr/
Have you go a piece of advice or a solution to this problem.
With all my thankfulness.
ps: Sorry for my bad english :? .
Re: 2.0.0 Portal bloc
Please check all the files you edited or uploaded. Also check if you uploaded all language files correctly.
arshess
Post by arshess »
i have uploaded all the files in the .zip and i have modified once and check the modification once more.
I have copied all files in intall_fr.zip ( http://board3.de/viewtopic.php?f=55&t=4670 ) on the file board3 before uploading it on my ftp
arshess
Post by arshess »
another idea plz ?
i'm stuck by this problem for my guild website
anywhere91
Translator
phpBB.com User: Anywhere91
Post by anywhere91 »
I'll double-check the translation files this weekend
Regards
Bonjour / Soir
Je vais revérifier les fichiers de traduction ce weekend
Cordialement
