[REL] Gallery Block 1.4.1
wintstar
phpBB.de User: wintstar
phpBB.com User: wintstar
Re: [REL] Gallery Block 1.4.1
Post by wintstar »
wintstar wrote:Wird der Mod noch weiter entwickelt ?
Der Versions Server kann nicht erreicht werden
wintstar
Gibt es darauf keine Antwort?
Gruß Stephan :-)
Nashra
phpBB.de User: FRvN
phpBB.com User: Nashra
Post by Nashra »
Mess wrote:Can someone please translate Nashra's solution please? I can get the gist of it, but would like to be sure I understand all of it, and google/translator isn't helping. :)
Sorry my english is not so good :oops:
Wäre jemand von euch hier so nett und würde es "Mess" übersetzen damit er weiß worum es geht, vielen Dank
Ralf
„Die Menschen müssen lernen wieder zu sehen, was sie anschauen.
Sie müssen ihr Pferd fühlen, um es begreifen zu können.“
Tom Dorrance, 1910 - 2003
Hallo Nashra,
hilf dir selbst / help yourself.
Ich kann auch kein Englisch-ich übersetze es hiermit: http://translate.google.de/?hl=de&tab=wT#
Nashra
phpBB.de User: FRvN
Post by Nashra »
archivar wrote:Hallo Nashra,
Oh, das ist ja mal wirklich genial, danke dir ;)
Nashra
phpBB.de User: FRvN
Post by Nashra »
Hello from Google-Translation :D :D
Delete in the index.php this code completely
(See last post)
then the error is only times when you call off the index.
The portal work with all the settings of the display which have been made in the ACP,
to your private images which are displayed only when you are online that is here the
Rights / settings observed.
The only drawback, the images in the index are now always and only with the latest
and private images i.e. the rights and settings are ignored in the ACP.
Remedy for this, since private images do not appear to us for guests
in the ... / template / index.html
(See last post)
kwl
Post by kwl »
Running;
PHP 5.2.14
mySQL 5.1.50
phpbb3 3.0.7
phpgalery 1.0.5
portal 1.0.6
When I install Gallery Block 1.4.1 it works, I see it in the .mod portal area. I can see the images on the portal page but after this install I get a blank page when going to the board index.
I uninstalled Gallery Block 1.4.1 and the index works again.
I did have to modify the install.xml /portal/block/additional_blocks.php
From;
if (!defined('IN_PORTAL'))
exit;
To;
exit;
Other than that the install was perfect except that the board index no longer works afterward.
Any thoughts?
Turn on debug in your config.php and post any error messages here.
Lucian_rider
phpBB.com User: Lucian_rider
Post by Lucian_rider »
I recently updated both my portal and Nick Vergessens Gallery Mod to the latest versions and am somewhat disappointed that the previous version of the Gallery Block that I was using (1.2.3) is not compatible with the latest gallery and the new Gallery Block version does not offer the same functionality.
What I really liked about the older version was the ability to display images from from a particular album using the ID number and having it display randomly the pictures in that album on every refresh.
Presently I am using the recent images block but I don't really want that.
In addition by no longer using a custom made center block and taking the short cut of inserting a complete block from the gallery (example the recent_body.html) makes changing the style difficult. I'm using BF_Vista style and after making the necessary style changes in the gallery I can't get the styling to work in the Portal. You can see my dilemma here: http://www.lucianriders.com/forum
Has anyone been able to modify the code to get the center block to display random images from a single album? I'm hoping that someone here might have come up with something to do what the old version used to.
Muppi
phpBB.de User: Muppi
phpBB.com User: Muppi
Post by Muppi »
Also das istr ne tolle Sache, mein Problem ist nur, das bei mir
Einstellungen für den kleinen Block
und Einstellungen für den mittleren Block
keinerlei Wirkung zeigen (nicht sichtbar im Hauptportal sind).
Woran könnte das liegen ?
wintstar
Post by wintstar »
Bump viewtopic.php?f=21&t=92&p=25245#p24785
Staatsgeheimniss oder wieso gibt es dazu keine Antwort :shock:
Gruß Stephan :-)
Christian hat zur Zeit leider nicht so viel Zeit für den Block, ich werde mich des Blocks aber in nächster Zeit mal annehmen und die genannten Fehler beseitigen.
wintstar
Post by wintstar »
Ich bedanke mich für die dennoch lang dauernte Antwort. :)
Stephan
Gruß Stephan :-)
Ori
Post by Ori »
Gibt es den denn noch irgendwo zum Download? :)
Ori wrote:Gibt es den denn noch irgendwo zum Download? :)
schau mal hier: http://www.flying-bits.org/viewtopic.php?f=80&t=1030
EDIT: Der Download-Link für den Gallery Block v1.4.1, hier auf dem Board, geht auch wieder.
Muppi
Post by Muppi »
Marc wrote:Christian hat zur Zeit leider nicht so viel Zeit für den Block, ich werde mich des Blocks aber in nächster Zeit mal annehmen und die genannten Fehler beseitigen.
Marc hast du Dir das Problem schon angeschaut ?
