Calendar block for phpBB Calendar 0.0.8
Re: Calendar block for phpBB Calendar 0.0.8
Razer wrote:wie bekomme ich das europaeische System in den Kalendar, sprich Woche vom Montag aus.
Das sollte eine Option im ACP für den Kalender sein. Hier der Code, womit das bestimmt wird aus der includes/functions_calendar.php:
//find the first day of the week
       $first_day_of_week = get_calendar_config_value("first_day_of_week", 0);
Wenn Dir die Option fehlt, müsste es sich auch "hardcoden" lassen:
       //$first_day_of_week = get_calendar_config_value("first_day_of_week", 0);
$first_day_of_week = 1;
thomas.d
phpBB.de User: thomas.d
phpBB.com User: thomas.d
Post by thomas.d »
Kevin wrote:... Wenn Dir die Option fehlt, müsste es sich auch "hardcoden" lassen ...
Das ist nicht notwendig denn ...
Kevin wrote:... Das sollte eine Option im ACP für den Kalender sein. ...
Das ist so. In den Einstellungen des Kalenders kann der erste Tag der Woche (hier Mo) ausgewählt werden.
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Huor
Post by Huor »
I am just have installed this mod. But i have some problems with the style. So my first question has anyone of you already this mod installed and using black pearl style? And if yes would you mind to support me with this?
If the mod itself is running i am thinking to integrate the portal mod for this as well.
I hope i am not totally offtopic.
Thanks in advance
Huor
Edit: Self is the man - i made the adaption to Black Pearl Style for it.
Now tomorrow or so i think i will try the mod for the portal as well. ;)
Midge
Sponsor
phpBB.com User: Midge
Post by Midge »
This block works fine, thank you very much for that! :D
There is just one question I have: How do I change the colours of the portal calendar? I do appreciate that days with events are bolded, but if there's only one event it looks as if this was the current day - while the square around the actual 'current day' is quite difficult to see. Is is possible to adjust the colour of the square to make it...say...black and the background of the day white or something?
wintstar
phpBB.de User: wintstar
phpBB.com User: wintstar
Post by wintstar »
falls ihr auf der portalseite die events oder wochenansicht (im ACP unter Kalendereinstellungen) anzeigen zu lassen wie in der forenübersicht geht folgend vor:
phpbb 3.05.
phpbb calender 0.0.8
board3 portal 1.0.3
prosilver
root/portal.php
suche:
dannach:
include($phpbb_root_path . 'includes/functions_calendar.' . $phpEx);
suche:
// output page
davor:
// Generate calendar week view or next events if required ...
calendar_display_calendar_on_index();
EDIT anweisung unten nur für 1.0.3
style/prosilver/template/portal/portal_body.html
suche:
<!-- IF S_DISPLAY_ONLINE_PORTAL_LIST and S_DISPLAY_ONLINE_LIST -->
davor:
<!-- IF S_CALENDAR_WEEK -->
	<!-- INCLUDE calendar_week_on_index.html -->
<!-- ELSEIF S_CALENDAR_NEXT_EVENTS -->
	<!-- INCLUDE calendar_next_events_on_index.html -->
Cache leeren
Template und Themen aktuallisieren. FERTIG :D
gruß
Stephan
Gruß Stephan :-)
Onetimer
Post by Onetimer »
I still have two minor problems with the Calendar block.
With my own template the corners of the block is slightly out of place;
In SubSilver the blue background is missing (and yes, all cache have been emptied);
Anybody know how I can correct this? If I remember correctly both of these problems were brought up here somewhere before but now I can't find it...
Deutsch sind auch OK!
The second picture is prosilver, not subsilver(2) ;)
Sorry, but i cant help you much without a link...
Onetimer
Post by Onetimer »
Oh yeah, I meant ProSilver! It's not online yet, I'm waiting to get a host and domain until I have these few quirks sorted out. What file or code are you looking for specifically, maybe I can post it here?
Normally im looking for the source of these files:
portal_body.html
_block_config.html
...your block file...
and of course the source of the whole site...
in ff there are developer tolls where you can edit the site in realtime. But it doesnt work with a screenshot ;)
NortonWalker
phpBB.de User: Exotic Shayle
Post by NortonWalker »
So Hallo,
gibt es denn jetzt eine Zusammenfassung in Deutsch?, weil ich blicke hier im Thread garnicht mehr durch nachd en ganzen Ausbesserungen. Ich habe das soweit Installiert, von den was auf der 1.Seite steht und das was auf der 3.Seite steht, diese functions, ausgebessert, aber trotzdem geht es noch nicht, der Block ist zwar ,,soweit da", aber die Schrift im Prosilver und Subsilver ist doppelt so groß und ich bekomme folgende fehlermeldung:
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3837: Cannot modify header information - headers already sent by (output started at /portal/block/calendar.php:37)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3839: Cannot modify header information - headers already sent by (output started at /portal/block/calendar.php:37)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3840: Cannot modify header information - headers already sent by (output started at /portal/block/calendar.php:37)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3841: Cannot modify header information - headers already sent by (output started at /portal/block/calendar.php:37)
Ich denke es liegt entweder an der Portal.php oder am functions_calendar
Währe schön wenn mir jemand helfen kann
denn mein Englisch ist praktisch nicht so gut...
Lg Marcel
NortonWalker
Ok Problem gelöst, wenn es keiner Macht fasse ich mal zusammen:
frold wrote:CALENDAR BLOCK FOR phpBB CALENDAR 0.0.7 (MAYBE EARLIER VERSIONS TOO)
Credit:
DaMysterious from http://damysterious.xs4all.nl/portal_premod/
Minor changes by frold
Demo: http://www.studmed.dk - See the block "Kalender"
CREATE
styles/prosilver/template/portal/block/calendar.html
REPLACE ALL WITH
<div class="panel">
    <div class="inner">
        <span class="corners-top"><span></span></span>
            <h3><a href="{U_CALENDAR}" title="{L_CALENDAR}">{L_MINI_CAL_CALENDAR}</a></h3>
<table cellspacing="0" width="100%">
    <td class="row1" style="text-align: left"><!-- IF CALENDAR_PREV_MINI -->{CALENDAR_PREV_MINI}</a><!-- ENDIF --></td>
    <td class="row1" style="text-align: center"><span class="genmed">{CALENDAR_HEADER_MINI}</span></td>
    <td class="row1" style="text-align: right"><!-- IF CALENDAR_NEXT_MINI -->{CALENDAR_NEXT_MINI}</a><!-- ENDIF --></td>
<table class="table_minical" cellspacing="0" cellpadding="0">
  <!--<tr>
    <th style="text-align:left;" colspan="7">{L_MINI_CAL_CALENDAR}</td>
</tr>-->
  <tr class="row1">
    <td style="width: 5%; text-align: center" class="bg4">{SUNDAY_MINI}</td>
    <td style="width: 5%; text-align: center" class="bg4">{MONDAY_MINI}</td>
    <td style="width: 5%; text-align: center" class="bg4">{TUESDAY_MINI}</td>
    <td style="width: 5%; text-align: center" class="bg4">{WEDNESDAY_MINI}</td>
    <td style="width: 5%; text-align: center" class="bg4">{THURSDAY_MINI}</td>
    <td style="width: 5%; text-align: center" class="bg4">{FRIDAY_MINI}</td>
    <td style="width: 5%; text-align: center" class="bg4">{SATURDAY_MINI}</td>
  <!-- BEGIN mini_calendar_days -->
  <!-- IF mini_calendar_days.START_WEEK -->
    <!-- ENDIF -->
    <!-- IF mini_calendar_days.DUMMY_DAY -->
    <td valign="top" class="bg3_calMon">&nbsp;</td>
    <!-- ELSE -->
      <td valign="top" class="{mini_calendar_days.DAY_CLASS}">
      <table cellpadding="0" cellspacing="1" border="0" width="100%">
          <td class="{mini_calendar_days.HEADER_CLASS}">
              <!-- IF mini_calendar_days.ADD_LINK -->
            <a href="{mini_calendar_days.ADD_LINK}">{mini_calendar_days.NUMBER}</a>
            <!-- ELSE -->
            <!-- ENDIF -->
            <br />
      </table></td>
    <!-- ENDIF -->
    <!-- IF mini_calendar_days.END_WEEK -->
  <!-- ENDIF -->
  <!-- END mini_calendar_days -->
<br clear="all" />
<table class="table_minical" cellspacing="0" cellpadding="0" width="100%">
  <tr class="row1">
        <td style="width: 100%; text-align: center" class="bg4">Events</td>
    <td class="row1">
      <!-- BEGIN events -->
      <!-- IF mini_calendar_days.events.S_FIRST_ROW -->
      <!-- IF mini_calendar_days.BIRTHDAYS --><hr><!-- ENDIF -->
      <!-- ELSE --><hr><!-- ENDIF -->
      <a href="{mini_calendar_days.events.DAY_VIEW_URL}"><!-- IF mini_calendar_days.events.COLOR --><span style="color:#{mini_calendar_days.events.COLOR}"><!-- ENDIF -->
      [{mini_calendar_days.events.NUMBER}]<!-- IF mini_calendar_days.events.COLOR --></span><!-- ENDIF --></a>
      <a href="{mini_calendar_days.events.EVENT_URL}" title="{mini_calendar_days.events.EVENT_SUBJECT}">
      <!-- IF mini_calendar_days.events.DISPLAY_BOLD --><strong><!-- ENDIF -->
      <!-- IF mini_calendar_days.events.IMAGE --><img src="{mini_calendar_days.events.IMAGE}" title="{mini_calendar_days.events.ETYPE_DISPLAY_NAME}" height="20" width="20" /><!-- ENDIF -->
      <!-- IF mini_calendar_days.events.ETYPE_DISPLAY_NAME -->{mini_calendar_days.events.ETYPE_DISPLAY_NAME}:<!-- ENDIF -->
      <!-- IF mini_calendar_days.events.DISPLAY_BOLD --></strong><!-- ENDIF -->
      <!-- IF mini_calendar_days.events.SHOW_TIME --><br /><!-- IF mini_calendar_days.events.ALL_DAY -->{L_ALL_DAY}<!-- ELSE -->
      {L_FROM_TIME}: {mini_calendar_days.events.START_TIME} <br />{L_TO_TIME}: {mini_calendar_days.events.END_TIME}<!-- ENDIF -->
      <!-- ENDIF -->
      <!-- IF mini_calendar_days.events.COLOR --></span><!-- ENDIF --></a><br />
      <!-- END events -->
        <span class="corners-bottom"><span></span></span>
<br style="clear:both" />
OPEN
language/en/common.php
FIND
BEFORE ADD
//Missing lang variables
$lang['MONTH'] = 'Month';
$lang['WEEK'] = 'Week';
$lang['DAY'] = 'Day';
    // Event Calendar
    $lang = array_merge($lang, array(
       'CALENDAR'      => 'Calendar',
       // minical short day names
       'mini_datetime'   => array(
            'Su'      => 'Su',
            'Mo'      => 'Mo',
            'Tu'      => 'Tu',
            'We'      => 'We',
            'Th'      => 'Th',
            'Fr'      => 'Fr',
            'Sa'      => 'Sa',
OPEN
portal.php
FIND
include($phpbb_root_path . 'portal/includes/functions.'.$phpEx);
AFTER ADD
FIND
if ($portal_config['portal_change_style'])
    include($phpbb_root_path . 'portal/block/change_style.'.$phpEx);
AFTER ADD
include($phpbb_root_path . 'portal/block/calendar.'.$phpEx);
OPEN
styles/prosilver/template/portal/portal_body.html
FIND
        <!-- IF S_DISPLAY_MINICAL -->
            <!-- INCLUDE portal/block/mini_calendar.html -->
        <!-- ENDIF -->
AFTER ADD
        <!-- INCLUDE portal/block/calendar.html -->
CREATE
REPLACE ALL WITH
* @name mini_calendar.php
* @package phpBB3 Portal XL 4.0
* @version $Id: mini_calendar.php,v 1.4 2008/04/07 09:44:35 damysterious Exp $
* @copyright (c) 2007 Portal XL 4.0 Group
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
if (!defined('IN_PHPBB'))
    exit;
// Generate calendar view or next events if required ...
calendar_display_mini_month();
// Assign specific vars
$template->assign_vars(array(
        'U_CALENDAR'    => append_sid("{$phpbb_root_path}calendar.$phpEx"),
// Set the filename of the template you want to use for this file.
    'body' => 'portal/block/calendar.html',
OPEN
FIND
$mode_sel_code = "";
AFTER ADD
    * Begin additional Portal XL 4.0 functions
    function calendar_display_center_month()
       global $auth, $db, $user, $config, $template, $date, $available_etype_colors, $available_etype_images, $available_etype_display_names, $month_sel_code, $day_sel_code, $year_sel_code, $mode_sel_code;
       global $phpEx, $phpbb_root_path;
       init_calendar_data();
       init_view_selection_code("month");
       //create next and prev links
       set_date_prev_next( "month" );
       $center_prev_link = append_sid($calling_page, "calM=".$date['prev_month']."&calY=".$date['prev_year']);
       $center_next_link = append_sid($calling_page, "calM=".$date['next_month']."&calY=".$date['next_year']);
       get_weekday_names( $first_day_of_week, $sunday, $monday, $tuesday, $wednesday, $thursday, $friday, $saturday );
       //get the first day of the month
       $date['num'] = "01";
       $date['fday'] = get_fday( $date['num'], $date['month_no'], $date['year'], $first_day_of_week );
       $number_days = gmdate("t", gmmktime( 0,0,0,$date['month_no'], $date['day'], $date['year']));
       //center_calendar_header_txt = $user->lang['MONTH_OF'] . sprintf($user->lang['LOCAL_DATE_FORMAT'], $user->lang['datetime'][$date['month']], $date['day'], $date['year'] );
       $center_calendar_header_txt = $user->lang['datetime'][$date['month']] . ' - ' . $date['year'];
       $subject_limit = get_calendar_config_value("display_truncated_name", 0);
       // Is the user able to view ANY events?
       $user_can_view_events = false;
       if ( $auth->acl_get('u_calendar_view_events') )
          $user_can_view_events = true;
          /* find the group options here so we do not have to look them up again for each day */
          $group_options = get_sql_group_options($user->data['user_id']);
       $counter = 0;
       for ($j = 1; $j < $number_days+1; $j++, $counter++)
          // if it is the first week
          if ($j == 1)
             // find how many place holders we need before day 1
             if ($date['fday'] < 7)
                $date['fday'] = $date['fday']+1;
                for ($i = 1; $i < $date['fday']; $i++, $counter++)
                   // create dummy days (place holders)
                   if( $i == 1 )
                      $center_calendar_days['START_WEEK'] = true;
                      $center_calendar_days['START_WEEK'] = false;
                   $center_calendar_days['END_WEEK'] = false;
                   $center_calendar_days['HEADER_CLASS'] = 'bg3';
                   $center_calendar_days['DAY_CLASS'] = 'bg2';
                   $center_calendar_days['NUMBER'] = 0;
                   $center_calendar_days['DUMMY_DAY'] = true;
                   $center_calendar_days['ADD_LINK'] = '';
                   $center_calendar_days['BIRTHDAYS'] = '';
                   $template->assign_block_vars('center_calendar_days', $center_calendar_days);
          // start creating the data for the real days
          $center_calendar_days['DUMMY_DAY'] = false;
          $center_calendar_days['HEADER_CLASS'] = '';
          $center_calendar_days['DAY_CLASS'] = '';
          if($counter % 7 == 0)
          if($counter % 7 == 6 )
             $center_calendar_days['END_WEEK'] = true;
          $center_calendar_days['NUMBER'] = $j;
          if( $auth->acl_get('u_calendar_create_events') )
             $center_calendar_days['ADD_LINK'] = append_sid("{$phpbb_root_path}calendarpost.$phpEx", "mode=post&calD=".$j."&calM=".$date['month_no']."&calY=".$date['year']);
          $center_calendar_days['DAY_VIEW_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=day&calD=".$j."&calM=".$date['month_no']."&calY=".$date['year']);
          $center_calendar_days['WEEK_VIEW_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=week&calD=".$j."&calM=".$date['month_no']."&calY=".$date['year']);
          //highlight selected day
          if( $j == $date['day'] )
             $center_calendar_days['DAY_CLASS'] = 'bg4';
          //highlight current day
          $test_start_hi_time = mktime( 0,0,0,$date['month_no'], $j, $date['year']) + date('Z');
          $test_end_hi_time = $test_start_hi_time + 86399;
          $test_hi_time = time() + $user->timezone + $user->dst;
          if( ($test_start_hi_time <= $test_hi_time) &&
              ($test_end_hi_time >= $test_hi_time))
             $center_calendar_days['HEADER_CLASS'] = 'highlight';
             $center_calendar_days['DAY_CLASS'] = 'highlight';
          if ( $user_can_view_events && $auth->acl_get('u_viewprofile') )
             // find birthdays
             $center_calendar_days['BIRTHDAYS'] = generate_birthday_list( $j, $date['month_no'], $date['year'] );
          if ( $user_can_view_events )
             //find any events on this day
             $start_temp_date = gmmktime(0,0,0,$date['month_no'], $j, $date['year'])  - $user->timezone - $user->dst;
             $end_temp_date = $start_temp_date + 86399;
             $sql = 'SELECT * FROM ' . CALENDAR_EVENTS_TABLE . '
                   WHERE ( (event_access_level = 2) OR
                      (event_access_level = 0 AND poster_id = '.$db->sql_escape($user->data['user_id']).' ) OR
                      (event_access_level = 1 AND ('.$db->sql_escape($group_options).') ) ) AND
                   ((( event_start_time >= '.$db->sql_escape($start_temp_date).' AND event_start_time <= '.$db->sql_escape($end_temp_date).' ) OR
                    ( event_end_time > '.$db->sql_escape($start_temp_date).' AND event_end_time <= '.$db->sql_escape($end_temp_date).' ) OR
                    ( event_start_time < '.$db->sql_escape($start_temp_date).' AND event_end_time > '.$db->sql_escape($end_temp_date)." )) OR
                    ((event_all_day = 1) AND (event_day LIKE '" . $db->sql_escape(sprintf('%2d-%2d-%4d', $j, $date['month_no'], $date['year'])) . "'))) ORDER BY event_start_time ASC";
                $event_output['COLOR'] = $available_etype_colors[$row['etype_id']];
                $event_output['IMAGE'] = $available_etype_images[$row['etype_id']];
                $event_output['EVENT_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=event&calEid=".$row['event_id']);
                // if the event was created by this user
                // display it in bold
                if( $user->data['user_id'] == $row['poster_id'] )
                   $event_output['DISPLAY_BOLD'] = true;
                   $event_output['DISPLAY_BOLD'] = false;
                $event_output['ETYPE_DISPLAY_NAME'] = $available_etype_display_names[$row['etype_id']];
                $event_output['EVENT_SUBJECT'] = censor_text($row['event_subject']);
                if( $subject_limit > 0 )
                   if(utf8_strlen($event_output['EVENT_SUBJECT']) > $subject_limit)
                      $event_output['EVENT_SUBJECT'] = truncate_string($event_output['EVENT_SUBJECT'], $subject_limit) . '...';
                $template->assign_block_vars('center_calendar_days.events', $event_output);
             $db->sql_freeresult($result);
       $counter--;
       $dummy_end_day_count = 6 - ($counter % 7);
       for ($i = 1; $i <= $dummy_end_day_count; $i++)
          if( $i == $dummy_end_day_count )
       // A typical usage for sending your variables to your template.
          'CALENDAR_HEADER_CENTER'      => $center_calendar_header_txt,
          'DAY_IMG'                  => $user->img('button_calendar_day', 'DAY'),
          'WEEK_IMG'                  => $user->img('button_calendar_week', 'WEEK'),
          'CALENDAR_PREV_CENTER'         => '<a href=\''.$center_prev_link.'\'><<</a>',
          'CALENDAR_NEXT_CENTER'         => '<a href=\''.$center_next_link.'\'>>></a>',
          'CALENDAR_VIEW_OPTIONS'       => $mode_sel_code.' '.$month_sel_code.' '.$day_sel_code.' '.$year_sel_code,
          'SUNDAY'                  => $sunday,
          'MONDAY'                  => $monday,
          'TUESDAY'                  => $tuesday,
          'WEDNESDAY'                  => $wednesday,
          'THURSDAY'                  => $thursday,
          'FRIDAY'                  => $friday,
          'SATURDAY'                  => $saturday,
          'S_POST_ACTION'               => append_sid("{$phpbb_root_path}calendar.$phpEx" ),
    function calendar_display_mini_month()
       // data of akt. month
       $time = getdate(time());
       $calling_page = (!empty($_SERVER['PHP_SELF'])) ? $_SERVER['PHP_SELF'] : $_ENV['PHP_SELF'];
       $mini_prev_link = append_sid($calling_page, "calM=".$date['prev_month']."&calY=".$date['prev_year']);
       $mini_next_link = append_sid($calling_page, "calM=".$date['next_month']."&calY=".$date['next_year']);
       get_weekday_names_mini( $first_day_of_week, $sunday, $monday, $tuesday, $wednesday, $thursday, $friday, $saturday );
       //$mini_calendar_header_txt = $user->lang['MONTH_OF'] . sprintf($user->lang['LOCAL_DATE_FORMAT'], $user->lang['datetime'][$date['month']], $date['day'], $date['year'] );
       $mini_calendar_header_txt = $user->lang['datetime'][$date['month']] . ' - ' . $date['year'];
       $counter = 0;
          if ($j == 1)
                   if( $i == 1 )
                      $mini_calendar_days['START_WEEK'] = true;
                      $mini_calendar_days['START_WEEK'] = false;
                   $mini_calendar_days['END_WEEK'] = false;
                   $mini_calendar_days['HEADER_CLASS'] = 'bg3';
                   $mini_calendar_days['DAY_CLASS'] = 'bg2';
                   $mini_calendar_days['NUMBER'] = 0;
                   $mini_calendar_days['DUMMY_DAY'] = true;
                   $mini_calendar_days['ADD_LINK'] = '';
                   $mini_calendar_days['BIRTHDAYS'] = '';
                   $template->assign_block_vars('mini_calendar_days', $mini_calendar_days);
          $mini_calendar_days['DUMMY_DAY'] = false;
         $mini_calendar_days['WRITE_BOLD'] = 100;
             $mini_calendar_days['END_WEEK'] = true;
          $mini_calendar_days['NUMBER'] = $j;
             $mini_calendar_days['ADD_LINK'] = append_sid("{$phpbb_root_path}calendarpost.$phpEx", "mode=post&calD=".$j."&calM=".$date['month_no']."&calY=".$date['year']);
          $mini_calendar_days['DAY_VIEW_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=day&calD=".$j."&calM=".$date['month_no']."&calY=".$date['year']);
          $mini_calendar_days['WEEK_VIEW_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=week&calD=".$j."&calM=".$date['month_no']."&calY=".$date['year']);
          if( $j == $date['day'] && $date["month_no"] == $time["mon"])
             $mini_calendar_days['DAY_CLASS'] = 'bg4';
             // find birthdays
             $mini_calendar_days['BIRTHDAYS'] = generate_birthday_list( $j, $date['month_no'], $date['year'] );
          $arrayOfDays[] = $mini_calendar_days;
             if($time["mon"] == $date["month_no"]) $day = $date['day']; else $day = 1;
             // startDate = first Day of viewed month
             $start_temp_date = gmmktime( 0,0,0,$date['month_no'], $day, $date['year']);
          $end_temp_date = $start_temp_date + 2678400;
          // find all day events that are still taking place
          $sort_timestamp_cutoff = $start_temp_date - 86400+1;
          // don't list events that are more than 1 year in the future
                 ( event_start_time < '.$db->sql_escape($start_temp_date).' AND event_end_time > '.$db->sql_escape($end_temp_date)." )) OR (sort_timestamp > ".$db->sql_escape($sort_timestamp_cutoff)." AND event_all_day = 1) ) ORDER BY sort_timestamp ASC";
          // find next 5 events
          $result = $db->sql_query_limit($sql, 5, 0);
    //         $result = $monthEventResult;
                $dayOfEvent =  getdate($row["sort_timestamp"]);
                $event_output['NUMBER'] = $dayOfEvent["mday"].".".$dayOfEvent["mon"].".";
                $event_output['DAY_VIEW_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=day&calD=".$dayOfEvent["mday"]."&calM=".$dayOfEvent["mon"]."&calY=".$dayOfEvent["year"]);
                $event_output['WEEK_VIEW_URL'] = append_sid("{$phpbb_root_path}calendar.$phpEx", "view=week&calD=".$dayOfEvent["mday"]."&calM=".$dayOfEvent["mon"]."&calY=".$dayOfEvent["year"]);
                if($date["month_no"] == $dayOfEvent["mon"]) {
                   $arrayOfDays[$dayOfEvent["mday"]-1]["WRITE_BOLD"] = "bold";
                $template->assign_block_vars('events', $event_output);
         for($a=0;$a<count($arrayOfDays);$a++) {
            if(!empty($arrayOfDays[$a]["NUMBER"])) {
               $template->assign_block_vars('mini_calendar_days', $arrayOfDays[$a]);
       $counter--;
          $mini_calendar_days['HEADER_CLASS'] = '';
          $mini_calendar_days['DAY_CLASS'] = '';
          'CALENDAR_HEADER_MINI'         => $mini_calendar_header_txt,
          'CALENDAR_PREV_MINI'         => '<a href=\''.$mini_prev_link.'\'><img src="' . $phpbb_root_path . 'styles/' . $user->theme['theme_path'] . '/theme/images/portal/mini_cal_icon_left_arrow.png' . '" title="' . $user->lang['View_previous_month'] . '" height="16" width="16" alt="<<" /></a>',
          'CALENDAR_NEXT_MINI'         =>  '<a href=\''.$mini_next_link.'\'><img src="' . $phpbb_root_path . 'styles/' . $user->theme['theme_path'] . '/theme/images/portal/mini_cal_icon_right_arrow.png' . '" title="' . $user->lang['View_next_month'] . '" height="16" width="16" alt=">>" /></a>',
          'SUNDAY_MINI'               => $sunday,
          'MONDAY_MINI'               => $monday,
          'TUESDAY_MINI'               => $tuesday,
          'WEDNESDAY_MINI'            => $wednesday,
          'THURSDAY_MINI'               => $thursday,
          'FRIDAY_MINI'               => $friday,
          'SATURDAY_MINI'               => $saturday,
          'S_POST_ACTION_MINI'         => append_sid("{$phpbb_root_path}calendar.$phpEx" ),
    function get_weekday_names_mini( $first_day_of_week, &$sunday, &$monday, &$tuesday, &$wednesday, &$thursday, &$friday, &$saturday )
       global $user;
       switch( $first_day_of_week )
          case 0:
             $sunday = $user->lang['mini_datetime']['Su'];
             $monday = $user->lang['mini_datetime']['Mo'];
             $tuesday = $user->lang['mini_datetime']['Tu'];
             $wednesday = $user->lang['mini_datetime']['We'];
             $thursday = $user->lang['mini_datetime']['Th'];
             $friday = $user->lang['mini_datetime']['Fr'];
             $saturday = $user->lang['mini_datetime']['Sa'];
             break;
          case 1:
             $saturday = $user->lang['mini_datetime']['Su'];
             $sunday = $user->lang['mini_datetime']['Mo'];
             $monday = $user->lang['mini_datetime']['Tu'];
             $tuesday = $user->lang['mini_datetime']['We'];
             $wednesday = $user->lang['mini_datetime']['Th'];
             $thursday = $user->lang['mini_datetime']['Fr'];
             $friday = $user->lang['mini_datetime']['Sa'];
             break;
          case 2:
             $friday = $user->lang['mini_datetime']['Su'];
             $saturday = $user->lang['mini_datetime']['Mo'];
             $sunday = $user->lang['mini_datetime']['Tu'];
             $monday = $user->lang['mini_datetime']['We'];
             $tuesday = $user->lang['mini_datetime']['Th'];
             $wednesday = $user->lang['mini_datetime']['Fr'];
             $thursday = $user->lang['mini_datetime']['Sa'];
             break;
          case 3:
             $thursday = $user->lang['mini_datetime']['Su'];
             $friday = $user->lang['mini_datetime']['Mo'];
             $saturday = $user->lang['mini_datetime']['Tu'];
             $sunday = $user->lang['mini_datetime']['We'];
             $monday = $user->lang['mini_datetime']['Th'];
             $tuesday = $user->lang['mini_datetime']['Fr'];
             $wednesday = $user->lang['mini_datetime']['Sa'];
             break;
          case 4:
             $wednesday = $user->lang['mini_datetime']['Su'];
             $thursday = $user->lang['mini_datetime']['Mo'];
             $friday = $user->lang['mini_datetime']['Tu'];
             $saturday = $user->lang['mini_datetime']['We'];
             $sunday = $user->lang['mini_datetime']['Th'];
             $monday = $user->lang['mini_datetime']['Fr'];
             $tuesday = $user->lang['mini_datetime']['Sa'];
             break;
          case 5:
             $tuesday = $user->lang['mini_datetime']['Su'];
             $wednesday = $user->lang['mini_datetime']['Mo'];
             $thursday = $user->lang['mini_datetime']['Tu'];
             $friday = $user->lang['mini_datetime']['We'];
             $saturday = $user->lang['mini_datetime']['Th'];
             $sunday = $user->lang['mini_datetime']['Fr'];
             $monday = $user->lang['mini_datetime']['Sa'];
             break;
          case 6:
             $monday = $user->lang['mini_datetime']['Su'];
             $tuesday = $user->lang['mini_datetime']['Mo'];
             $wednesday = $user->lang['mini_datetime']['Tu'];
             $thursday = $user->lang['mini_datetime']['We'];
             $friday = $user->lang['mini_datetime']['Th'];
             $saturday = $user->lang['mini_datetime']['Fr'];
             $sunday = $user->lang['mini_datetime']['Sa'];
             break;
    * End additional Portal XL 4.0 functions
I recommand you do the changes you find in this treat too....
viewtopic.php?f=21&t=459&start=30#p6323
dann:
Graceland wrote:Today I have installed these great mod on my new phpbb3 Forum and I have updated it a little bit.
The 60 extra SQL querys on the Portal was too much for me.
I have done these changes:
- Removed the birthdays(31 SQL Querys) from the list, because there is another Box on the portal, which solved it better
- Reduce the Query for every day to one Query at the end for all days
(You needn't use the event_day row, because these timestamps stands in sort_timestamp )
- The mini calendar shows the next 5 events in the next 30 days. Not only from the current month.
- Days with events are shown bold
- The style is changed a little bit
You need do changes in functions_calendar.php and calendar.html.
Open includes/functions_calendar.php
SEARCH
function calendar_display_mini_month() {
REPLACE THE COMPLETE FUNCTION WITH (UP TO function get_weekday_names_mini ...)
   $counter = 0;
      if ($j == 1)
               if( $i == 1 )
         // find birthdays
   $counter--;
OPEN styles/prosilver/template/portal/block/calendar.html
REPLACE ALL WITH
<div class="portal-panel">
   <div class="inner">
         <h3><table cellspacing=0 cellpadding=0><td><img src="{T_THEME_PATH}/images/portal/portal_calendar.gif" width="18px" height="15px" alt=""/>&nbsp;</td><td><a href="{U_CALENDAR}" title="{L_CALENDAR}">Kalender</a></td></table></h3>
				<td align="left" colspan="2"><!-- IF CALENDAR_PREV_MINI -->{CALENDAR_PREV_MINI}</a><!-- ENDIF --></td>
				<td colspan="3" align="center"><span class="genmed">{CALENDAR_HEADER_MINI}</span></td>
				<td align="right" colspan="2"><!-- IF CALENDAR_NEXT_MINI -->{CALENDAR_NEXT_MINI}</a><!-- ENDIF --></td>
  <!--<tr>
</tr>-->
  <tr class="row1">
    <td style="width: 5%; text-align: center"><span class="gensmall" style="color:#0000FF">{SUNDAY_MINI}</span></td>
    <td style="width: 5%; text-align: center"><span class="gensmall" style="color:#0000FF">{MONDAY_MINI}</span></td>
    <td style="width: 5%; text-align: center"><span class="gensmall" style="color:#0000FF">{TUESDAY_MINI}</span></td>
    <td style="width: 5%; text-align: center"><span class="gensmall" style="color:#0000FF">{WEDNESDAY_MINI}</span></td>
    <td style="width: 5%; text-align: center"><span class="gensmall" style="color:#0000FF">{THURSDAY_MINI}</span></td>
    <td style="width: 5%; text-align: center"><span class="gensmall">{FRIDAY_MINI}</span></td>
    <td style="width: 5%; text-align: center"><span class="gensmall" style="color:#FF0000">{SATURDAY_MINI}</span></td>
          <td class="{mini_calendar_days.HEADER_CLASS}" style="font-weight:{mini_calendar_days.WRITE_BOLD}; text-align:center;">
      </table></td>
<br clear="all" />
  <tr class="row1">
      <td style="width: 100%; text-align: center" class="bg4">Veranstaltungen</td>
    <td class="row1">
      <!-- IF events.S_FIRST_ROW -->
      <a href="{events.DAY_VIEW_URL}"><!-- IF events.COLOR --><span style="color:#{events.COLOR}"><!-- ENDIF -->
      [{events.NUMBER}]<!-- IF events.COLOR --></span><!-- ENDIF --></a>
      <a href="{events.EVENT_URL}" title="{events.EVENT_SUBJECT}">
      <!-- IF events.DISPLAY_BOLD --><strong><!-- ENDIF -->
      <!-- IF events.IMAGE --><img src="{events.IMAGE}" title="{events.ETYPE_DISPLAY_NAME}" height="20" width="20" /><!-- ENDIF -->
      <!-- IF events.ETYPE_DISPLAY_NAME -->{events.ETYPE_DISPLAY_NAME}:<!-- ENDIF -->
      <!-- IF events.DISPLAY_BOLD --></strong><!-- ENDIF -->
      <!-- IF events.SHOW_TIME --><br /><!-- IF events.ALL_DAY -->{L_ALL_DAY}<!-- ELSE -->
      {L_FROM_TIME}: {events.START_TIME} <br />{L_TO_TIME}: {events.END_TIME}<!-- ENDIF -->
      <!-- IF events.COLOR --></span><!-- ENDIF --></a><br />
      <!-- END events -->
I hope you understand my english and could use these modifications.
Die komplette funktion und nicht nur die eine Zeile
und zum Schluss sollte man noch beachten:
DeanB wrote:Den Fehler hatte ich auch , es liegt an der calendar.php dort sind vor dem <?php und ?> leerstellen die gelöscht werden müssen .
amroth wrote:habe alles soweit installed usw nur kommt jetzt ne fehler meldung
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3764: Cannot modify header information - headers already sent by (output started at /portal/block/calendar.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3766: Cannot modify header information - headers already sent by (output started at /portal/block/calendar.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3767: Cannot modify header information - headers already sent by (output started at /portal/block/calendar.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3768: Cannot modify header information - headers already sent by (output started at /portal/block/calendar.php:1)
was muss ich machen das die verschwindet oder was hab ich falsch gemacht ?
und nicht nur die davor sondern auch die dahinter...
Lg Marcel
hegse
phpBB.de User: hegse
Post by hegse »
Nabend.
Funktioniert das ganze eigentlich mit dem Calendar Update auf 0.1.0?
Hat das schon jemand ausprobiert?
Gruß Hegse
Alexandrej
Post by Alexandrej »
Nein :(
Has anyone come up with a version compatible with alightner's calendar 0.1.0 ?
So since I got no response, I started to figure out if I could adapt the calendar block to version 0.1.0 so we could keep the calendar view exactly like it was under calendar 0.0.8 as version 1.0.3 of the calendar published in this thread (viewtopic.php?f=21&t=1567&p=10174&hilit ... ner#p10174) is not a calendar, just a block with a list of upcoming events.
I just upgraded to calendar 0.1.0 and the calendar works fine in my forum, but it blew up the portal completely.
When I go to the portal, I get a blank page with the following message :
Fatal error: Call to undefined function calendar_display_mini_month() in root\phpbb3_torontois\portal\block\calendar.php on line 21
So I followed frold's the instructions on how to create the portal block on page 1 of this thread and I found out the issue is that the update of file file root\includes\functions_calendar.php, got rid of entire function calendar_display_mini_month() function and all other calendar block functions. This is exaclty the error I got above where it could not find this function.
So I added the missing code :
OPEN
FIND
AFTER ADD
       $counter = 0;
          if ($j == 1)
                   if( $i == 1 )
             // find birthdays
       $counter--;
       $counter = 0;
          if ($j == 1)
                   if( $i == 1 )
             // find birthdays
       $counter--;
       global $user;
          case 0:
             break;
          case 1:
             break;
          case 2:
             break;
          case 3:
             break;
          case 4:
             break;
          case 5:
             break;
          case 6:
             break;
Then, frold recomended to do the changes you find in this treat too....
viewtopic.php?f=21&t=459&start=30#p6323[/quote]
So I went ahead and made the following changes :
SEARCH
   $counter = 0;
      if ($j == 1)
               if( $i == 1 )
         // find birthdays
   $counter--;
So now, I don't get the error message Fatal error: Call to undefined function calendar_display_mini_month() in root\phpbb3_torontois\portal\block\calendar.php on line 21,
but I do the the following error message :
SQL ERROR [ mysql4 ]
Syntax error near '\'%,15,%\') ) ) AND ((( event_start_time >= 1250208000 AND event_sta' on line 4 [1064]
Looks like I am getting close. Any idea what could be causing this problem ?
Midge
Sponsor
Post by Midge »
I've just finished installing the Portal version 1.0.4. The only block I couldn't get to work again was this calendar block (I'm still using version 0.0.8 for the moment). I added the code in portal.php - as far as I can see this was the only file that was touched by the portal update earlier, everything else remained the same - but only a white page was displayed after the additions, without any error messages.
Am I missing anything?
NortonWalker
Hi Leute hab ein Problem,
der zieht mir seit dem neuen Update vom Portal den Kalenderblock ganz breit woran liegt das?
aber ich glaube das liegt nicht am Update nur was kann ich machen...
Ist aber immer nur beim aktuellen Monat . . .
Also der titel Kalender ist richtig, nur ab den Tagen und das was darunter kommt geht ca. 40px nach refchts raus und drückt alles nach links...
