Your Portal Version: 1.0.5
Boardlink: http://www.completervr.com
nothing
haven't
I am wanting to change the Recent block from recent topic to recent replies.
So if a thread has been responded to recently, it will be at the top of the list, and filter down accordingly.
ultimately I would like 2 of the announcement blocks, but i see someone else asked for this with no joy.
Thank you.
Change Recent topics to Recent replies?
Re: Change Recent topics to Recent replies?
If you want the recent topics to be ordered by the recent replies, try this:
Open portal/block/recent.php
You will have to do the next edit 3 times:
Find:
Replace with:
Find:
ORDER BY topic_time DESC';
ORDER BY topic_last_post_time DESC';
Did this change. But on purging cache and going to portal it's reporting
Parse error: syntax error, unexpected '}' in /home/complet0/public_html/portal/block/recent.php on line 71
Line 71 was never changed?
Below is the recent block code.
![Frage :?:](./images/smilies/icon_question.gif)
* @package - Board3portal
* @version $Id: recent.php 589 2009-12-04 21:11:16Z marc1706 $
exit;
// Exclude forums
// ORDER BY to
$sql_where = '';
if ($portal_config['portal_recent_forum'] > 0)
$exclude_forums = explode(',', $portal_config['portal_recent_forum']);
$sql_where = ' AND ' . $db->sql_in_set('forum_id', $exclude_forums, ($portal_config['portal_exclude_forums']) ? true : false);
// Get a list of forums the user cannot read
$forum_ary = array_unique(array_keys($auth->acl_getf('!f_read', true)));
// Determine first forum the user is able to read (must not be a category)
$sql = 'SELECT forum_id
FROM ' . FORUMS_TABLE . '
WHERE forum_type = ' . FORUM_POST;
$forum_sql = '';
if (sizeof($forum_ary))
$sql .= ' AND ' . $db->sql_in_set('forum_id', $forum_ary, true);
$forum_sql = ' AND ' . $db->sql_in_set('t.forum_id', $forum_ary, true);
$g_forum_id = (int) $db->sql_fetchfield('forum_id');
// Recent announcements
$sql = 'SELECT topic_title, forum_id, topic_id
FROM ' . TOPICS_TABLE . ' t
WHERE topic_status <> ' . FORUM_LINK . '
AND topic_approved = 1
AND (topic_type = ' . POST_ANNOUNCE . ' OR topic_type = ' . POST_GLOBAL . ')
AND topic_moved_id = 0
' . $sql_where . '' . $forum_sql . '
$result = $db->sql_query_limit($sql, $portal_config['portal_max_topics']);
while(($row = $db->sql_fetchrow($result)) && ($row['topic_title']))
// auto auth
if (($auth->acl_get('f_read', $row['forum_id'])) || ($row['forum_id'] == '0'))
$template->assign_block_vars('latest_announcements', array(
'TITLE' => character_limit($row['topic_title'], $portal_config['portal_recent_title_limit']),
'FULL_TITLE' => censor_text($row['topic_title']),
'U_VIEW_TOPIC' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . (($row['forum_id'] == 0) ? $g_forum_id : $row['forum_id']) . '&t=' . $row['topic_id'])
}R
$db->sql_freeresult($result);
// Recent hot topics
WHERE topic_approved = 1
AND topic_replies >=' . $config['hot_threshold'] . '
// auto auth
$template->assign_block_vars('latest_hot_topics', array(
// Recent topic (only show normal topic)
WHERE topic_status <> ' . ITEM_MOVED . '
AND topic_type = ' . POST_NORMAL . '
// auto auth
$template->assign_block_vars('latest_topics', array(
'U_VIEW_TOPIC' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $row['forum_id'] . '&t=' . $row['topic_id'])
$template->assign_var('S_DISPLAY_RECENT', true);
What is that R doing there:
}R
im using an older version of board3, but i could only find it 2 times in the file.
This will only work with 1.0.5. Update your portal.
Haha, don't know.Marc wrote:What is that R doing there:Code: Select all
}R } $db->sql_freeresult($result);
But removing it fixed the problem
![Überglücklich :D](./images/smilies/icon_e_biggrin.gif)
Thanks for your help.
It acutally worked just fine, is there a way to add how many replys there are. So it would look like this
New Topic (14)
Second Topic (2)
ThirdTopic (52)
And so on, and so you will be send to the last page aswell![Lächeln :)](./images/smilies/icon_e_smile.gif)
Regards
New Topic (14)
Second Topic (2)
ThirdTopic (52)
Regards
