Neon (Base: prosilver)
Style: Neon (This style only works with "prosilver"! / Dieser Styles funktioniert nur mit "prosilver"!)
Style Version: 1.0.1
Style Download: https://www.phpbb.com/customise/db/style/neon_2/
to: root/styles/Neon/template/portal/*.*
to: root/styles/Neon/theme/portal.css
to: root/styles/Neon/theme/images/portal/*.*
open: root/styles/Neon/template/overall_footer.html
open: root/styles/Neon/template/overall_header.html
<div id="custom-menu-h">
							<!-- IF S_DISPLAY_MEMBERLIST --><a href="{U_MEMBERLIST}" title="{L_MEMBERLIST_EXPLAIN}" style="text-align: right; font-family: Arial; color: #ffffff; font-size: 12px; font-weight: bold; text-transform: uppercase; text-shadow: black 0.1em 0.1em 0.1em; border: 1px solid #1a1a1a; -moz-border-radius: 4px; -webkit-border-radius: 4px; -khtml-border-radius: 4px; border-radius: 4px; background: #060606; padding: 7px">{L_MEMBERLIST}</a><!-- ENDIF -->
<div id="wrap">
	<div id="page-body">
open: root/styles/Neon/template/theme/colours.css
li.row:hover {
	background-color: transparent;
li.row:hover {
	background-color: #DAE2FF;
open: root/styles/Neon/theme/stylesheet.css
open: root/styles/Neon/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forumbg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 0px 0px 2px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forumbg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dt>' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="forumbg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
nach: root/styles/Neon/template/portal/*.*
nach: root/styles/Neon/theme/portal.css
nach: root/styles/Neon/theme/images/portal/*.*
Öffne: root/styles/Neon/template/overall_footer.html
Öffne: root/styles/Neon/template/overall_header.html
<div id="wrap">
Öffne: root/styles/Neon/template/theme/colours.css
li.row:hover {
li.row:hover {
Öffne: root/styles/Neon/theme/stylesheet.css
Öffne: root/styles/Neon/template/portal/_block_config.html
