The MCP info on index modification adds a red box to the index when there are reported or unapproved posts (and how many). So you don't have to check the MCP everytime and you will see reports and unapproved posts faster.
It would be nice to have a module in the portal displaying this information as well.
MCP info module in portal
cpg
- Sponsor
- phpBB.de User: cpg
Re: MCP info module in portal
So???
First you have to install MCP info on index
And than:
In styles/prosilver/portal/modules/user_menu_side.html
CPG
And than:
Best regards<!-- IF U_UM_MCP -->
<li><a href="{U_UM_MCP}">{L_MCP}</a><!-- IF TOTAL_MODERATOR_REPORTS --> <a href="{U_MODERATOR_REPORTS}">{TOTAL_MODERATOR_REPORTS}</a><!-- ENDIF --><!-- IF TOTAL_MODERATOR_POSTS --> <a href="{U_MODERATOR_APPROVE_POSTS}">{TOTAL_MODERATOR_POSTS}</a><!-- ENDIF --><!-- IF TOTAL_MODERATOR_TOPICS --> <a href="{U_MODERATOR_APPROVE_TOPICS}">{TOTAL_MODERATOR_TOPICS}</a><!-- ENDIF --><!-- IF TOTAL_MODERATOR_PMS --> <a href="{U_MODERATOR_PMS}">{TOTAL_MODERATOR_PMS}</a><!-- ENDIF --></li>
CPG
Somehow the mod isn't showing anything (there are unapproved posts in the queue) at the moment. Even on the index which was working before I upgraded from portal 1.0.6 to 2.0.0
Any ideas?
Any ideas?
cpg
- Sponsor
did you follow all points of the instructions of MCP info on index?
Best regards
CPG
Best regards
CPG
Should be properly installed. I followed every instruction of the "MCP info on index" installation manual. At the moment it even isn't showing anything on the index page which already worked before.
The problem could also result from the phpBB update 3.0.10 --> 3.0.11. Maybe something went wrong there. I'll take a look at it if I have time.
