Hi all
I am looking for a add-on for the gallery program that I can display on the portal page.
What I want to do is place a random slide show of photos from the gallery in the middle column of the portal page (something similar to the gallery block add-on but with just a single image display) which will allow me to set the time duration, image size and transition effect if possible for the images I want to display (chosen from the gallery or randomly picked from the gallery).
I am completely useless at programming so any help with this project would be very much appreciated.
Thanks in advance
Slide Show
- phpBB.de User: Scorpio
- phpBB.com User: scorpiors
Re: Slide Show
I am also looking for same type of module.
