No Permissions to view portal in ACP after update to 3.1.7-
ShocK
Post by ShocK »
EDIT: Just realised it's the update to 3.1.7-pl1 that's caused the permission problem and removed the "Can view the Portal" option in permissions.
Your Portal Version: 2.1.0
Boardlink: http://phpbbmods.co.uk/
The setting "Can view the Portal" is missing for all groups and NRU and Registered users cannot see the portal. Admins, global mods, guests can see the portal.
I've installed on localhost to test and the same setting is missing there for all groups aswell
http://s19.postimg.org/jncwnodoz/pic.png
User: test
Pass: test123
I've uninstalled and reinstalled with no joy.
Thanks
Update: When a user gets removed from the NRU group and they're only in the Registered user group that's when they can't see the portal - If I leave them in the NRU then they can see the portal.
ShocK
Re: No Permissions to view portal in ACP
Post by ShocK »
Anyone else noticed this permission problem with 3.1.7-pl1 ?
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
yep its done the same for me. just checked it with my local install which i havn't updated and the option is there but on the newest phpbb the option is not there.
Roma
phpBB.com User: romaamor
Post by Roma »
I have the same problem. No access rights settings.
Roma
Post by Roma »
Me too - No Permissions to view portal in ACP
MyLady
Sponsor
phpBB.de User: Scanialady
phpBB.com User: Scanialady
Post by MyLady »
May be it is caused by this bug https://tracker.phpbb.com/browse/PHPBB3-14407
Tmod
Post by Tmod »
Any updates as to what exactly caused this issue?
Terry
Tmod
Post by Tmod »
Just checked into this further and this was my solution to registered users not being able to see the portal. Admins and Guests could always see it but when a registered user logged in then it dis-appeared.
ACP > Users And Groups > Group Permissions > Registered Users > Hit submit > Role= Standard Features > Apply Permissions
Now they should be able to see the portal, Worked for me so hopefully it works for others that have this issue.
Terry
Roma
Post by Roma »
Tmod wrote:Just checked into this further and this was my solution to registered users not being able to see the portal. Admins and Guests could always see it but when a registered user logged in then it dis-appeared.
Terry
Thank you ;)
ShocK
Post by ShocK »
Tmod wrote:Worked for me so hopefully it works for others that have this issue.
Nicely figured out :D This workaround works for me too.
Tmod
Re: No Permissions to view portal in ACP after update to 3.
Post by Tmod »
Ok I installed a vanilla version of 3.1.6 and a vanilla version of 3.1.7 pl1 and installed board3 portal on both and the option in the ACP misc tab on 3.1.7 pl1 is missing compared to 3.1.6. I have installed 3.1.7 pl1 a total of three times and the same result each time.
phpBB 3.1.6
phpBB 3.1.7 pl1
So the issue does exist, Now the question is why?
Tmod
Tmod
Post by Tmod »
Ok found the file and code that was causing the issue for me. includes/acp/auth.php. When I commented out the code below the "Can view the portal" option returned in 3.1.7 pl1. Checking the same file in 3.1.6 it does not have the same code listed below.
if (!$phpbb_permissions->permission_defined($permission))
					continue;
This was after multiple clean vanilla installs of 3.1.7 pl1 and just adding Board3 Portal so I know it was not any mod that caused this issue.
Pre comment out includes/acp/auth.php
Post comment out includes/acp/auth.php
Tmod
Post by Tmod »
Ok update time.
I was checking into this issue and here is my resolution without modifying any core phpbb files.
You will have to edit the listener.php file located at ext/board3/portal/events/listener.php
Open listener.php and find the following located near the top:
static public function getSubscribedEvents()
		return array(
			'core.user_setup'			=> 'load_portal_language',
			'core.viewonline_overwrite_location'	=> 'viewonline_page',
			'core.page_header'			=> 'add_portal_link',
Now replace that entire code with the following code:
		return array(
			'core.permissions' => 'add_permission',
	* Load permission event
	public function add_permission($event)
    $permissions = $event['permissions'];
    $permissions['u_view_portal'] = array('lang' => 'ACL_U_VIEW_PORTAL', 'cat' => 'misc');
    $permissions['a_manage_portal'] = array('lang' => 'ACL_A_MANAGE_PORTAL', 'cat' => 'misc');
    $event['permissions'] = $permissions;
Now save and exit and upload to your site or if you edited in the ftp program you should be good.
Refresh the site and you will now be able to view the option in the ACP misc tab to either Yes/No/Never view the portal for all the groups. You will also have the ability in the admin permissions misc tab to Yes/No/Never altering the portal settings.
marian0810
phpBB.de User: marian0810
phpBB.com User: marian0810
Post by marian0810 »
That works for me, however the portal settings are still not showing up for me on the Extensions tab in my ACP :?
“We’re all stories, in the end. Just make it a good one, eh?”
Thanks for the solution
You can insert it so:
        return array(
            'core.permissions'                        => 'permission',
    public function permission($event)
        $permissions += array(
            'u_view_portal'    => array(
            'cat'        => 'misc'
            'a_manage_portal' => array(
                'lang'        =>'ACL_A_MANAGE_PORTAL',
                'cat'        => 'misc'
@marian0810:
Have you the permission "Can alter Portal settings"?
