warcraft recruitment block (port from phpbb3portal)
talonos
Portal Specialist
phpBB.com User: talonos
Re: warcraft recruitment block (port from phpbb3portal)
Post by talonos »
its still a work in progress atm. i'm no good at setting up ACP stuff so i've kindly asked a friend if he could do it but he's currently on field training and still has a few weeks of that left aswell.
Itania
Post by Itania »
Sheepy wrote:Nice to see my Recruitment Block converted for Board3.
I'm making an updated package, with new images an wrote an install.xml file with all the board3 edits to make it easier for install.
Will upload the file as soon as im done ;)
I'll also add the subsilver style files as well.
Sheepy wrote:Here is the updated package i made.
Contains new install.xml easier to read install options :D
New images.
Fixed some typo's
http://sheepy.ulmb.com/misc/recruitment ... rd3.de.zip
Sry for my bad english, but i need the files for subsilver2. Do you have add the files somewhere? It would be very nice ;)
talonos
Portal Specialist
Post by talonos »
Julies wrote:This looks really nice! Will it look good with a black background instead of white and will you be adding the Worgen race?
it will have a transparent background. also there is no WORGEN class..... Worgen is a RACE...
the NEW recruitment block is now in the public alpha stage... please refer to http://board3.de/viewtopic.php?f=9&t=4150 for information.
