Error after update (Could not open the file)
Anteli
phpBB.com User: Anteli
Post by Anteli »
Hi! I updated from 2.0.0b to 2.0.0. After installation I got an error message:
Refreshing the we_clearblue template
ERROR: Could not open the file ../styles/we_clearblueucp_main_subscribed.html for reading.
I went to ACP and I tried to refresh we_clearblue template from there and then I got another error message:
Could not open ./../styles/we_clearblue/template/portal/modules/announcements.html
Then I went to MOD page of Board3 and now it says that I have version 2.0.0, but I'm not sure if I really have that version, because I got the error message after update.
Any tips? Thanks!
Re: Error after update (Could not open the file)
This stands in update.xml:
Delete files
Delete portal/includes/trim_message/*.*
Delete styles/prosilver/template/portal/modules/announcements.html
Delete styles/prosilver/template/portal/modules/announcements_compact.html
Anteli
Post by Anteli »
Thanks for quick reply, but I deleted all those files during the update.
A link to the forum would be helpful.
Anteli
Post by Anteli »
archivar wrote:A link to the forum would be helpful.
Portal - http://yksipyoraily.fi/
Board Index - http://yksipyoraily.fi/index.php
Edit: Before updating the Board3, I update my forum from 3.0.9 to 3.0.10. Hopefully that update didn't cause the problem.
Anteli wrote:Hi! I updated from 2.0.0b to 2.0.0. After installation I got an error message:
The style we_clearblue is phpBB v. 3.0.8.
This error should not be the cause of the portal.
You should also customize the style of phpBB 3.0.10, or they take a different style for phpBB 3.0.10.
Anteli wrote:I went to ACP and I tried to refresh we_clearblue template from there and then I got another error message:
Do they have this bug still exists?
Anteli
Post by Anteli »
I updated (made changes by myself) we_clearblue to 3.0.10 and I also tried new style (proglass 3.0.10) with portal.
I was able to refresh templates of proglass style without any problems, but when I try to refresh templates of we_clearblue (v. 3.0.10) I still get same error.
I noticed another problem. When I try to do any changes to Portal Modules I get this error:
The requested file could not be found: styles/prosilver/theme/images/portal/
Anteli wrote: I noticed another problem. When I try to do any changes to Portal Modules I get this error:
Copy: root/styles/prosilver/theme/images/portal/*.*
To: styles/prosilver/theme/images/portal/*.*
Anteli
Post by Anteli »
Ahaa! Thanks! I deleted complete prosilver style, because I don't want to use it. One error fixed!
I still have this problem, when I refresh templates of we_clearblue style:
Could not open ./../styles/we_clearblue/template/portal/modules/announcements_compact.html
But, I think that I will start to use different style. Thank you for your help!
You must delete this File announcements_compact.html see the Instruction
Anteli
Post by Anteli »
Kirk wrote:You must delete this File announcements_compact.html see the Instruction
I have deleted it.
Copy (overwrite) all Portal-files in the forum directory and all styles.
Return to “Styles Support”
