Calendar block for phpBB Calendar 0.0.8
Onetimer
Re: Calendar block for phpBB Calendar 0.0.8
Very good points Kevin! I agree with all of them, actually. I just didn't realize how complicated it would be.
I never thought of that before, but there are no other mods in Board3?
No - no other mods. As far I remember, we only took over some snippets, from users who have provided it here aboard, e.g in the birthday block for the upcoming birthdays (kendoo).Onetimer wrote:I never thought of that before, but there are no other mods in Board3?
And (don't start to laugh
But this one has been already implemented in the moment we started this fork from phpBB3Portal. And we had a lot trouble with it (Styling / XHTML valid strict). At some point we thought about kicking it completely out.@copyright (c) Adrian Cockburn - phpbb@netclectic.com (mini calendar)
All support for other mods should be done separately in extra blocks.
But don't get me wrong: we are happy about every developed extra block, who supports other good mods.
And we already have a lot supporting blocks: gallery, download mod, teamspeak, other calendars, games, etc..
So everyone could "pimp" his portal to his needs.
Anyway: I'm expecting some more good calendar mods in future - another argument to keep it like it is. The mini cal needs no edits to the core sytem.
DeanB
- phpBB.de User: DeanB
hast du das Problem gelöst ?
Holy wrote:Hi, ich hab folgendes Problem:
Im Calendar auf der Haupseite werden normale Termine erst angezeigt, wenn sie innerhalb der nächsten 2 oder 3 wochen liegen, all-day events aber wenn sie innerhalb des Jahres sind.
Bsp:
Termin morgen -> wird angezeigt
Termin nächsten Monat -> nicht angezeigt
all-day Termin in 3 Monaten -> wird angezeigt
Dadurch entsteht der effekt, dass im nächsten Monat nix los ist. kann ich das auch für all-day-events so einstellen, dass die nur angezeigt werden, wenn sie in der entsprechenden zeitspanne sind?
PS: Ich glaube, die änderung muss irgend wo in der function calendar_display_mini_month() erfolgen, an dieser stelle wohl, aber wie genau?
$start_temp_date = gmmktime( 0,0,0,$date['month_no'], $day, $date['year']); $end_temp_date = $start_temp_date + 2678400; // find all day events that are still taking place $sort_timestamp_cutoff = $start_temp_date - 86400+1; // don't list events that are more than 1 year in the future $sql = 'SELECT * FROM ' . CALENDAR_EVENTS_TABLE . ' WHERE ( (event_access_level = 2) OR (event_access_level = 0 AND poster_id = '.$db->sql_escape($user->data['user_id']).' ) OR (event_access_level = 1 AND ('.$db->sql_escape($group_options).') ) ) AND ((( event_start_time >= '.$db->sql_escape($start_temp_date).' AND event_start_time <= '.$db->sql_escape($end_temp_date).' ) OR ( event_end_time > '.$db->sql_escape($start_temp_date).' AND event_end_time <= '.$db->sql_escape($end_temp_date).' ) OR ( event_start_time < '.$db->sql_escape($start_temp_date).' AND event_end_time > '.$db->sql_escape($end_temp_date)." )) OR (sort_timestamp > ".$db->sql_escape($sort_timestamp_cutoff)." AND event_all_day = 1) ) ORDER BY sort_timestamp ASC";
wintstar
- phpBB.de User: wintstar
- phpBB.com User: wintstar
mein calender block funktioniert nicht hab alles nach install gemacht. install scheint was zu fehlen.
habe phpbb 3.o4 und das board Portal
kann mir jemand helfen?
danke
stephan
danke
stephan
Gruß Stephan
Onetimer
Entschuldige meine schlechtes Deutsch, aber dieses block sind "adandonware". Sie musst die ganze thread lesen.wintstar wrote:mein calender block funktioniert nicht hab alles nach install gemacht. install scheint was zu fehlen.
danke
stephan
wintstar
Onetimer wrote:wintstar wrote:mein calender block funktioniert nicht hab alles nach install gemacht. install scheint was zu fehlen.
danke
stephan
versteh ich nicht (an deinem deutsch liegt´s nicht) hab ich was hier übersehen?
Gruß Stephan
DeaQ
- Valued Contributor
- phpBB.de User: DeaQ
- phpBB.com User: DeaQ
wintstar mache es mal so wie Denis es beschrieben hat ... ich habe es so ausgeführt und habe alles perfekt hinbekommen
viewtopic.php?f=21&t=459&start=105#p12161
greetz
DeaQ [di_kju]
DeaQ [di_kju]
Onetimer
Anybody got this block to work with Board3 1.0.3?
My Calendar block is just an empty block now (except for the word Events). I guess this has something to do with the new block handling in 1.0.3?
Because Frold seem to have abandoned this mod/block, it would be great if someone php-savvy could update this block (and correct some of the mistakes/errors already in there, look at the screenshot a few posts above as well as some of the posts on page 6 for instance).
wintstar
hab jetzt alles berreinigt und nach euren tips installiert. funtioniert trotzdem nicht, kein event wird angzeigt. bin ratlos
gruß
stephan
gruß
stephan
Gruß Stephan
Onetimer
I just realized I had replaced portal.php in the update process, and after re-adding the code to it the Calendar is now back to where it was before I updated to Board3 1.0.3. I still have the problem with no events showing up in the Calendar block, even if I set the to public events. So if anyone can give me a tip on how to get that working I would be very grateful. I know someone mentioned that he or she had the same problem a while back.
I though I'd go ahead and try the updates recommeneded in the first post. One question though;
Replace With
Just to be sure, does the above mean this;Graceland wrote: Open includes/functions_calendar.php
SEARCHREPLACE THE COMPLETE FUNCTION WITH (UP TO function get_weekday_names_mini ...)Code: Select all
function calendar_display_mini_month() {Code: Select all
function calendar_display_mini_month() { global $auth, $db, $user, $config, $template, $date, $available_etype_colors, $available_etype_images, $available_etype_display_names, $month_sel_code, $day_sel_code, $year_sel_code, $mode_sel_code; global $phpEx, $phpbb_root_path; init_calendar_data(); init_view_selection_code("month"); // data of akt. month $time = getdate(time()); //create next and prev links set_date_prev_next( "month" ); $calling_page = (!empty($_SERVER['PHP_SELF'])) ? $_SERVER['PHP_SELF'] : $_ENV['PHP_SELF']; $mini_prev_link = append_sid($calling_page, "calM=".$date['prev_month']."&calY=".$date['prev_year']); $mini_next_link = append_sid($calling_page, "calM=".$date['next_month']."&calY=".$date['next_year']); //find the first day of the week $first_day_of_week = get_calendar_config_value("first_day_of_week", 0); get_weekday_names_mini( $first_day_of_week, $sunday, $monday, $tuesday, $wednesday, $thursday, $friday, $saturday ); //get the first day of the month $date['num'] = "01"; $date['fday'] = get_fday( $date['num'], $date['month_no'], $date['year'], $first_day_of_week ); $number_days = gmdate("t", gmmktime( 0,0,0,$date['month_no'], $date['day'], $date['year'])); //$mini_calendar_header_txt = $user->lang['MONTH_OF'] . sprintf($user->lang['LOCAL_DATE_FORMAT'], $user->lang['datetime'][$date['month']], $date['day'], $date['year'] ); $mini_calendar_header_txt = $user->lang['datetime'][$date['month']] . ' - ' . $date['year']; $subject_limit = get_calendar_config_value("display_truncated_name", 0); // Is the user able to view ANY events? $user_can_view_events = false; if ( $auth->acl_get('u_calendar_view_events') ) { $user_can_view_events = true; /* find the group options here so we do not have to look them up again for each day */ $group_options = get_sql_group_options($user->data['user_id']); } $counter = 0; for ($j = 1; $j < $number_days+1; $j++, $counter++) { // if it is the first week if ($j == 1) { // find how many place holders we need before day 1 if ($date['fday'] < 7) { $date['fday'] = $date['fday']+1; for ($i = 1; $i < $date['fday']; $i++, $counter++) { // create dummy days (place holders) if( $i == 1 ) { $mini_calendar_days['START_WEEK'] = true; } else { $mini_calendar_days['START_WEEK'] = false; } $mini_calendar_days['END_WEEK'] = false; $mini_calendar_days['HEADER_CLASS'] = 'bg3'; $mini_calendar_days['DAY_CLASS'] = 'bg2'; $mini_calendar_days['NUMBER'] = 0; $mini_calendar_days['DUMMY_DAY'] = true; $mini_calendar_days['ADD_LINK'] = ''; $mini_calendar_days['BIRTHDAYS'] = ''; $template->assign_block_vars('mini_calendar_days', $mini_calendar_days); } } } // start creating the data for the real days $mini_calendar_days['START_WEEK'] = false; $mini_calendar_days['END_WEEK'] = false; $mini_calendar_days['DUMMY_DAY'] = false; $mini_calendar_days['HEADER_CLASS'] = 'bg3'; $mini_calendar_days['DAY_CLASS'] = 'bg2'; $mini_calendar_days['NUMBER'] = 0; $mini_calendar_days['ADD_LINK'] = ''; $mini_calendar_days['BIRTHDAYS'] = ''; $mini_calendar_days['WRITE_BOLD'] = 100; if($counter % 7 == 0) { $mini_calendar_days['START_WEEK'] = true; } if($counter % 7 == 6 ) { $mini_calendar_days['END_WEEK'] = true; } $mini_calendar_days['NUMBER'] = $j; if( $auth->acl_get('u_calendar_create_events') ) { $mini_calendar_days['ADD_LINK'] = append_sid("{$phpbb_root_path}calendarpost.$phpEx", "mode=post&calD=".$j."&calM=".$date['month_no']."&calY=".$date['year']); } $mini_calendar_days['DAY_VIEW_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=day&calD=".$j."&calM=".$date['month_no']."&calY=".$date['year']); $mini_calendar_days['WEEK_VIEW_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=week&calD=".$j."&calM=".$date['month_no']."&calY=".$date['year']); //highlight selected day if( $j == $date['day'] && $date["month_no"] == $time["mon"]) { $mini_calendar_days['DAY_CLASS'] = 'bg4'; } //highlight current day $test_start_hi_time = mktime( 0,0,0,$date['month_no'], $j, $date['year']) + date('Z'); $test_end_hi_time = $test_start_hi_time + 86399; $test_hi_time = time() + $user->timezone + $user->dst; if( ($test_start_hi_time <= $test_hi_time) && ($test_end_hi_time >= $test_hi_time)) { $mini_calendar_days['HEADER_CLASS'] = 'bg3'; $mini_calendar_days['DAY_CLASS'] = 'bg4'; } /* if ( $user_can_view_events && $auth->acl_get('u_viewprofile') ) { // find birthdays $mini_calendar_days['BIRTHDAYS'] = generate_birthday_list( $j, $date['month_no'], $date['year'] ); } */ $arrayOfDays[] = $mini_calendar_days; } if ( $user_can_view_events ) { if($time["mon"] == $date["month_no"]) $day = $date['day']; else $day = 1; // startDate = first Day of viewed month $start_temp_date = gmmktime( 0,0,0,$date['month_no'], $day, $date['year']); $end_temp_date = $start_temp_date + 2678400; // find all day events that are still taking place $sort_timestamp_cutoff = $start_temp_date - 86400+1; // don't list events that are more than 1 year in the future $sql = 'SELECT * FROM ' . CALENDAR_EVENTS_TABLE . ' WHERE ( (event_access_level = 2) OR (event_access_level = 0 AND poster_id = '.$db->sql_escape($user->data['user_id']).' ) OR (event_access_level = 1 AND ('.$db->sql_escape($group_options).') ) ) AND ((( event_start_time >= '.$db->sql_escape($start_temp_date).' AND event_start_time <= '.$db->sql_escape($end_temp_date).' ) OR ( event_end_time > '.$db->sql_escape($start_temp_date).' AND event_end_time <= '.$db->sql_escape($end_temp_date).' ) OR ( event_start_time < '.$db->sql_escape($start_temp_date).' AND event_end_time > '.$db->sql_escape($end_temp_date)." )) OR (sort_timestamp > ".$db->sql_escape($sort_timestamp_cutoff)." AND event_all_day = 1) ) ORDER BY sort_timestamp ASC"; // find next 5 events $result = $db->sql_query_limit($sql, 5, 0); // $result = $monthEventResult; while ($row = $db->sql_fetchrow($result)) { $dayOfEvent = getdate($row["sort_timestamp"]); $event_output['COLOR'] = $available_etype_colors[$row['etype_id']]; $event_output['IMAGE'] = $available_etype_images[$row['etype_id']]; $event_output['EVENT_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=event&calEid=".$row['event_id']); $event_output['NUMBER'] = $dayOfEvent["mday"].".".$dayOfEvent["mon"]."."; $event_output['DAY_VIEW_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=day&calD=".$dayOfEvent["mday"]."&calM=".$dayOfEvent["mon"]."&calY=".$dayOfEvent["year"]); $event_output['WEEK_VIEW_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=week&calD=".$dayOfEvent["mday"]."&calM=".$dayOfEvent["mon"]."&calY=".$dayOfEvent["year"]); if($date["month_no"] == $dayOfEvent["mon"]) { $arrayOfDays[$dayOfEvent["mday"]-1]["WRITE_BOLD"] = "bold"; } // if the event was created by this user // display it in bold if( $user->data['user_id'] == $row['poster_id'] ) { $event_output['DISPLAY_BOLD'] = true; } else { $event_output['DISPLAY_BOLD'] = false; } $event_output['ETYPE_DISPLAY_NAME'] = $available_etype_display_names[$row['etype_id']]; $event_output['EVENT_SUBJECT'] = censor_text($row['event_subject']); if( $subject_limit > 0 ) { if(utf8_strlen($event_output['EVENT_SUBJECT']) > $subject_limit) { $event_output['EVENT_SUBJECT'] = truncate_string($event_output['EVENT_SUBJECT'], $subject_limit) . '...'; } } $template->assign_block_vars('events', $event_output); } $db->sql_freeresult($result); } for($a=0;$a<count($arrayOfDays);$a++) { if(!empty($arrayOfDays[$a]["NUMBER"])) { $template->assign_block_vars('mini_calendar_days', $arrayOfDays[$a]); } } $counter--; $dummy_end_day_count = 6 - ($counter % 7); for ($i = 1; $i <= $dummy_end_day_count; $i++) { // create dummy days (place holders) $mini_calendar_days['START_WEEK'] = false; if( $i == $dummy_end_day_count ) { $mini_calendar_days['END_WEEK'] = true; } else { $mini_calendar_days['END_WEEK'] = false; } $mini_calendar_days['HEADER_CLASS'] = ''; $mini_calendar_days['DAY_CLASS'] = ''; $mini_calendar_days['NUMBER'] = 0; $mini_calendar_days['DUMMY_DAY'] = true; $mini_calendar_days['ADD_LINK'] = ''; $mini_calendar_days['BIRTHDAYS'] = ''; $template->assign_block_vars('mini_calendar_days', $mini_calendar_days); } // A typical usage for sending your variables to your template. $template->assign_vars(array( 'CALENDAR_HEADER_MINI' => $mini_calendar_header_txt, 'DAY_IMG' => $user->img('button_calendar_day', 'DAY'), 'WEEK_IMG' => $user->img('button_calendar_week', 'WEEK'), 'CALENDAR_PREV_MINI' => '<a href=\''.$mini_prev_link.'\'><img src="' . $phpbb_root_path . 'styles/' . $user->theme['theme_path'] . '/theme/images/portal/mini_cal_icon_left_arrow.png' . '" title="' . $user->lang['View_previous_month'] . '" height="16" width="16" alt="<<" /></a>', 'CALENDAR_NEXT_MINI' => '<a href=\''.$mini_next_link.'\'><img src="' . $phpbb_root_path . 'styles/' . $user->theme['theme_path'] . '/theme/images/portal/mini_cal_icon_right_arrow.png' . '" title="' . $user->lang['View_next_month'] . '" height="16" width="16" alt=">>" /></a>', 'CALENDAR_VIEW_OPTIONS' => $mode_sel_code.' '.$month_sel_code.' '.$day_sel_code.' '.$year_sel_code, 'SUNDAY_MINI' => $sunday, 'MONDAY_MINI' => $monday, 'TUESDAY_MINI' => $tuesday, 'WEDNESDAY_MINI' => $wednesday, 'THURSDAY_MINI' => $thursday, 'FRIDAY_MINI' => $friday, 'SATURDAY_MINI' => $saturday, 'S_POST_ACTION_MINI' => append_sid("{$phpbb_root_path}calendar.$phpEx" ), )); }
function get_weekday_names_mini( $first_day_of_week, &$sunday, &$monday, &$tuesday, &$wednesday, &$thursday, &$friday, &$saturday )
global $user;
switch( $first_day_of_week )
case 0:
$sunday = $user->lang['mini_datetime']['Su'];
$monday = $user->lang['mini_datetime']['Mo'];
$tuesday = $user->lang['mini_datetime']['Tu'];
$wednesday = $user->lang['mini_datetime']['We'];
$thursday = $user->lang['mini_datetime']['Th'];
$friday = $user->lang['mini_datetime']['Fr'];
$saturday = $user->lang['mini_datetime']['Sa'];
break;
case 1:
$saturday = $user->lang['mini_datetime']['Su'];
$sunday = $user->lang['mini_datetime']['Mo'];
$monday = $user->lang['mini_datetime']['Tu'];
$tuesday = $user->lang['mini_datetime']['We'];
$wednesday = $user->lang['mini_datetime']['Th'];
$thursday = $user->lang['mini_datetime']['Fr'];
$friday = $user->lang['mini_datetime']['Sa'];
break;
case 2:
$friday = $user->lang['mini_datetime']['Su'];
$saturday = $user->lang['mini_datetime']['Mo'];
$sunday = $user->lang['mini_datetime']['Tu'];
$monday = $user->lang['mini_datetime']['We'];
$tuesday = $user->lang['mini_datetime']['Th'];
$wednesday = $user->lang['mini_datetime']['Fr'];
$thursday = $user->lang['mini_datetime']['Sa'];
break;
case 3:
$thursday = $user->lang['mini_datetime']['Su'];
$friday = $user->lang['mini_datetime']['Mo'];
$saturday = $user->lang['mini_datetime']['Tu'];
$sunday = $user->lang['mini_datetime']['We'];
$monday = $user->lang['mini_datetime']['Th'];
$tuesday = $user->lang['mini_datetime']['Fr'];
$wednesday = $user->lang['mini_datetime']['Sa'];
break;
case 4:
$wednesday = $user->lang['mini_datetime']['Su'];
$thursday = $user->lang['mini_datetime']['Mo'];
$friday = $user->lang['mini_datetime']['Tu'];
$saturday = $user->lang['mini_datetime']['We'];
$sunday = $user->lang['mini_datetime']['Th'];
$monday = $user->lang['mini_datetime']['Fr'];
$tuesday = $user->lang['mini_datetime']['Sa'];
break;
case 5:
$tuesday = $user->lang['mini_datetime']['Su'];
$wednesday = $user->lang['mini_datetime']['Mo'];
$thursday = $user->lang['mini_datetime']['Tu'];
$friday = $user->lang['mini_datetime']['We'];
$saturday = $user->lang['mini_datetime']['Th'];
$sunday = $user->lang['mini_datetime']['Fr'];
$monday = $user->lang['mini_datetime']['Sa'];
break;
case 6:
$monday = $user->lang['mini_datetime']['Su'];
$tuesday = $user->lang['mini_datetime']['Mo'];
$wednesday = $user->lang['mini_datetime']['Tu'];
$thursday = $user->lang['mini_datetime']['We'];
$friday = $user->lang['mini_datetime']['Th'];
$saturday = $user->lang['mini_datetime']['Fr'];
$sunday = $user->lang['mini_datetime']['Sa'];
break;
* End additional Portal XL 4.0 functions
function calendar_display_month()
$counter = 0;
if ($j == 1)
if( $i == 1 )
// find birthdays
$counter--;
Razer
Ich habe ein riesen Problem!
In etwa 20 Stunden MUSS meine Seite wieder online sein, jetzt ist sie komplett wess!
Ich habe einfach alle Aenderungen durchgefuehrt, geht nicht! Die ganze Seite ist weiss!
Wer kann helfen>
Wer kann helfen>
Schon die betreffenden Artikel in der KB versucht?
ralf-isi
- phpBB.de User: ralf-isi
@Razer
einfach die gesicherten files wieder auf den server stellen. dann läuft es wieder und den um-/einbau nochmals machen.
Razer
Danke, hatte halt so ein STress, denn heute musste die Seite wieder online sein! Sorry. Aber eine ganz andere Frgae:ralf-isi wrote:@Razer
subsilver2 style?
Razer
So, habe das mit subsliver selber hinbekommen, hier der Code, beachtet aber, dass ich ihn an meinen Style, der auf subsilver basiert, angepasst habe. Dass anpassen an andere Styles sollte nicht so schwer sein:
Jetzt stellt sich die Frage, wie bekomme ich das europaeische System in den Kalendar, sprich Woche vom Montag aus. Wenn ich SO und MO in der Datei tausche, sind die Tage falsch. Was soll ich unternehmen?
Danke!
{$LR_BLOCK_H_L}<img src="{T_THEME_PATH}/images/portal/portal_minical.png" width="16px" height="16px" alt="" /> {L_MINI_CAL_CALENDAR}{$LR_BLOCK_H_R}
<tr class="row1">
<td>
<table width="100%" cellspacing="1">
<td align="left" colspan="2"><!-- IF CALENDAR_PREV_MINI -->{CALENDAR_PREV_MINI}</a><!-- ENDIF --></td>
<td colspan="3" align="center"><span class="genmed"><b>Sp?les {CALENDAR_HEADER_MINI}<b></span></td>
<td align="right" colspan="2"><!-- IF CALENDAR_NEXT_MINI -->{CALENDAR_NEXT_MINI}</a><!-- ENDIF --></td>
<table class="table_minical" cellspacing="0" cellpadding="0">
<!--<tr>
<th style="text-align:left;" colspan="7">{L_MINI_CAL_CALENDAR}</td>
</tr>-->
<tr class="row1">
<td style="width: 5%; text-align: center"><span class="gensmall" style="color:#800000"><b>Sv</b></span></td>
<td style="width: 5%; text-align: center"><span class="gensmall" style="color:#800000"><b>Pi</b></span></td>
<td style="width: 5%; text-align: center"><span class="gensmall" style="color:#800000"><b>Ot</b></span></td>
<td style="width: 5%; text-align: center"><span class="gensmall" style="color:#800000"><b>Tr</b></span></td>
<td style="width: 5%; text-align: center"><span class="gensmall" style="color:#800000"><b>Ce</b></b></span></td>
<td style="width: 5%; text-align: center"><span class="gensmall" style="color:#800000"><b>Se</b></span></td>
<!-- BEGIN mini_calendar_days -->
<!-- IF mini_calendar_days.START_WEEK -->
<!-- IF mini_calendar_days.DUMMY_DAY -->
<td valign="top" class="bg3_calMon"> </td>
<td valign="top" class="{mini_calendar_days.DAY_CLASS}">
<table cellpadding="0" cellspacing="1" border="0" width="100%">
<td class="{mini_calendar_days.HEADER_CLASS}" style="font-weight:{mini_calendar_days.WRITE_BOLD}; text-align:center;">
<!-- IF mini_calendar_days.ADD_LINK -->
<a href="{mini_calendar_days.ADD_LINK}">{mini_calendar_days.NUMBER}</a>
</table></td>
<!-- IF mini_calendar_days.END_WEEK -->
<!-- END mini_calendar_days -->
<br clear="all" />
<table class="table_minical" cellspacing="0" cellpadding="0" width="100%">
<tr class="row1">
<td style="width: 100%; text-align: center" class="bg4"><b><font color="#ffffff">N?kam?s sp?les</font></b></td>
<td class="row1">
<!-- BEGIN events -->
<!-- IF events.S_FIRST_ROW -->
<!-- ELSE --><hr><!-- ENDIF -->
<a href="{events.DAY_VIEW_URL}"><!-- IF events.COLOR --><span style="color:#{events.COLOR}"><!-- ENDIF -->
[{events.NUMBER}]<!-- IF events.COLOR --></span><!-- ENDIF --></a>
<a href="{events.EVENT_URL}" title="{events.EVENT_SUBJECT}">
<!-- IF events.DISPLAY_BOLD --><strong><!-- ENDIF -->
<!-- IF events.IMAGE --><img src="{events.IMAGE}" title="{events.ETYPE_DISPLAY_NAME}" height="20" width="20" /><!-- ENDIF -->
<!-- IF events.ETYPE_DISPLAY_NAME -->{events.ETYPE_DISPLAY_NAME}:<!-- ENDIF -->
<!-- IF events.DISPLAY_BOLD --></strong><!-- ENDIF -->
<!-- IF events.SHOW_TIME --><br /><!-- IF events.ALL_DAY -->{L_ALL_DAY}<!-- ELSE -->
{L_FROM_TIME}: {events.START_TIME} <br />{L_TO_TIME}: {events.END_TIME}<!-- ENDIF -->
<!-- IF events.COLOR --></span><!-- ENDIF --></a><br />
<!-- END events -->
{$LR_BLOCK_F_L}{$LR_BLOCK_F_R}Danke!
