DarkFX (Base: prosilver)
Style: DarkFX
Style Version: 1.0.1
phpBB Version: 3.0.12
Board3Portal Version: 2.0.2
Style Download: https://www.phpbb.com/customise/db/style/darkfx/
to: root/styles/darkfx/template/portal/*.*
to: root/styles/darkfx/theme/portal.css
to: root/styles/darkfx/theme/images/portal/*.*
open: root/styles/darkfx/template/overall_footer.html
open: root/styles/darkfx/template/overall_header.html
<div class="navmenu">
<div class="wrap2" style="width: {$DARKFX_BOARD_WIDTH};"><div class="navlink"><ul>
				<!-- IF U_PORTAL --><li><a href="{U_PORTAL}">
					<strong>{L_PORTAL}</strong>
				</a></li><!-- ENDIF -->
</ul></div></div>
<div class="cat-head">
<div class="cat-title"><span><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a></span></div><!-- BEGIN navlinks --><div class="cat-title" style="margin-left: 5px;"><span><a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a></span></div><!-- END navlinks -->
<div class="cat-title"><span><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a>&nbsp;&nbsp;&nbsp;&nbsp;<!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a></span></div><!-- BEGIN navlinks --><div class="cat-title" style="margin-left: 5px;"><span><a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a></span></div><!-- END navlinks -->
open: root/styles/darkfx/theme/stylesheet.css
Als erstes musst du den Style downloaden und Installieren. Wenn das geschafft ist und der Style läuft, kannst du das Portal für diesen Style nach folgender Anleitung installieren:
nach: root/styles/darkfx/template/portal/*.*
nach: root/styles/darkfx/theme/portal.css
nach: root/styles/darkfx/theme/images/portal/*.*
Öffne: root/styles/darkfx/template/overall_footer.html
Öffne: root/styles/darkfx/template/overall_header.html
</ul></div></div>
Öffne: root/styles/darkfx/theme/stylesheet.css
