Custon Block ACP
Current Version: 2.0.2
Released: 2013-10-27
talonos
Portal Specialist
phpBB.com User: talonos
Custon Block ACP
Post by talonos »
Your Portal Version: 2.0.1
Boardlink: http://demo.pretereo-stormrage.co.uk/board2
Created a new module using the template system from the knowledge base.
knowledgeboard with no prevail and also internet research still with no luck
Created a new portal module with acp. if i use
		set_config('board3_wowheroesregion_' . $module_id, 'eu');
		set_config('board3_wowheroesrealm_' . $module_id, 'stormrage');
		set_config('board3_wowheroesguild_' . $module_id, 'pretereo');
		return true;
in the module it will work without problems.
trying to change them settings from ACP is not working at all.
here a snippet of my acp file.
<form id="acp_portal_wowheroes" method="post" action="{U_ACTION}">
	<fieldset>
              <legend>{L_PORTAL_WOWHEROES_TITLE}</legend>
		<dl>
			<dt><label>{L_WOWHEROES_REGION}:</label><br />{L_WOWHEROES_REGION_EXPLAIN}</dt>
			<dd><input maxlength="3" size="3" type="text" name="wowregion" id="wowregion" value="{WOWREGION}"/>
		</dl>
        <dl>
			<dt><label>{L_WOWHEROES_REALM}:</label><br />{L_WOWHEROES_REALM_EXPLAIN}</dt>
			<dd><input maxlength="30" size="30" type="text" name="wowrealm" id="wowrealm" value="{WOWREALM}"/>
		</dl>
		<dl>
			<dt><label>{L_WOWHEROES_GUILD}:</label><br />{L_WOWHEROES_GUILD_EXPLAIN}</dt>
			<dd><input maxlength="30" size="30" type="text" name="wowguild" id="wowguild" value="{WOWGUILD}"/>
		</dl>
	<p class="submit-buttons">
		<input class="button1" type="submit" id="submit" name="submit" value="{L_SUBMIT}" />&nbsp;
		<input class="button2" type="reset" id="reset" name="reset" value="{L_RESET}" />
	</p>
	{S_FORM_TOKEN}
	</fieldset>
	</form>
the {WOW*****} values are set in the module file like so
		global $config, $template;
		$template->assign_vars(array(
			'WOWREGION'			=> $config['board3_wowheroesregion_' . $module_id],
			'WOWREALM'			=> $config['board3_wowheroesrealm_' . $module_id],
			'WOWGUILD'			=> $config['board3_wowheroesguild_' . $module_id],
		return 'wowheroes.html';
please could i get some help on this as once i've worked out what the problem is i can start converting allot of my old 1.0.6 mods over to 2.0.1[/i]
Re: Custon Block ACP
You don't need an extra HTML file for the acp settings. Just set get_template_acp() to what you need (similar to this):
		return array(
			'title'	=> 'ACP_PORTAL_WOWHEROES_SETTINGS',
			'vars'	=> array(
				'legend1'							=> 'ACP_PORTAL_WOWHEROES_SETTINGS',
				'board3_wowheroesregion_' . $module_id					=> array('lang' => 'PORTAL_WOWHEROES_REGION',	'validate' => 'string',		'type' => 'text:15:30',	'explain' => true),
Function get_template_side() is for the actual output in the side columns of the portal and not for the ACP (hence the name).
talonos
Portal Specialist
Post by talonos »
ahh ok so thats where my problem was. thanks for that Marc it works great now :)
