Install it correctly and it works!
Who's playing Arcade 1.3.0
Wuerzi
Topic author - Tester
- phpBB.de User: Würzi
- phpBB.com User: Wuerzi
Re: Who's playing Arcade 1.3.0
Yes
c1nco
Wuerzi wrote:Yes![]()
* @package - Board3portal
* @version $Id: additional_blocks.php 523 2009-08-27 21:41:08Z christian_n $
exit;
include($phpbb_root_path . 'portal/block/arcade_games.' . $phpEx);
?>Code: Select all
<!-- version $Id: additional_blocks_right.html 503 2009-04-20 18:34:29Z kevin74 $ //-->
<!-- additional_blocks //-->
<!-- INCLUDE portal/block/arcade_playing.html -->The box just displays.
WHO IS PLAYING?
UsernameGame
There are currently no games being played.-
Wuerzi
If you see this text, then no user play a game at the moment
techapb12
this thing in red is some sort of a caution.. can anyone translate this for me please :
Wichtig: Die Datei portal/block/arcade_games.php darf nur 1x includiert werden in die portal/block/additional_blocks.php. Andere Arcade Blöcke von mir, werden die gleiche Datei nutzen.
thankies!
thankies!
Span
- phpBB.de User: spanspace
- phpBB.com User: spanspace
This does not work for for me
I followed the installation instructions completely. Whenever the arcade_games line is added my portal no longer functions.
#-----[ FIND ]------------------------------------------
exit;
#-----[ AFTER, ADD ]------------------------------------------
include($phpbb_root_path . 'portal/block/arcade_games.' . $phpEx);-
treumer
- phpBB.de User: treumer
- phpBB.com User: treumer
Terr0r
- phpBB.com User: Terr0r
I hava install this on my portal but I see noting happend
I playing a gam and take a look on my notebook
but I see not that I playing a game how is that possible and how can I fix that
treumer
solte jemand probleme haben damit habe ich eine lösung gefunden
tragt einfach die php datei in addionale blocks ein statt das includet so habe ich es gemacht und es funktioniert endlich
