Boardlink: http://circleofnine.com.pl
PHP Version: 5.2.13
Hello,
yesterday i instaled Advanced BBCode Box 3 but the Image Resizer in portal don't work with img bbcode but with thumbnail works ok, in normal forum section works fine. How can it be fix?
Using:
Board3 1.0.6
phpBB3 3.0.11
Style Jade bbDKP
Langue PL
Thx for any help.
Regards
Fariki
Sory for my english but im polish.
board3 1.0.6 and Advanced BBCode Box 3 problem
Re: board3 1.0.6 and Advanced BBCode Box 3 problem
This might be due to the way the image resizer works with this MOD. If it needs an edit to a certain HTML file you'll need to add this edit to the Portal. Your best change would be to ask the author of the MOD what edit you would need.
