I used softalicous to upgrade from 3.0.8 to 3.0.9, and also edited all the board files that were necessary. But for some reason, the portal button at the navbar does not appear. I have tried editing the overall header file, but the most I could do was have a portal button, which directs to portal.php when I am already on the portal page, and index.php when I am on the index page (2 separate re-directs).
The style I use is CB_Black. Here is the overall_header file:
<head>
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" />
<!-- INCLUDE ca_config.html -->
{META}
<title><!-- IF not S_VIEWTOPIC and not S_VIEWFORUM -->{SITENAME} - <!-- ENDIF --><!-- IF S_IN_MCP -->{L_MCP} - <!-- ELSEIF S_IN_UCP -->{L_UCP} - <!-- ENDIF -->{PAGE_TITLE}<!-- IF S_VIEWTOPIC or S_VIEWFORUM --> - {SITENAME}<!-- ENDIF --></title><!-- IF S_ENABLE_FEEDS -->
// <![CDATA[
var on_page = '{ON_PAGE}';
var per_page = '{PER_PAGE}';
var ca_main_width = '{$CA_WIDTH}';
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
var url = '{UA_POPUP_PM}';
* Find a member
function find_username(url)
return false;
window.onload = function()
eval(onload_functions[i]);
window.onunload = function()
eval(onunload_functions[i]);
if(navigator.userAgent && navigator.userAgent.indexOf('Mac OS X') > 0)
document.write('<link rel="stylesheet" href="{T_THEME_PATH}/tweaks_mac.css" type="text/css" />');
</script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/ca_scripts.js"></script>
<!--[if IE]><link href="{T_THEME_PATH}/tweaks_ie.css" type="text/css" rel="stylesheet"/><![endif]-->
<!-- IF S_MCHAT_ENABLE and (S_MCHAT_ON_INDEX or U_MCHAT) -->
<script type="text/javascript" src="{ROOT_PATH}mchat/jquery-1.5.0.min.js"></script>
<script type="text/javascript" src="{ROOT_PATH}mchat/jquery_cookie_mini.js"></script>
<link href="{T_THEME_PATH}/mods.css" rel="stylesheet" type="text/css" />
</head>
<div id="header-wrapper">
<p class="skiplink"><a href="#start_here">{L_SKIP}</a></p>
<div id="header" style="width: {$CA_WIDTH}; margin: 0 auto;">
<div id="header-left"><div id="header-right">
<!-- header start -->
<div id="search-box">
<fieldset>
</fieldset>
</form>
<div style="width: 700px; height: 100px; margin: auto;"><a href="{U_PORTAL}" id="logolink"><span>{SITENAME}</span>{SITE_LOGO_IMG}</a></div>
<div class="header-clear"></div>
</div></div>
<div id="content-wrapper">
<div id="content" style="width: {$CA_WIDTH}; margin: 0 auto;">
<div class="topnav">
<span<!-- IF $CA_PAGE == 'ucp' --> class="current"<!-- ENDIF -->>
<a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="u">{L_PROFILE}</a>
</span>
<!-- IF S_DISPLAY_PM -->
<span>
<a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a>
</span>
<span>
</span>
<span<!-- IF $CA_PAGE == 'faq' --> class="current"<!-- ENDIF -->>
<a href="{U_FAQ}" title="{L_FAQ_EXPLAIN}">{L_FAQ}</a>
</span>
<!-- IF not S_IS_BOT -->
<!-- IF S_USER_LOGGED_IN and S_DISPLAY_MEMBERLIST -->
<span<!-- IF $CA_PAGE == 'users' --> class="current"<!-- ENDIF -->>
<a href="{U_MEMBERLIST}" title="{L_MEMBERLIST_EXPLAIN}">{L_MEMBERLIST}</a>
</span>
<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) -->
<span<!-- IF $CA_PAGE == 'register' --> class="current"<!-- ENDIF -->>
<a href="{U_REGISTER}">{L_REGISTER}</a>
</span>
<span<!-- IF $CA_PAGE == 'login' --> class="current"<!-- ENDIF -->>
<a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l">{L_LOGIN_LOGOUT}</a>
</span>
<div id="page-body">
<div class="navbar navbar-top">
<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> » <!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>‹</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
<!-- IF U_EMAIL_TOPIC --><li class="rightside"><a href="{U_EMAIL_TOPIC}" title="{L_EMAIL_TOPIC}" class="sendemail">{L_EMAIL_TOPIC}</a><!-- IF $CA_HEADER_LINK --> | <!-- ELSE --><!-- DEFINE $CA_HEADER_LINK = '1' --><!-- ENDIF --></li><!-- ENDIF -->
<!-- IF U_EMAIL_PM --><li class="rightside"><a href="{U_EMAIL_PM}" title="{L_EMAIL_PM}" class="sendemail">{L_EMAIL_PM}</a><!-- IF $CA_HEADER_LINK --> | <!-- ELSE --><!-- DEFINE $CA_HEADER_LINK = '1' --><!-- ENDIF --></li><!-- ENDIF -->
<!-- IF U_PRINT_TOPIC --><li class="rightside"><a href="{U_PRINT_TOPIC}" title="{L_PRINT_TOPIC}" accesskey="p" class="print">{L_PRINT_TOPIC}</a><!-- IF $CA_HEADER_LINK --> | <!-- ELSE --><!-- DEFINE $CA_HEADER_LINK = '1' --><!-- ENDIF --></li><!-- ENDIF -->
<!-- IF U_PRINT_PM --><li class="rightside"><a href="{U_PRINT_PM}" title="{L_PRINT_PM}" accesskey="p" class="print">{L_PRINT_PM}</a><!-- IF $CA_HEADER_LINK --> | <!-- ELSE --><!-- DEFINE $CA_HEADER_LINK = '1' --><!-- ENDIF --></li><!-- ENDIF -->
<!-- IF SCRIPT_NAME == 'viewtopic' -->
<!-- IF U_VIEW_NEWER_TOPIC --><li class="rightside"><a href="{U_VIEW_NEWER_TOPIC}">{L_VIEW_NEXT_TOPIC}</a><!-- IF $CA_HEADER_LINK --> | <!-- ELSE --><!-- DEFINE $CA_HEADER_LINK = '1' --><!-- ENDIF --></li><!-- ENDIF -->
<!-- IF U_VIEW_OLDER_TOPIC --><li class="rightside"><a href="{U_VIEW_OLDER_TOPIC}">{L_VIEW_PREVIOUS_TOPIC}</a><!-- IF $CA_HEADER_LINK --> | <!-- ELSE --><!-- DEFINE $CA_HEADER_LINK = '1' --><!-- ENDIF --></li><!-- ENDIF -->
<!-- IF not S_IS_BOT && not $CA_SKIP_PM_NOTIFY && S_USER_LOGGED_IN && S_DISPLAY_PM -->
<!-- IF S_USER_NEW_PRIVMSG -->
<div class="pm-notify-new">
<h3>{L_PRIVATE_MESSAGES}</h3>
<p><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></p>
<!-- ELSEIF S_USER_UNREAD_PRIVMSG -->
<div class="pm-notify-unread">
{$CA_BLOCK_START}
{$CA_BLOCK_END}
<!-- ENDIF -->Thanks.
Here is my website URL:
http://www.3godsempire.org
EDIT: I seem to have solved this problem by editing it and replacing the navbar code with this:
<li class="icon-home"><a href="http://www.3godsempire.org/portal.php">Portal</a> » <a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>‹</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
