Milky Way (Base: subsilver2)
Style: Milky Way
Style Version: 1.6.8
Style Download: http://www.phpbb.com/customise/db/style/milky_way/
to: root/styles/milky_way/template/portal/*.*
to: root/styles/milky_way/theme/images/portal/*.*
open: root/styles/milky_way/template/breadcrumbs.html
<!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a>&nbsp;&#187;&nbsp;<!-- ENDIF -->
open: root/styles/milky_way/template/breadcrumbs_footer.html
open: root/styles/milky_way/template/breadcrumbs_pages.html
open: root/styles/milky_way/template/menu_block.html
<a href="{U_INDEX}">{L_FORUM}</a>
<!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a>&nbsp; <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" />&nbsp; <!-- ENDIF -->
open: root/styles/milky_way/template/overall_header.html
<!-- INCLUDE menu_block.html -->
open: root/styles/milky_way/template/portal/modules/forumlist.html
Find and Delete
Tip: Find and delete this code.
<!-- IF S_DISPLAY_SEARCH or (S_USER_LOGGED_IN and not S_IS_BOT) -->
	<!-- IF S_DISPLAY_SEARCH -->
	<p class="searchbar">
		<!-- IF S_USER_LOGGED_IN or S_LOAD_UNREADS -->
		<span style="float: {S_CONTENT_FLOW_END};"><!-- IF S_LOAD_UNREADS --><a href="{U_SEARCH_UNREAD}">{L_SEARCH_UNREAD}</a><!-- IF S_USER_LOGGED_IN --> | <!-- ENDIF --><!-- ENDIF --><!-- IF S_USER_LOGGED_IN --><a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a> | <a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a><!-- ENDIF --></span>
	</p>
open: root/styles/milky_way/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div><div class="tbl-h-l" style="padding-left: 5px"><div class="tbl-h-r"><div class="tbl-h-c"><div class="tbl-title"><span style="float: left">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</span></div></div></div></div>' -->
<!-- DEFINE $LR_BLOCK_F_L = '<div class="tbl-f-l"><div class="tbl-f-r"><div class="tbl-f-c">' -->
<!-- DEFINE $LR_BLOCK_F_R = '</div></div></div></div><br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div><div class="tbl-h-l"><div class="tbl-h-r"><div class="tbl-h-c"><div class="tbl-title"><span style="text-align: center">' -->
<!-- DEFINE $C_BLOCK_H_R = '</span></div></div></div></div>' -->
<!-- DEFINE $C_BLOCK_F_L = '<div class="tbl-f-l"><div class="tbl-f-r"><div class="tbl-f-c">' -->
<!-- DEFINE $C_BLOCK_F_R = '</div></div></div></div><br style="clear:both" />' -->
<!-- DEFINE $WHOS_IMAGES = '/images/online.png' -->
nach: root/styles/milky_way/template/portal/*.*
nach: root/styles/milky_way/theme/images/portal/*.*
Öffne: root/styles/milky_way/template/breadcrumbs.html
Öffne: root/styles/milky_way/template/breadcrumbs_footer.html
Öffne: root/styles/milky_way/template/breadcrumbs_pages.html
Öffne: root/styles/milky_way/template/menu_block.html
Öffne: root/styles/milky_way/template/overall_header.html
Öffne: root/styles/milky_way/template/portal/modules/forumlist.html
Finde und entferne
Tip: Finde und entferne diesen Code.
	</p>
Öffne: root/styles/milky_way/template/portal/_block_config.html
