problem in portal with HE board.
oferxxx
Translator
Post by oferxxx »
Boardlink: http://oferxxx.gofreeserve.com/index.php?
PHP Version: 3.0.2
Nothing; just install the portal.
Look on the trasnlated files to understand wher's the problem; uninstall and reinstall the portal with some change in the trasnlated files.
My board works in the Hebrew language as default, so when im try to get in the forum with this default language I just see a white page with nothing in it, But when im login with the British English language I can see the whole forum and gat into the portal without any problem.
Any suggestion for fixin this issue ?
P.S. I've change the default language to British English so you can see the forum and register without any problems, when you'll be registerd user try to switch to the other language from the UCP and you'll can see what i've ment for.
Whene this issue will fix then i'll release my Hebrew translation.
Sincerely; oferxxx.
Ice
Re: problem in portal with HE board.
Post by Ice »
Have you created a Hebrew translation for the portal? If not it'll try to open non-existing files and break.
oferxxx
Translator
Post by oferxxx »
Of course, i've traslated the next files: info_acp_portal; lang_portal; lang_portal_acp; portal_install.
I forgot to add, the ACP works just fine and the tab "Arcade" show with all in it in my traslation.
Ice
Post by Ice »
Hmm, it may be that the files din't save as the right type, can you confirm they are all saved as utf-8 without bom?
oferxxx
Translator
Post by oferxxx »
I've already confirm that...twice.
I think the problem caused by the fille: lang_portal.php
Case when I remove the line from the installation:
	$user->add_lang('mods/lang_portal');
(includes/functions.php)
then I can see my forum, but can't get into the portal (white page with nothing in it).
EDIT: Now even the ACP (in Hebrew) dosn't work.
Ice
Post by Ice »
Would you possibly mind sticking all your Hebrew translations in a zip file and sticking them on your server and pming me a link to it?
oferxxx
Translator
Post by oferxxx »
Ice wrote:Would you possibly mind sticking all your Hebrew translations in a zip file and sticking them on your server and pming me a link to it?
You got it.
