I have upgraded my phpBB from 3.0.14 => 3.1.10 => 3.2.0, and installed Board3 for the first time.
The first time I tried to install there was an error with an non existing database: database_portal_modules
I created this database with a copy from an other test forum after witch the installation could run to the end.
Now in the ACP there are non working items:
ACP_PORTAL_SHOW_ALL
ACP_PORTAL_SHOW_ALL:
PORTAL_SHOW_ALL_SIDE:
I think they don't work because there are still missing tables in the database.
Is there a way to recreate the tables?
ACP problems!
- Valued Contributor
- phpBB.com User: Froddelaar
Re: ACP problems!
They work, but need some edits. Use the files I edited:
https://www.froddelpower.be/scripts/boa ... hsides.zip
It's not perfect, but works and the error is gone.
Or just wait for a better fix
Register a free account & Play!!
~~~ https://www.solidjeuh.be ~~~
Have a secret? --> https://www.tellyoursecrets.eu
Re: ACP problems!
Oh great, it worked!
Thanks for the fast fix.
Edit: there is only one weird thing: in the Dutch version (didn't try the English version) the right menu is the only one if the selection
"Toon portaal op beide kanten: Ja Nee" is ja (Show portal on both sides = yes)
