Gallery
cwjs
phpBB.de User: cwjs
phpBB.com User: cwjs
Gallery
Post by cwjs »
Is anyone using a gallery with portal 2.0, I have tried to install flying-bits gallery 2.1.1 but it will not work, stops with lots of errors. I will re-install and detail the errors if anyone wants me to, I just really want to know if others have installed it.
Thanks
Re: Gallery
The gallery will be installed beforehand: http://www.flying-bits.org/download.php?mod_id=6
cwjs
phpBB.de User: cwjs
Re: Gallery
Post by cwjs »
Hi Archivar
Thank you for replying
I was trying to do the install from the same link as you gave me.
do you mean install the gallery and then the portal ?
Thanks
Clive
Re: Gallery
cwjs wrote: ...do you mean install the gallery.....?
And then the gallery block-Mod. for the portal.
cwjs
phpBB.de User: cwjs
Re: Gallery
Post by cwjs »
Hi Archivar,
I have a site that has been running for about a year, but I wanted a portal.
I installed the portal (2.0) which works great, I then tried to install gallery as above which gave me lots of errors and changed the look of the portal, I did not get as far as trying the block mod. my question was, has anyone else done this successfully.
Regards
Clive
Re: Gallery
A link to your board would be helpful, so I can see the errors.
cwjs
phpBB.de User: cwjs
Re: Gallery
Post by cwjs »
Hi Archivar,
Test website is now down !
I tried to install again but now get a blank page, I used automod to install, these are the errors I got on the way, last time I got to the board but with erros and the fonts were wrong.
Thanks again
[phpBB Debug] PHP Warning: in file /includes/editor.php on line 1177: is_dir(): open_basedir restriction in effect. File(./../gallery/) is not within the allowed path(s): (/:/tmp/)
[phpBB Debug] PHP Warning: in file /adm/index.php on line 150: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3774)
[phpBB Debug] PHP Warning: in file /adm/index.php on line 152: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3774)
[phpBB Debug] PHP Warning: in file /adm/index.php on line 153: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3774)
[phpBB Debug] PHP Warning: in file /adm/index.php on line 154: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3774)
Re: Gallery
You should not install AutoMod, but manually.
Support for the gallery to get the mod author. http://www.flying-bits.org/viewforum.php?f=101
We only give support for the portal.
cwjs
phpBB.de User: cwjs
Re: Gallery
Post by cwjs »
OK thanks Archivar, I will wipe and reinstall. I will let you know how I get on.
cwjs
phpBB.de User: cwjs
Re: Gallery
Post by cwjs »
I did the Manual install of the gallery which seems to be working fine, I have an extra tab called "ACP_CAT_MODS" which when clicked on gives a "general error Cannot find module ./../includes/acp/acp_mods.php" , it does not seem to affect the gallery or the site.
I also installed the b3p_gallery_block_2_1_1 which seems to be working as well.
Thanks for you help
cwjs
phpBB.de User: cwjs
Re: Gallery
Post by cwjs »
Hi Folks
I have phpbb3 3.09
Board3 Portal 2.0.0b1
Gallery 1_1_4
Gallery Block 2_1_1
It is all working great but I am a little confused over how to use the blocks.
I want a side block that just shows a picture from a certain album, I can get one recent or random but they come from any public album.
I have seen code for a RRC which has album selection, but do not understand how to use it.
Can anyone help please
Clive
cwjs
phpBB.de User: cwjs
Re: Gallery
Post by cwjs »
Thanks for all your help
I have got the album selection sorted now, thanks to nickvergessen at flying-bits.org see http://www.flying-bits.org/viewtopic.php?f=101&t=3707 for how to.
