Portalbox Sudoku 1.0.1
There4you
Post by There4you »
Hi There, I have installed this block and modified the code to suit as per instructions but , I am unable to get the block to display on this site.
http://www.tasmania4you.com
I am not sure what i should be looking at. :(:(
There4you
Re: Portalbox Sudoku 1.0.1
Post by There4you »
Update..
it now shows but it says
Sudoku Top 10
Username { RESULT }
I assume that is till someone posts a score?
Slav
Wuerzi
Tester
phpBB.de User: Würzi
phpBB.com User: Wuerzi
Post by Wuerzi »
why ask you in 2 forums :roll:
The answer you can find by http://vfalcone.pikenet.ru/forum/index.php
You dont use Portalbox Sudoku 1.0.1 :?
There4you
Post by There4you »
Wuerzi wrote:why ask you in 2 forums :roll:
I asked on two cause one I downloaded from here, and was not sure which was better to post on... :(:(
eoinzy
phpBB.com User: eoinzy
Post by eoinzy »
Hi guys, I know this is an old topic but I've recently downloaded this mod from another site that gives this site as the point of contact.
I have everything installed and working but I just need the portal block added. All the files are uploaded also.
In .MODs in the ACP, there is no mention of adding a sudoku block. Theres a custom box option but that is seemingly for putting in your own code.
Also, the link in the above post points to a site that seems to have been taken down!
Any help appreciated!
site is:
http://www.dingostew.com
/EDIT: Nevermind. I think my portal.php in my root was from board3portal 102 so i jsut copied it from my /phpBB3/ folder into the root and it worked, once i changed the root path!
Thanks.
