( help needed) board3_portal_2_0_2
Current Version: 2.0.2
Released: 2013-10-27
allen62
phpBB.com User: allen62
Post by allen62 »
Your Portal Version: board3_por
Boardlink: http://pakisoldiers.com/
i just install bord post i have installed many mods but all working fine before when i install portal it give me a lot of errors
i tried evervything which i can do ... i cecked whole installation 2 times all seems fine
Hi guys i am trying to install board3_portal_2_0_2 mod ... i am getting a lot of errors in one file and forum is looking like that mentioned in screen shots below ... i check all things 3 times all things are ok idk why this problem is comming so please anyone hep me...
i am using phpbb3 version 3.0.12
here is a screen shots
and this is my include/tempelate.php file
http://www.filedropper.com/template_5
Re: ( help needed) board3_portal_2_0_2
I see no picture, the include / template.php you do not have to edit.
For your style there is a tutorial: viewtopic.php?f=57&t=5399
allen62
Post by allen62 »
thanx bro now my problem solved i allpied ur method
ty again now plz tell me how to change this i want to put here text Home page instead of portal
Open: root/ext/board3/portal/language/en/portal.php
Find:
'PORTAL'			=> 'Portal',
Replace with:
'PORTAL'			=> 'Home page',
Note the correct encoding UTF-8 without BOM
allen62
Post by allen62 »
ty bro
last help plz i am putting my call of duty game server codes from game tracker.com code this
<a href="http://www.gametracker.com/server_info/cod4.youngmasti.pk:28960/" target="_blank"><img src="http://cache.www.gametracker.com/server_info/cod4.youngmasti.pk:28960/b_160_400_1_ffffff_c5c5c5_ffffff_000000_0_1_0.png" border="0" width="160" height="248" alt=""/></a>
when i put this code in portal custom block it is looking like this
it have to look like this
Make sure you enabled HTML in the custom block setting. Otherwise it'll try to parse BBCode which you're obviously not using.
