[RELEASE]National Flags mod block
Theriddler
Post by Theriddler »
National Flags on board 3 portal 2.x
If you didn't have the mod allready installed then install the mod first!
https://www.phpbb.com/customise/db/mod/national_flags/
Then Create a new php file called: portal_flags.php
Put the following inside that file:
* @package Board3 Portal v2 - Team
* @copyright (c) Board3 Group ( www.board3.de ) , theriddler ( http://www.phpbbservice.nl )
* @ignore
if (!defined('IN_PHPBB'))
   exit;
* @package Team
class portal_flags_module
   * top      1
   * left      2
   * center   4
   * right      8
   * bottom   16
   public $columns = 21;
   * Default modulename
   public $name = 'PORTAL_FLAGS';
   * Default module-image:
   public $image_src = 'portal_custom.png';
   * module-language file
   public $language = 'portal_flags_module';
   * custom acp template
   public $custom_acp_tpl = '';
   global $config, $user, $phpEx, $phpbb_root_path;
//Begin: National_Flag
if (!empty($config['allow_flags']))
   if (!function_exists('top_flags'))
      include($phpbb_root_path . 'includes/functions_flag.' . $phpEx);
   top_flags();
//End: National_Flag
return 'flags_center.html';
      return array(
         'title'   => 'PORTAL_FLAGS',
         'vars'   => array(),
   * API functions
    function install($module_id)
        return true;
    function uninstall($module_id)
       return true;
Save this file to: root/portal/modules/
Create a new php file called: portal_flags_module.php
* DO NOT CHANGE
   exit;
   $lang = array();
// DEVELOPERS PLEASE NOTE
   'PORTAL_FLAGS'  => 'National flags',
save this file to: root/language/en/mods/portal/
Create a new html file called: flags_center.html
put the following inside that file:
<span style="width:100%;"><!-- BEGIN fnum --><span style="width:10%;float:left;text-align:center;">{fnum.FLAG}<br />{fnum.L_FLAG_USERS}</span><!-- END fnum --></span><br style="clear:both" />
Save this file to: root/styles/your-style/template/portal/modules/
Refresh templates
Finish >> Add your new national flags block
