Boardlink: http://www.vzroslye.net/portal.php
Nothing!
Absolutely nothing was done on my board last couple of months and problem appeared just two days ago
When I open URL http://www.vzroslye.net/portal.php I see empty screen. I am using subsilver2 but another user of the board uses prosilver and has exactly the same problem.
After some searching I found that the problem disappears when I remove
[b]
[/b]
