mChat block site [Artodia Black]
FailLife
Post by FailLife »
Hello,
I'm looking for help with my portal. I start today, install php, portal Board3 and mChat. On prosilver work fine but when i install Artodia, edit templates I can't open forum. Portal site work but when I go to the forum - site stop...
http://www.russianvik.unixstorm.org/
Thanks in advance
Re: mChat block site [Artodia Black]
FailLife wrote:Hello,
Thanks in advance
You must follow for their style as the first this manual. =====>Artodia: Ultra Blue / Artodia: Black (Base: prosilver)
The Mchat must incorporate in their style.
FailLife
Post by FailLife »
Yes, I know it. I maked with this instruction. Chat work for guests but when I'm login on site, forum have block. I'm looking for
authorization but everything is ok there.
FailLife wrote:Chat work for guests but when I'm login on site, forum have block. I'm looking for
If they want to be allowed to see the guests Mchat the portal, they must mark approval for the control block.
You must copy mchat_center.html (prosilver) in root / styles / art_black / template / portal /
FailLife
Post by FailLife »
That's problem - quests and normal users can see and write in chat but when I entry like Admin site crashes...
FailLife wrote:That's problem - quests and normal users can see and write in chat but when I entry like Admin site crashes...
I do not think it has to do with the block Mchat, please notify it to the mod developers or www.phpBB.com.
FailLife
Post by FailLife »
Ok, I fixed it.
In mchat_body.html
Find:
<script type="text/javascript" src="{T_TEMPLATE_PATH}/editor.js"></script>
change to:
<script type="text/javascript" src="{T_SUPER_TEMPLATE_PATH}/editor.js"></script>
but next problem is:
and very looong word:
Do You have any ideas?
Edit: fixed ;) Solution:
http://www.rmcgirr83.org/viewtopic.php? ... age#p18474
