[Release] Random Post for B3P v2.0.0b1
Nekstati
phpBB.com User: Nekstati
Post by Nekstati »
Addon: Random Post
Addon Version: 1.0.0
Addon Author: Nekstati
Addon Description:
Displays a random post from defined topic (or several topics). Can be used e. g. to display a random quotations or random anecdotes.
Addon Requirements: Board3 Portal 2.0.0b1 and newer.
Download Link is here: http://www.phpbbguru.net/community/topic36557.html.
Note: Prosilver only.
Instructions:
2. Add new module into center, left or right column of the portal (ACP > MODS > Portal > Portal Modules).
Screenshots:
Crocodile
phpBB.com User: Crocodile442
Re: [Release] Random Post for B3P v2.0.0b1
Post by Crocodile »
Just a suggestion here. It would be more useful if we could pull posts from selected forums, also a link to the post only shows if the random post is shortened by the minimum text length, it would be better if the link was a constant.
Otherwise nice module, thanks.
giardiniere
Post by giardiniere »
Crocodile wrote:Just a suggestion here. It would be more useful if we could pull posts from selected forums, also a link to the post only shows if the random post is shortened by the minimum text length, it would be better if the link was a constant.
+1
Great module. Thanks :) I've tried to put two blocks (on the right side and on the center) but the random posts shown are the same. Is it possible to have differents random posts?
And what about "Random topic"?
noth
phpBB.com User: noth
Post by noth »
this is a great addition for a portal, very nice!! :D
Enter here an ID of one topic, or IDs of several topics, separated by comma. 0 = show messages from all topics.
does using 0 place a great load onto the forums? when I insert 0 the response takes 5 - 10 seconds to load the portal, sometimes 20 seconds! without 0 it takes 1 or 2 seconds
0 seems to place a huge ton of resources looking for topics or something, it slows the portal down to slow motion, 0 setting NOT RECOMMENDED
SubSilver2 - randompost_side
  {$LR_BLOCK_H_L}{$TITLE}{$LR_BLOCK_H_R}
		<td class="row1" rowspan="2" align="center" valign="middle">
<!-- IF S_RNDP_NO_POSTS -->
	{L_NO_MESSAGES}
	<!-- IF RNDP_AUTHOR --><p class="author" style="margin: 0 0 0.6em 0"><a href="{U_RNDP_POST}"><img src="{T_IMAGESET_PATH}/icon_post_target.gif" alt="" title="{L_POST}" /></a> {RNDP_AUTHOR} &raquo; {RNDP_TIME}</p><!-- ENDIF -->
	<div class="content" style="white-space: normal !important; word-wrap: break-word !important">{RNDP_TEXT}</div>
	<hr style="clear: both" />
	<form style="clear: both" action="{U_RNDP_NEXT}" method="post"><fieldset><!-- IF RNDP_STRIPPED --><a href="{U_RNDP_POST}">{L_RNDP_FULL}</a><!-- ENDIF --><input type="submit" class="button2" name="" value="{L_NEXT}" style="float: right" /></fieldset></form>
SubSilver2 - randompost_center
		<td class="row1"  valign="middle">
	{L_NO_MESSAGES}
	<!-- IF RNDP_AUTHOR --><p class="author"><a href="{U_RNDP_POST}"><img src="{T_IMAGESET_PATH}/icon_post_target.gif" alt="" title="{L_POST}" /></a> {RNDP_AUTHOR} &raquo; {RNDP_TIME}</p><!-- ENDIF -->
	<div class="content"><span style="font-size:medium;">{RNDP_TEXT}</span></div>
{$C_BLOCK_F_L}{$C_BLOCK_F_R}
giardiniere wrote: I've tried to put two blocks (on the right side and on the center) but the random posts shown are the same. Is it possible to have differents random posts?
I think random post is better than Random Topic, much better but giardiniere does have a point, being able to have "Random Posts" maybe 1 either side of the centre, on top of that ..... being able to have "Random Member" maybe 1 either side of the centre but as giardiniere has alluded, it's no good if the block is just a duplicate, the content needs to display different posts/ members :D
crustyz
Post by crustyz »
if anyone has figured out how to resize images?
