Your Portal Version: 1.0.6
Your phpBB Type: other phpBB Distribution
Tried to integrate Prime login return. Also contacted mod author, but... See more here: https://www.phpbb.com/customise/db/mod/ ... al-t_97942
If anyone knows how to integrate it, I would be very grateful.
EDIT: I'm using Portalview!
Integrate Prime Login Return to portal block login_box
mladiucitelj
Re: Integrate Prime Login Return to portal block login_box
Thread moved to "Modifications Support".
