Help with an error msg in the ACP
Current Version: 2.0.2
Released: 2013-10-27
Hippie459MN
phpBB.com User: Hippie459MN
Post by Hippie459MN »
I just installed v2.0.0 on a fresh install with no other mods other then a different style that is based off ProSilver.
Everything seems to be working perfect with the portal and functioning great except one thing, I dont have the original prosilver enabled as I am not using it and when ever I try to change a setting in the ACP I get the error below but the setting will change and still work just fine. What could be the cause of this?
I have another forum running 1.0.6 without this error on a prosilver based theme and I cant seem to figure it out.
The web site is at a somewhat temp location while we put it all together but you can view it here - http://www.hippie459mn.com/mnmudboggers
Any help would be great. :)
Hippie459MN
Re: Help with an error msg in the ACP
Encase you cant read the message it is as follows:
Information
The requested file could not be found: styles/prosilver/theme/images/portal/
I get it when I hit the submit button to make changes to the settings for the portal. Like I said, The changes still take affect all all seems to work as normal, I just get that error of sorts.
MyLady
Sponsor
phpBB.de User: Scanialady
phpBB.com User: Scanialady
Post by MyLady »
may be you have forgotten to copy the folder /portal from prosilver to your theme
There are files missing
Hippie459MN
The theme/images/portal folder is there for the style I am using with all the images. There is other issues with this same error now I noticed. I will report more when I get home tomorrow. Out of town right now.
MyLady
Sponsor
Post by MyLady »
Hippie459MN wrote:... I dont have the original prosilver enabled as I am not using it...
hm.. can that be the problem? It is asking for "..styles/prosilver/theme/images/portal/.."
I don't know whether or not prosilver must be available for installing
noth
phpBB.com User: noth
Post by noth »
well the message is just for your information
ok what are the other problems? if there are none just run with it :D
otherwise try FTP'ing all the Board3 prosilver files to your site again ;)
Hippie459MN
The other issue I am having now is if I try to disable a module in the ACP I get that same message as in the above post and the module will remain enabled when I go back to it. I can delete the module from the list but thats not what I really want to do.
I dont know what happened. And I also have this in my .mods module management after I ran the install script. Can I just run the DB install file and remove the BD enrties and try redoing it? Just a thought...
Thank you for the help thus far. :)
Hippie459MN
Well, Its fixed... I dont know why but even though Prosilver was not my default theme it was active and once I deactivated it everything is working perfect now. The error messages have gone away and all the settings are now saving. Weird but its working.
Thank you for the help. :)
