Mini Knowledge Base block for Mini Knowledge Base v 0.2.8
frold
Portal Enthusiast
Post by frold »
MINI KNOWLEDGE BASE BLOCK FOR MINI KNOWLEDGE BASE V. 0.2.7 (MAYBE EARLIER VERSIONS TOO)
Credit:
DaMysterious from http://damysterious.xs4all.nl/portal_premod/
Minor changes by frold
Demo: http://www.studmed.dk - See the block "Nyeste artikler"
Download Mini Knowledge Base here: http://www.phpbb.com/community/viewtopi ... 0&t=589907
CREATE
styles/prosilver/template/portal/block/knowledge.html
REPLACE ALL WITH
<div class="panel">
   <div class="inner">
         <h3>{L_KNOWLEDGE_BASE}</h3>
<!--<tr>
	<th style="text-align:left;" colspan="1">{L_KB_RECENT_ARTICLES}</td>
</tr>-->
  <!-- BEGIN kb_recent_artikel -->
    <td class="<!-- IF kb_recent_artikel.S_ROW_COUNT is even -->row1<!-- ELSE -->row2<!-- ENDIF -->" valign="top">
      <h3>{kb_recent_artikel.TOPIC_LATEST_IMG} <a href="{kb_recent_artikel.U_ARTIKEL}">{kb_recent_artikel.TITLE}</a></h3>
      <div class="rightside" style="float: right;"><a href="#" onclick="Effect.toggle('{kb_recent_artikel.TITLE}','appear'); return false;"> {kb_recent_artikel.ARROW_DOWN_IMG}</a> </div>
  <tr class="<!-- IF kb_recent_artikel.S_ROW_COUNT is not even -->row1<!-- ELSE -->row2<!-- ENDIF -->" id="{kb_recent_artikel.TITLE}" style="margin: 10px 5px 10px 5px; display: none;">
    <td valign="top">
        <div style="margin:15px;">{kb_recent_artikel.ARTIKEL}</div>
  <tr class="<!-- IF kb_recent_artikel.S_ROW_COUNT is even -->row1<!-- ELSE -->row2<!-- ENDIF -->">
    <td valign="top">
      <div class="leftside" style="float: left;"> <span class="gensmall">{kb_recent_artikel.TIME} {L_POST_BY_AUTHOR}: <a href="{kb_recent_artikel.U_USERNAME}">{kb_recent_artikel.POST_AUTHOR_FULL}</a></span> </div>
      <div class="rightside" style="float: right;"> <span class="gensmall">{L_VIEWS}: {kb_recent_artikel.HITS}</span> </div>
  <!-- END kb_recent_artikel -->
<br style="clear:both" />
OPEN
portal.php
    if ($portal_config['portal_change_style'])
       include($phpbb_root_path . 'portal/block/change_style.'.$phpEx);
AFTER ADD
include($phpbb_root_path . 'portal/block/knowledge.'.$phpEx);
OPEN
styles/prosilver/template/portal/portal_body.html
FIND (or where you want to have you knowledge block)
      <!-- IF S_DISPLAY_MINICAL -->
         <!-- INCLUDE portal/block/mini_calendar.html -->
AFTER ADD
			<!-- INCLUDE portal/block/knowledge.html -->
CREATE
portal/block/knowledge.php
REPLACE ALL WITH
* @name kb_recent_articles.php
* @package phpBB3 Portal XL 4.0
* @version $Id: kb_recent_articles.php,v 1.8 2008/03/15 10:12:08 damysterious Exp $
* @copyright (c) 2007 Portal XL 4.0 Group
if (!defined('IN_PHPBB'))
	exit;
$allow_max_articles = 5;  // Here you can set how many articles you want to list
$allow_kb_recent_limit = 250; // Here you can set the chars limit size of the article text
$user->setup('mods/kb');
// Artikel
$sql = "SELECT a.*, u.username, u.user_colour, u.user_id
	FROM " .KB_ARTICLE_TABLE . " a,	" . USERS_TABLE . " u
	WHERE a.activ  = '1'
	AND a.user_id = u.user_id
	ORDER BY post_time DESC";
$result = $db->sql_query_limit($sql, $allow_max_articles);
	$row['bbcode_options'] = (($row['enable_bbcode']) ? OPTION_FLAG_BBCODE : 0);
	$message = generate_text_for_display($row['article'], $row['bbcode_uid'], $row['bbcode_bitfield'], $row['bbcode_options']);
	$message = smiley_text($message); // Always process smilies after parsing bbcodes
	$row['username'] = '<b style="color:#' . $row['user_colour'] . '">' . $row['username'] . '</b> ' ;
	$template->assign_block_vars('kb_recent_artikel', array(
		'ARTIKEL'			=> substr(str_replace('\n', '<br />', $message), 0, $allow_kb_recent_limit) . '...',
		'TITLE'				=> $row['titel'],
		'TIME'				=> $user->format_date($row['post_time']),
		'HITS'				=> $row['hits'],
		'U_ARTIKEL'			=> append_sid("{$phpbb_root_path}knowledge/kb_show." . $phpEx . '?id=' . $row['article_id']),
		'POST_AUTHOR_FULL'	=> get_username_string('full', $row['user_id'], $row['username'], $row['user_colour']),
      	'U_USERNAME'   		=> append_sid("{$phpbb_root_path}memberlist.$phpEx", 'mode=viewprofile&u=' . $row['user_id']),
		'LAST_POST_IMG'		=> $user->img('icon_topic_latest', 'VIEW_LATEST_POST'),
		'NEWEST_POST_IMG'	=> $user->img('icon_topic_newest', 'VIEW_NEWEST_POST'),
		'TOPIC_LATEST_IMG'	=> '<img src="' . $phpbb_root_path . 'styles/' . $user->theme['template_path'] . '/imageset/icon_topic_latest.gif" />',
		'ARROW_DOWN_IMG'	=> '<img src="' . $phpbb_root_path . 'styles/' . $user->theme['template_path'] . '/theme/images/arrow_down.gif" />',
$db->sql_freeresult($result);
1. if you want to change the number of newest articles then edit:
2. if you want to change the number of chars that is show of the article text edit:
3. if you have installed knowledge base in another folder then the standart one then you need to edit:
frold
Portal Enthusiast
Re: Mini Knowledge Base block for Mini Knowledge Base v 0.2.7
Post by frold »
If you wanna have a more simpel block
Open knowledge.html
REPLACE ALL WITH
<div class="panel">
   <div class="inner">
<!--<tr>
</tr>-->
      <strong style="font-size:1.1em;">{kb_recent_artikel.TOPIC_LATEST_IMG} <a href="{kb_recent_artikel.U_ARTIKEL}">{kb_recent_artikel.TITLE}</a></strong>
	  <hr style="margin: 0px 0px 3px 0px;" />
  <tr class="<!-- IF kb_recent_artikel.S_ROW_COUNT is not even -->row1<!-- ELSE -->row2<!-- ENDIF -->">
    <td valign="top"></td>
Kharon
Post by Kharon »
thank you frold
it is working Mini Knowledge Base v 0.2.8 :)
frold
Portal Enthusiast
Post by frold »
Kharon wrote:thank you frold
Thank you subject updated :D
RoxRio
Re: Mini Knowledge Base block for Mini Knowledge Base v 0.2.8
Post by RoxRio »
Hello,
I know this is a old topic, but it's very important to me. I tried to add a Mini KB block in my portal, but I don't know why don't work. Don't appear anything in the block, no article.
I'm using Mini KB v. 0.2.9.
Thanks for your time. And sorry my English.
I have just installed this mod (v. 0.2.9) here on board3.de
Good chance, that i'll take a look on this block within the next days. ;)
RoxRio
Post by RoxRio »
wow, thanks! I'm waiting for the "tests" :mrgreen:
Black-Civic
phpBB.de User: Black-Civic
phpBB.com User: Black-Civic
Post by Black-Civic »
leider kann ich kein Englisch.
Wäre es möglich das nicht nur der Titel sondern auch die beschreibung auf dem Portal angezeigt wird?
MfG
Daniel
the.ronin
Post by the.ronin »
Thanks for writing this frold ...
The strangest thing is that it is working fine locally for me but when I upload the files to my server, I get the following error:
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3554: Cannot modify header information - headers already sent by (output started at /portal/block/knowledge.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3556: Cannot modify header information - headers already sent by (output started at /portal/block/knowledge.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3557: Cannot modify header information - headers already sent by (output started at /portal/block/knowledge.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3558: Cannot modify header information - headers already sent by (output started at /portal/block/knowledge.php:1)
A look into functions.php show these lines as:
	header('Content-type: text/html; charset=UTF-8');
	header('Cache-Control: private, no-cache="set-cookie"');
	header('Expires: 0');
	header('Pragma: no-cache');
Also, changing the char limit does not seem to do anything.
Any ideas what might be going on here?
j.rhy@n
Post by j.rhy@n »
On the following web site http://www.studmed.dk
I see the following error when I click on the Knowlege link
[phpBB Debug] PHP Notice: in file /artikler/kb_show.php on line 214: Undefined variable: s_reported
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3638: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3017)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3640: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3017)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3641: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3017)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3642: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3017)
That seems to ba an issue with the KB itself, not the block.
On this site, the KB looks a bit screwed up in general. ;)
frold
Portal Enthusiast
Post by frold »
It works pretty fine on my site: www.studmed.dk I havent got reported or seen any errors...
I get the "Undefined variable: s_reported" too in the KB: http://www.studmed.dk/artikler/kb_show.php?id=47
And all special chars seemed to be screwed up. :?
the.ronin
Post by the.ronin »
^^ That’s just about how mine looks, Kevin.
What baffles me is that it worked perfectly fine during testing on my home computer. I only got the errors when I tried it on the live site. And both are otherwise exactly identical.
I could imagine that the DB fields for the KB are not set to UTF-8 - i would check this.
