Call to undefined function get_unread_topics in user_menu.ph
melian
Post by melian »
Your Portal Version: 1.0.6
Boardlink: http://www.psu-odyssey.com/forum/
Nothing
Just installed the portal
Nothing
So I just installed the last version and I get this error with the user menu.
Fatal error: Call to undefined function get_unread_topics() in /home/www/myname/www/forum/portal/block/user_menu.php on line 56
And I don't know what to do.
Re: Call to undefined function get_unread_topics in user_men
The first thing you should do is using the search. ;)
melian
Post by melian »
Marc wrote:The first thing you should do is using the search. ;)
I did, and all the results are in deutch. (Apparently) it has to do with my phpBB version? Mine is old, it's a 3.0.2.
Can I just edit functions.php with what is missing? Because I won't update my phpBB version, there are too many modifications on it.
melian
Post by melian »
Google traductions helped me. I just had to cut the line from the file, and it looks fine now.
Found my answer in this topic : viewtopic.php?f=8&t=3511&hilit=undefined+function
